Newbie's code works in IDLE but not python
Posted: Mon Jun 29, 2020 11:09 pm
by ryanjg80
I've tried a bunch of different things but I'm having a few problems. 2 issues...
1 - The following code runs just fine in IDLE and Pycharm on my PC (except the GPIO parts, of course) but when run in python, the string manipulation parts don't function as intended. (See comments in code)
2 - I tried using GPIO.cleanup() under an eventually: in the try: loop. It says nothing to clean up. However, without it, the second time I run this it says channels are in use. I cheated and added a GPIO.setwarnings(False) in, but I'd like to know how to avoid that.
Any help would be GREATLY appreciated!
import RPi.GPIO as GPIO
import time
from datetime import datetime
in1 = 16
in2 = 18
GPIO.setmode(GPIO.BOARD)
GPIO.setup(in1, GPIO.OUT)
GPIO.setup(in2, GPIO.OUT)
GPIO.output(in1, True)
GPIO.output(in2, True)
mem_num = ""
valid_card = False
mem_file = open("members.txt", "r")
mem_list = mem_file.readlines()
mem_file.close()
while True:
    try:
        mem_num = input("?")
        if mem_num == "1":
            break
        valid_card = mem_num.startswith("VHA1")
       #The following line seems to be where my trouble is.
        mem_num = str(mem_num.replace("VHA100", ""))
        #Any valid card scanned start withs 'VHA100'. The following line
        #in Python returns the entire original string, including the 'VHA100' prefix.
        print(mem_num)
        if (mem_num + "\n") in mem_list and valid_card:
            print("Valid")
            GPIO.output(in1, False)
            GPIO.output(in2, False)
            time.sleep(.5)
    except Exception as err:
        now = datetime.now()
        dt_string = now.strftime("%d/%m/%Y %H:%M:%S")
        print (err, "***", dt_string)
I know my error-trapping is terrible, but I wasn't sure what Exceptions to look for, so I figured I'd add them as they popped up.
Re: Newbie's code works in IDLE but not python
Posted: Tue Jun 30, 2020 3:02 am
by pidd
Must be something funny getting scanned on the input, try partially filtering one extra character at a time.
mem_num = str(mem_num.replace("V", ""))
then
mem_num = str(mem_num.replace("VH", ""))
etc
and see what happens.
Or try casting the input to a string to make sure it is (I don't know python, this might need changing)
 mem_num = str(input("?"))
Posted: Tue Jun 30, 2020 4:13 am
by ryanjg80
First suggestion didn't work. The type should automatically be string. The only reason I added a type conversion is because the code did not work as expected, but for debugging purposes, I tried type(mem_num) and it returned string.
Posted: Tue Jun 30, 2020 4:27 am
by pidd
I guessed you had put the str() in out of desperation but then I wondered if the result was all number whether it could be auto-casted as an integer.
The code seems fine, it must be something strange with the input string, possibly the old utf8/ascii/iso. problems?
Posted: Tue Jun 30, 2020 5:26 am
by ryanjg80
I don’t know about old problems. How do I fix it?
Every card scanned in the testing phase returned a string with the type() test. If it didn’t return a string (because it was completely numerical) it’s supposed to fail the validation anyway, hence the valid_card boolean test. I’m at a loss.
Posted: Tue Jun 30, 2020 11:55 am
by hippy
You don't say what results you are getting. You could try with simpler code - This works for me; enter VHA100123 and it prints 123 etc -
while True:
  if mem_num == "1":
    break
  mem_num = mem_num.replace("VHA100", "")
  print(mem_num)
Maybe you aren't running with Python 3 ? If run with Python 2 it will error with some rather peculiar error messages -
pi@Pi3B:~/tmp $ python2 test.py
?VHA100123
  File "y.py", line 2, in <module>
  File "<string>", line 1, in <module>
NameError: name 'VHA100123' is not defined
Or, with your error trapping -
pi@Pi3B:~/tmp $ python2 y.py
?VHA100123
(NameError("name 'VHA100123' is not defined",), '***', '30/06/2020 12:53:31')
If that's what you're seeing; run with "python3" rather than "python".
Posted: Tue Jun 30, 2020 4:16 pm
by ryanjg80
I did say in the in the code comment that I’m getting the original string back, not the manipulated one I’m looking for. The scanner inputs “VHA1000123”. I want to get back only the last 4 characters of that, but it’s still returning the entire original string. I’m not getting any error messages (now that I’ve suppressed the GPIO ones). As far as the version of python, how do I know which I’m running? If it’s a matter of updates, these are very new installs, and I’ve run ‘sudo apt update’ on them recently.
Posted: Tue Jun 30, 2020 5:28 pm
by pcmanbob
I took your posted code and stripped out most of it leaving just the bit that asks for input and does the string replacement.
import time
while True:
    try:
        if mem_num == "1":
            break
        print(mem_num)
I saved this as ryan.py and then ran it from the command line with
python3 ryan.py
and this was the output from this code
pi@BusterPi:~ $ python3 ryan.py
?VHA1000234
0234
?VHA1000123
0123
?VHA1001234
1234
So to me it looks like it works just fine......
as for which python your are running the code under,
python = python2
python3 = python3
Posted: Tue Jun 30, 2020 5:30 pm
by B.Goode
New installs of what?
The IDLE IDE is not installed by default in any of the 3 variants of the 2 most recent releases of the RasPiOS Buster Operating System.
The IDLE IDE is written in, and invokes, the Python2 interpreter. When you start IDLE it tells you what version of Python it is using as the very first line on the default Python Shell window. When you start the Python interpreter from a shell (command line) prompt it will give the same information -
pi@RPi3BplusOffice:~ $ python
Python 2.7.13 (default, Sep 26 2018, 18:42:22)
[GCC 6.3.0 20170516] on linux2
Type "help", "copyright", "credits" or "license" for more information.
Posted: Tue Jun 30, 2020 5:34 pm
by ghp
To check python version, place the snippet at the top of your file.
import sys
print (sys.version)
assert sys.version_info >= (3, 7)
Posted: Tue Jun 30, 2020 7:12 pm
by hippy
Maybe post a complete transcript of you starting the code, entering your input and getting back the results because it works for me and for pcmanbob. There's no obvious reason why it's not working for you.
There's no reason mem_num = str(mem_num.replace("VHA100", "")) would not remove the "VHA100" from your string unless that "VHA100" isn't actually in the string, even though it may appear to be there when printed on screen.
From "The scanner inputs" I am guessing you aren't typing in at the command line, but receiving from some other device ?
If so that might be introducing non-printable, invisible, characters into the string.
Perhaps add this immediately after your mem_num = input("?") ...
        for n in range(len(mem_num)):
           print(str(n) + " : " + hex(ord(mem_num[n])))
That will show exactly what's in each string being input, may give a clue.
One final thought: It's not an 'oh' instead of 'zero' or 'ell' for 'one', or vice-versa, issue is it?
Posted: Tue Jun 30, 2020 8:30 pm
by pidd
hippy wrote:From "The scanner inputs" I am guessing you aren't typing in at the command line, but receiving from some other device ?
I came to the same conclusion as you, there must be something hiding in the input string. I was wondering if the scanner outputs utf8 or something but I haven't got the knowledge of Python to know how that deals with other character sets and I haven't got the correct words to describe it other than saying multi-byte.
Posted: Wed Jul 01, 2020 2:58 pm
by hippy
However, and I had forgotten about this -
I'm not sure what would be causing 'input()' to return something different in IDLE and PyCharm and when run from the command line. That just adds to the mystery rather than solves anything.
It could be input data is being typed in when run in IDLE or PyCharm is coming from the scanner device when run at the command line.
Posted: Wed Jul 01, 2020 3:31 pm
by pidd
My lack of knowledge of Python means I would not know, but it doesn't seem unreasonable that a later version of a language had improved character set handling and now allows say UTF8 in an input instead of filtering it to ASCII? I avoid anything to do with character sets, life is complicated enough.
Posted: Wed Jul 01, 2020 4:55 pm
by hippy
Absolutely agree with that last sentence. Annoyingly Python 3 often means one has to. I've been battling those issues for the last few days when porting Python 2 code which handles 8-bit data bytes via serial to Python 3.
I'm also not familiar with 'input()', IDLE or PyCharm. It could be a version issue but I was under the impression that those Python IDE's use the system installed version/sub-versions rather than their own versions. That doesn't mean there can't be version/sub-version issues but it would surprise me if that.
Posted: Wed Jul 01, 2020 5:09 pm
by dbrion06
w/r python version:
the command line
python --version
gives the version (one can mess up python 3 and 2...)
w/r encoding:
http://sametmax.com/lencoding-en-python ... our-toute/ (sorry, it is in colloquial French) advises
a) to begin each python script, whatever the version, with the following line:
# coding: utf-8
(this is the default verion for python3, but NOT with python2
b) every chain should be prefixed with u ex: u"VIHCOVID" works with python 3.8.1 and python 2.6.6 (likely between)
c) every input should be decoded in python2 (does not work with python3) ex:
Python 2.6.6 (r266:84292, Jun 20 2019, 14:14:55)
[GCC 4.4.7 20120313 (Red Hat 4.4.7-23)] on linux2
>>> input("?").decode('utf8')
?"salut à tous"
u'salut \xe0 tous'
Posted: Wed Jul 01, 2020 8:35 pm
by ryanjg80
I ran the code using python3. It worked! I had no idea there were different versions. I am indeed using a barcode scanner for the input. I apologize for not supplying enough information.
So, first problem solved. Now what about the GPIO stuff? I’m currently cheating by suppressing the warnings, but how would I properly use GPIO.cleanup()?
Posted: Wed Jul 01, 2020 8:48 pm
by hippy
Just put that at the end of the code though I wouldn't worry about it, would just keep using GPIO.setwarnings(False).
In fact, having multiple programs running using RPi.GPIO, I find calling GPIO.cleanup() causes more problems than it solves so I never use it. YMMV.
Posted: Thu Jul 02, 2020 4:53 am
by ryanjg80
Got it! I’ll just leave well enough alone. Thank you all so much for your help! When I get some more time to toy around with it, I’ll add the string testing functions posted earlier and run it in Python (not 3) just to help clear up the mystery. I’m actually a bartender. Wrote this code to validate cards at a private club where I work. Definitely worth the time and effort now that I don’t have to stop what I’m doing to press a button to let someone in.
Posted: Thu Jul 02, 2020 1:40 pm
by dbrion06
You should keep with python3: things are likely to get worse and worse with python2 (the same way migrating from hoses driven cars to fuel cars made things terrible for horse drivers): new stuff -ex : within 5 years, a better card reader will, may be , exist -will get only python3 support : manufacturers have no time for python 2....
Posted: Fri Jul 03, 2020 6:40 am
by ryanjg80
Oh no. I will continue to use Python3 to run the system. I meant to solve the mystery surrounding this, I’ll add those functions to the string input by the scanner and run in on my system at home. I don’t want to leave anyone hanging if they’re curious.
