Loonhaunt
How to assure that Python Modules are installed in the correct directory?
Mon Nov 16, 2020 9:26 pm
I seem to be having trouble with my Python3 via Thonny finding my serial module, or pyserial for that matter. I am getting an ATTRIBUTEError
for 'Serial' has no module?
  File "/home/pi/Documents/PyDev/Ser_Tesst_shrt.py", line 4, in <module>
    ser = serial.Serial(port="/dev/ttyAMC0"),
AttributeError: module 'serial' has no attribute 'Serial'
I have both serial and pyserial installed I have uninstalled both and re-installed them individually to see if it makes a difference.
Any suggestion at this point would be great. I don't remember having this issue with Python 2.7?
Dave
Re: How to assure that Python Modules are installed in the correct directory?
Mon Nov 16, 2020 10:32 pm
Are you using sudo pip3 install ... to install things?
Loonhaunt
Mon Nov 16, 2020 10:57 pm
Hi Dougie how have you been?
Yes I am using pip3. I got stuck on this issue a couple of years ago but haven't written much python code since then. I do remember that switching over to pyserial made a difference with the particular code that I was working on at the time but it doesn't seem to matter now? I am at a different machine now but when back at the Rpi I will paste in the actual code if that would be of any help. I am pretty sure I will have some other issues pop up with this code relating to attempting to intercede sensor data coming from Arduino serial.print() , but I can't get past this error to continue debugging.
Thanks so much for your help,
Dave
B.Goode
Tue Nov 17, 2020 12:01 am
I think it is possible that in /home/pi/Documents/PyDev/ you have a file serial.py which is being imported instead of the standard serial library module.
The import and subsequent use works for me with RasPiOS Buster -
pi@raspberrypi:~ $ sudo python3
Python 3.7.3 (default, Jul 25 2020, 13:03:44)
[GCC 8.3.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import serial
>>> ser = serial.Serial(port="/dev/ttyAMA0")
hippy
Tue Nov 17, 2020 1:02 pm
That's my feeling too. The error message indicates some 'serial' module has been found, but it doesn't include a 'def Serial():' -
Loonhaunt
Tue Nov 17, 2020 2:23 pm
Your answers got me started poking over Stackoverflow to see is there were similar issues.
What I did on my windows 10 machine was to
pip3 uninstall serial
pip3 install pyserial
then with powershell I got the message that I should upgrade pip.
Installing collected packages: pyserial
Successfully installed pyserial-3.4
WARNING: You are using pip version 20.2.3; however, version 20.2.4 is available.
You should consider upgrading via the 'c:\program files\python39\python.exe -m pip install --upgrade pip' command.
PS C:\WINDOWS\system32> python.exe -m pip install --upgrade pip
Collecting pip
  Downloading pip-20.2.4-py2.py3-none-any.whl (1.5 MB)
     |████████████████████████████████| 1.5 MB 3.2 MB/s
Installing collected packages: pip
  Attempting uninstall: pip
    Found existing installation: pip 20.2.3
    Uninstalling pip-20.2.3:
      Successfully uninstalled pip-20.2.3
Successfully installed pip-20.2.4
I have to think about what this means to my raspberry pi 3 with python3?
This is the result on from IDLE on my labtop
Connected to Arduino port:COM4
Created file
b'BME680 test\r\
b'72.72,836.74,22.11,0.00,4855.95\r\
b'72.84,836.74,22.18,313.47,4855.95\r\
b'73.04,836.76,22.28,322.65,4856.59\r\
b'73.15,836.74,22.29,326.80,4855.95\r\
b'73.20,836.72,22.28,327.45,4856.59\r\
b'73.26,836.72,22.40,326.48,4855.95\r\
b'73.27,836.74,22.72,325.51,4855.95\r\
b'73.29,836.72,23.02,325.83,4855.95\r\
b'73.31,836.74,23.04,328.10,4855.95\r\
b'73.31,836.72,22.91,329.08,4855.95\r\
Data collection complete!
Here is the code that produced the above result
import serial
# -- update your project info --
#serial port of Arduino
#on windows it will be "COM5" format
#on mac it will be "/dev/cu.usbmodemxxx" format
arduino_port = "COM4"
baud = 9600 #arduino uno runs at 9600 baud
fileName="analog-data.csv" #name of the CSV file generated
samples = 10 #how many samples do you want to collect?
print_labels = False #do you want to print out line ids to serial?
# -- no need to edit beyond this line!--
ser = serial.Serial(arduino_port, baud)
print("Connected to Arduino port:" + arduino_port)
file = open(fileName, "a")
print("Created file")
line = 0
while line <= samples:
    # incoming = ser.read(9999)
    # if len(incoming) > 0:
    if print_labels:
        if line==0:
            print("Printing Column Headers")
        else:
            print("Line " + str(line) + ": writing...")
    getData=str(ser.readline())
    data=getData[0:][:-2]
    print(data)
    file.write(data + "\n") #write data with a newline
    line = line+1
print("Data collection complete!")
file.close()
Return to “Python”
