jediob1
python game shooting not working
Sat Dec 29, 2012 5:33 pm
Hello, i have modified a dodging game's code i found in a book (http://inventwithpython.com/chapter20.html) and i wanted to make the player shoot. Here is my code:
import pygame, random, sys
from pygame.locals import *
WINDOWWIDTH = 900
WINDOWHEIGHT = 600
TEXTCOLOR = (255, 255, 255)
BACKGROUNDCOLOR = (200, 50, 50)
FPS = 40
BADDIEMINSIZE = 10
BADDIEMAXSIZE = 40
BADDIEMINSPEED = 1
BADDIEMAXSPEED = 8
ADDNEWBADDIERATE = 6
PLAYERMOVERATE = 5
def terminate():
    pygame.quit()
    sys.exit()
def waitForPlayerToPressKey():
    while True:
        for event in pygame.event.get():
            if event.type == QUIT:
                terminate()
            if event.type == KEYDOWN:
                if event.key == K_ESCAPE: # pressing escape quits
                    terminate()
                return
def playerHasHitBaddie(playerRect, baddies):
    for b in baddies:
        if playerRect.colliderect(b['rect']):
            return True
    return False
def drawText(text, font, surface, x, y):
    textobj = font.render(text, 1, TEXTCOLOR)
    textrect = textobj.get_rect()
    textrect.topleft = (x, y)
    surface.blit(textobj, textrect)
def playerWin():
    playerImage = pygame.image.load('playerHappy.png')
    windowSurface.blit(playerImage, playerRect)
    drawText('You Win!!!', font, windowSurface, (WINDOWWIDTH / 3), (WINDOWHEIGHT / 3))
    drawText('Press any key to restart.', font, windowSurface, (WINDOWWIDTH / 3) - 80, (WINDOWHEIGHT / 3) + 50)
    pygame.display.update()
def gameOver():
    # Stop the game and show the "Game Over" screen.
    playerImage = pygame.image.load('playerSad.png')
    drawText('Game Over', font, windowSurface, (WINDOWWIDTH / 3), (WINDOWHEIGHT / 3))
# set up pygame, the window, and the mouse cursor
pygame.init()
mainClock = pygame.time.Clock()
windowSurface = pygame.display.set_mode((WINDOWWIDTH, WINDOWHEIGHT))
pygame.display.set_caption('Cancer Attack')
pygame.mouse.set_visible(False)
# set up fonts
font = pygame.font.SysFont(None, 48)
fontSmall = pygame.font.SysFont(None, 26)
# set up images
playerImage = pygame.image.load('player.png')
playerRect = playerImage.get_rect()
baddieImage = pygame.image.load('baddie.png')
bulletImage = pygame.image.load('bullet.png')
bulletRect = playerImage.get_rect()
# show the "Start" screen
windowSurface.fill(BACKGROUNDCOLOR)
drawText('Cancer Attack', font, windowSurface, (WINDOWWIDTH / 3), (WINDOWHEIGHT / 3))
drawText('Use the mouse to move. Press any key to start.', fontSmall, windowSurface, (WINDOWWIDTH / 3) - 30, (WINDOWHEIGHT / 3) + 50)
topScore = 0
while True:
    # set up the start of the game
    bullets = []
    baddies = []
    score = 0
    playerRect.topleft = (WINDOWWIDTH / 2, WINDOWHEIGHT - 50)
    moveLeft = moveRight = moveUp = moveDown = False
    reverseCheat = slowCheat = False
    baddieAddCounter = 0
    bulletAddCounter = 0
    while True: # the game loop runs while the game part is playing
        score += 1 # increase score
                terminate()
                if event.key == ord('z'):
                    reverseCheat = True
                if event.key == ord('x'):
                    slowCheat = True
                if event.key == K_LEFT or event.key == ord('a'):
                    moveRight = False
                    moveLeft = True
                if event.key == K_RIGHT or event.key == ord('d'):
                    moveLeft = False
                    moveRight = True
                if event.key == K_UP or event.key == ord('w'):
                    moveDown = False
                    moveUp = True
                if event.key == K_DOWN or event.key == ord('s'):
                    moveUp = False
                    moveDown = True
            if event.type == KEYUP:
                    reverseCheat = False
                    score = 0
                    slowCheat = False
                    score = 0
                        terminate()
                    moveLeft = False
                    moveRight = False
                    moveUp = False
                    moveDown = False
            if event.type == MOUSEMOTION:
                # If the mouse moves, move the player where the cursor is.
                playerRect.move_ip(event.pos[0] - playerRect.centerx, event.pos[1] - playerRect.centery)
        # Add new baddies at the top of the screen, if needed.
        if not reverseCheat and not slowCheat:
            baddieAddCounter += 1
        if baddieAddCounter == ADDNEWBADDIERATE:
            baddieSize = random.randint(BADDIEMINSIZE, BADDIEMAXSIZE)
            newBaddie = {'rect': pygame.Rect(random.randint(0, WINDOWWIDTH-baddieSize), 0 - baddieSize, baddieSize, baddieSize),
                        'speed': random.randint(BADDIEMINSPEED, BADDIEMAXSPEED),
                        'surface':pygame.transform.scale(baddieImage, (baddieSize, baddieSize)),
            baddies.append(newBaddie)
        if pygame.key.get_pressed()[K_SPACE]:
            bulletAddCounter += 1
            newBullet = {'rect': bulletRect,
                         'speed': 2,
                         'surface': pygame.transform.scale(bulletImage, (1, 1)),
            bullets.append(newBullet)
        # Move the mouse cursor to match the player.
        pygame.mouse.set_pos(playerRect.centerx, playerRect.centery)
        # Move the baddies down.
        for b in baddies:
                b['rect'].move_ip(0, b['speed'])
            elif reverseCheat:
                b['rect'].move_ip(0, -5)
            elif slowCheat:
                b['rect'].move_ip(0, 1)
         # Delete baddies that have fallen past the bottom.
        for b in baddies[:]:
            if b['rect'].top > WINDOWHEIGHT:
                baddies.remove(b)
        # Draw the game world on the window.
        # Draw the score and top score.
        drawText('Score: %s' % (score), font, windowSurface, 10, 0)
        drawText('Highscore: %s' % (topScore), font, windowSurface, 10, 40)
        # Draw the player's rectangle
        # Draw each baddie
        for b in baddies:
            windowSurface.blit(b['surface'], b['rect'])
        for t in bullets[:]:
            windowSurface.blit(t['surface'], t['rect'])
            t['rect'].centery += 1
        # Check if any of the baddies have hit the player.
        if playerHasHitBaddie(playerRect, baddies):
            if score > topScore:
                topScore = score # set new top score
            gameOver()
            break
        if (score > 999):
            playerWin()
            break
        mainClock.tick(FPS)
I checked that the drawing code is being run by doing a print statement, however the bullets don't appear. I did change the bulletRect to the playerRect to see what would happen, and the player started moving down the screen so at least i know something is going on.
I use the python IDLE for development (not IDLE 3)
I am fluent in Objective C, however I am new to Python/Pygame and only in 6th grade.
I would appreciate any form of help very much. Thank you for your time and good will.
Heckles
Re: python game shooting not working
Sat Dec 29, 2012 6:00 pm
I could be barking up completely the wrong tree here as I only had a quick look..
but
shouldn't that be:
bulletRect = bulletImage.get_rect() ???
not sure that's the cause of the issue or whether I've got something wrong as I'm a beginner myself with Python
jediob1
Sat Dec 29, 2012 6:12 pm
Heckles wrote:I could be barking up completely the wrong tree here as I only had a quick look..
but
shouldn't that be:
Thanks Heckles! Didn't catch that. That might have caused some problems. Didn't fix the main problem, but thanks anyways! :D
Gibble
Sat Dec 29, 2012 6:50 pm
Hiya,
Not a Python man, so someone will probably correct me. I've had a play with your code...I think you are just referencing the same bullet each time in creation, so you won't get multiple bullets (I think!). So if you try something like...
            newBullet = {'rect': playerImage.get_rect(),
                         'speed': 2,
                         'surface': pygame.transform.scale(bulletImage, (10, 10)),
            newBullet['rect'].centerx = playerRect.centerx
            newBullet['rect'].centery = playerRect.centery
So we use the latest image each time and position it the same as the player...and then...
       for t in bullets:
            t['rect'].centery -= 1
to make the bullet go upwards.
Its probably not the best way to do it, getting the playerRect each time, but I hope it make point you in the right direction.
jediob1
Sat Dec 29, 2012 7:44 pm
THANK YOU GIBBLE SO MUCH YOU DA MAN THAT FIXED IT!! :D Now one thing that would be nice is that the bullet spawns in the center of the player. I have done this before in my ping-pong iPhone app but again not sure how to do it in Python.
-rst-
Mon Dec 31, 2012 5:47 pm
Completely off the cuff... (I definitely have to find the time to install pygame... :oops: )
Assuming the player and bullet images are not the same size, you might want to combine Heckles' suggestion into Gibble's code and try changing:
to
newBullet = {'rect': bulletImage.get_rect()
(the code seems to be centering the bullet image on the player center, but that wrong rect might push it off...)
http://raspberrycompote.blogspot.com/ - Low-level graphics and 'Coding Gold Dust'
jediob1
Mon Dec 31, 2012 6:14 pm
Uhh... You want me to change the same thing to the same thing? And I Already tried both Heckles and Gibble's suggestions... Thanks anyways!
Gibble
Tue Jan 01, 2013 4:12 pm
I think its the 'scale' thats putting it off. There needs to be a handle on what the object actual is compared to how its displayed (and then what points are being used for stuff like collision detection etc). If you scale, where its its left/right/center etc ?
Losing track a bit of the changes, but try something like...
bulletImage = pygame.transform.scale(bulletImage,(10,10))
So we scale it earlier once, no need to keep doing it anyway.
           newBullet = {'rect': bulletImage.get_rect(),
                         'speed': 2,
                         'surface': bulletImage,
You may also want to do something like create all the bullets first when everything initializes (say 20 bullets), then just flag them live/dead later or something and change positions, to save recreating objects etc. Not sure if some of the code would have memory leaks keep creating new bullets or not. I may be misleading you there, so just have it in mind maybe.
Gibble
Tue Jan 01, 2013 4:21 pm
Just testing it, you may want to change it also so that the bullet comes out of the top, rather than center...so...
                         'speed': 2,
            newBullet['rect'].midbottom = playerRect.midtop
I think I changed the bullet image file from the player image, but not sure it will make much diff. Having fun with this :).
Gibble
Tue Jan 01, 2013 4:34 pm
Couldn't resist while I was at it ;)....If you wanted to then make the bullets kill the baddies...
def bulletHits( bulletRect, baddies):
    for b in baddies:
        if bulletRect.colliderect(b['rect']):
            baddies.remove(b)
and in main loop...
                         'speed': 2,
        for b in bullets:
                bulletHits(b['rect'], baddies)
Makes it a bit too easy now though! Maybe not the wisest way to do it, but quite quick to code up for fun.
-rst-
Wed Jan 02, 2013 1:07 pm
to
jediob1 wrote:Uhh... You want me to change the same thing to the same thing? And I Already tried both Heckles and Gibble's suggestions... Thanks anyways!
Hmm, how is 'playerImage.get_rect()' same as 'bulletImage.get_rect()'? (unless the images are and always will be the same size) ;)
And the problem with the earlier suggestions were, that the 'bulletRect' variable (which Heckles' fixed the initialisation for) was not used in the (Gibble's) code...
Return to “Python”
