Anugerah Nuri Satria
Re: Write data just when the output changes
Mon Jul 13, 2020 5:59 am
Dear Mr.Pcmanbob
I have followed that instruction. But why my LCD does not ON? i have given VCC and GND correctly.
WhatsApp Image 2020-07-13 at 12.57.01.jpeg (49.54 KiB) Viewed 703 times
pcmanbob
Mon Jul 13, 2020 7:52 am
From the information supplied its impossible for anyone to tell you why your LCD is not working, we don't have access to your pi/LCD so we can only off advice on the information supplied.
But a guess would be that if your display is not even illuminating your have not connected something correctly.
Tue Jul 14, 2020 1:30 am
Hello Mr. PcManBob
Now, My LCD is ON. But I dont know how to show output from terminal to LCD in realtime for my code before.
Python Code for counting.
WhatsApp Image 2020-07-14 at 08.26.21.jpeg (54.48 KiB) Viewed 661 times
Tue Jul 14, 2020 5:31 am
pcmanbob
Tue Jul 14, 2020 7:48 am
OK
So now you have it working can you post the code that produced the LCD screen as shown in your image so I can see what setup you used.
then I can make suggestions on how to add it to your existing code.
Thu Jul 16, 2020 12:44 am
I still use your code Sir. because it matches for my project to count leaf spring. I dont know how to show in LCD sir. I need your suggestions.
pcmanbob wrote:
Fri Jun 12, 2020 9:34 am
This version of the code will also give you the number of seconds between detections
import RPi.GPIO as GPIO
import time
counting = 0
GPIO.setmode(GPIO.BCM)
GPIO.setup(25, GPIO.IN)
GPIO.setup(21, GPIO.IN, pull_up_down=GPIO.PUD_UP)
try:
    start  = time.time()
    while True:
        if GPIO.input(25) == 1:
            counting += 1
            print (('Proses Tapper Roll ke %s') % counting)
            print(time.strftime("%H:%M:%S"))
            now = time.time()
            print ("time between detections", round((now - start), 2), "seconds")
            while GPIO.input(25) == 1:
                time.sleep(0.1)
            start = time.time()
        if GPIO.input(21) == 0:
            print("reset counter")
            counting = 0
            while GPIO.input(21) == 0:
                time.sleep(0.1)
            start = time.time()
        time.sleep(0.1)
except KeyboardInterrupt:
    GPIO.cleanup()
again tested working using 2 switches.
pcmanbob
Thu Jul 16, 2020 8:08 am
Yes I understand you want to use the original code , but I need the code you used to make your display work , the program you ran to put the text on the LCD in your picture , as without that I don't know what setup you used for the LCD.
I cant use one of my examples becuae I connect my LCD's differently you how you have connected yours.
Thu Jul 16, 2020 8:26 am
This is my code SIr
import time
import csv
import lcddriver
display = lcddriver.lcd()
display.lcd_display_string("Counter :", 1)
counting = 0
GPIO.setup(24, GPIO.IN, pull_up_down=GPIO.PUD_UP)
csvfile = "countermesin"
try:
    start  = time.time()
    while True:
            counting += 1
            now = time.time()
                time.sleep(0.1)
            start = time.time()
            result = str(counting)+"item"
            display.lcd_display_string(result,2);
        if GPIO.input(24) == 0:
            counting = 0
            while GPIO.input(24) == 0:
                time.sleep(0.1)
            start = time.time()
        time.sleep(0.1)
    GPIO.cleanup()
pcmanbob
Thu Jul 16, 2020 8:38 am
looking at your code you have already worked out how to display information on the LCD , so what problem are you having in changing the print lines to output the information on the display ?
Thu Jul 16, 2020 8:40 am
i just found that way today sir, I still confuse how to make 2 line to make 2 output. average time between and sum of item.
pcmanbob
Thu Jul 16, 2020 10:37 am
Looking at this code you posted
import time
import csv
import lcddriver
counting = 0
try:
    start  = time.time()
    while True:
            counting += 1
            now = time.time()
                time.sleep(0.1)
            start = time.time()
            counting = 0
                time.sleep(0.1)
            start = time.time()
        time.sleep(0.1)
    GPIO.cleanup()
does it actually output anything to the screen ? because this line
does not have any of the setup details required to make the LCD work
it should look more like this
lcd = CharLCD(i2c_expander='PCF8574', address=0x27, port=1,
              cols=20, rows=4, dotsize=8,
              charmap='A02',
              auto_linebreaks=True,
              backlight_enabled=True)
this is only an example take from the documents.
you need to provide me with the information in the first line.
expander= ????
address=????
Fri Jul 17, 2020 3:13 am
if I run my code, it will give output like this
WhatsApp Image 2020-07-17 at 10.05.09.jpeg (39.48 KiB) Viewed 492 times
For Expander and Adress.
pi@raspberrypi:~ $ i2cdetect -y 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- 27 -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
I dont know how to check expander sir
pcmanbob
Fri Jul 17, 2020 8:36 am
I am surprised but ok , can you run this test code to check your display works as expected regarding display positioning.
import time
import csv
import lcddriver
lcd = lcddriver.lcd(cols=20, rows=4)
lcd.cursor_pos = (0, 0)
lcd.write_string("line 0")
lcd.cursor_pos = (1, 1)
lcd.write_string("line 1")
lcd.cursor_pos = (2, 2)
lcd.write_string("line 2")
lcd.cursor_pos = (3, 3)
lcd.write_string("line 3")
time.sleep(30)
you should see text on all 4 lines, moving one place further to the right on each line.
Fri Jul 17, 2020 9:03 am
pi@raspberrypi:~/Documents $ python saiful.py
File "saiful.py", line 6, in <module>
TypeError: __init__() got an unexpected keyword argument 'rows'
pcmanbob
Fri Jul 17, 2020 9:23 am
Are you using RPLCD ?
if so which version did you down load ?
if no please post a link to the driver you are using....
Mon Jul 20, 2020 12:50 am
pi@raspberrypi:~ $ sudo pip install RPLCD
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: RPLCD in /usr/local/lib/python2.7/dist-packages (1.3.0)
i just follow your instruction before at
https://rplcd.readthedocs.io/en/stable/ ... ation.html
pcmanbob
Mon Jul 20, 2020 8:58 am
Then I am confused because no were in the docs I can see does it say import lcddriver
the import command for RPLCD is from RPLCD.i2c import CharLCD
then you need a set up line similar to the one I posted before
              charmap='A02',
so what instructions were you following when it saidto use import lcddriver
Tue Jul 21, 2020 1:01 am
Sorry, i remember that i follow this web:
https://github.com/jumejume1/pi-LCD-Ult ... nce-lcd.py
But it is used just for 2 lines.
              charmap='A02',
pcmanbob
Tue Jul 21, 2020 9:28 am
So if you have installed RPLCD, then if my guess at your hardware set up is correct then this should output test on all 4 lines of the LCD
import time
              charmap='A02',
              compat_mode=True)
lcd.clear()
time.sleep(30)
this is only a test to see if I have guessed your hardware setup correctly, if its no right then you will have to adjust it and let me know what needs changing.
Wed Jul 22, 2020 1:29 am
Yes sir, it works in my Rpi. So how can I show a counter and average time between?
import time
              charmap='A02',
              compat_mode=True)
lcd.clear()
time.sleep(30)
WhatsApp Image 2020-07-22 at 08.27.57.jpeg (50.4 KiB) Viewed 281 times
pcmanbob
Wed Jul 22, 2020 10:40 am
Ok so now we have that sorted.
try this code , note its untested so there may be spacing errors and I have set it to clear the LCD on every update ,
you can change this if you make it so that you load the LCD fixed test once and then update the changing text on each pass.
It makes it a little more complex and you have to account for changing text lengths.
import time
              charmap='A02',
              compat_mode=True)
counting = 0
try:
    start  = time.time()
    while True:
            counting += 1
            now = time.time()
            lcd.clear()
            lcd.write_string("Proses Tapper Roll)
            lcd.cursor_pos = (1, 0)
            lcd.write_string("Item")
            lcd.cursor_pos = (1, 6)
            lcd.write_string str(counting)
            lcd.cursor_pos = (1, 12)
            lcd.write_string(time.strftime("%H:%M:%S"))
            lcd.cursor_pos = (2, 0)
            lcd.write_string("Between detections")
            DT = str(round((now - start), 2))
            DT = DT + " seconds"
            lcd.cursor_pos = (3, 0)
            lcd.write_string(DT)
                time.sleep(0.1)
            start = time.time()
            lcd.clear()
            lcd.cursor_pos = (1, 3)
            lcd.write_string("reset counter")
            counting = 0
                time.sleep(0.1)
            start = time.time()
        time.sleep(0.1)
    GPIO.cleanup()
Thu Jul 23, 2020 11:01 am
What should I change to make that program start from zero while counting?
import time
              charmap='A02',
              compat_mode=True)
counting = 0
try:
    start  = time.time()
    while True:
            counting += 1
            now = time.time()
            lcd.clear()
                time.sleep(0.1)
            start = time.time()
            lcd.clear()
            counting = 0
                time.sleep(0.1)
            start = time.time()
        time.sleep(0.1)
    GPIO.cleanup()
pcmanbob
Thu Jul 23, 2020 11:12 am
You should already have that option it was added along with the second button before you even added the LCD.
This code resets the counter to zero
            counting = 0
                time.sleep(0.1)
            start = time.time()
Thu Jul 23, 2020 11:32 am
I mean when I start firstly, that code will give output 2 directly ( 1 and 2 Items)
Or I make a mistake?
pcmanbob
Thu Jul 23, 2020 11:42 am
Well it working correctly when the results were bing output to the display , using this code
import time
counting = 0
try:
    start  = time.time()
    while True:
            counting += 1
            now = time.time()
                time.sleep(0.1)
            start = time.time()
            counting = 0
                time.sleep(0.1)
            start = time.time()
        time.sleep(0.1)
    GPIO.cleanup()
so I suggest you try running this code again to see if your hardware is the problem.
all we changed to use the LCD was were the output was sent to , changed print statements to lcd write statements.
As your count is controlled by your sensor and I don't have such a sensor I can really help with the sensor input.
Return to “Python”
