Kbho
PyGTK
Sun Jan 06, 2013 10:39 am
I have been seeing some tutorials around about how to use pyGTK, and downloaded the code for something that uses pyGTK, and i get some errors.
Is this because i need to install it, or configure it?, if you need to install it, can you give me instructions on how to do so.
Kbho
-rst-
Re: PyGTK
Wed Jan 09, 2013 4:01 pm
You might find more knowledgeable people on the Programming - Python sub-forum http://www.raspberrypi.org/phpBB3/viewforum.php?f=32
I suspect there might be an issue with GTK being Gnome based and the Pi default 'desktop environment' is LXDE which might not support this.
Also it would be good to see the exact errors...
http://raspberrycompote.blogspot.com/ - Low-level graphics and 'Coding Gold Dust'
Return to “Python”
