Motion sensor to call script for continuous lighting
Posted: Mon May 18, 2020 2:15 am
by richiepp
Hey All.
I'm using a motion sensor to turn on an LED. My hurdle right now is to have the led stay on for an interval, if more movement is detected I want to reset a timer to zero. I almost have this figured out by using 2 scripts, the first one detects motion and calls the second which turns the LED high for an interval.
What happens now is the sensor detects movement, triggers the led script which executes to completion and the led goes dim, even though I'm constantly moving, a second or so passes and the LED lights up again and the process repeats.
How can I write this so when movement is detected the interval is reset and the LED stays HIGH without interruption?
#!/usr/bin/python
import RPi.GPIO as GPIO
import time
# Use BCM GPIO references
# instead of physical pin numbers
GPIO.setmode(GPIO.BCM)
# Define GPIO to use on Pi
GPIO_PIR = 18
print "PIR Module Test (CTRL-C to exit)"
GPIO.setup(GPIO_PIR,GPIO.IN)      # Echo
Current_State  = 0
Previous_State = 0
try:
  print "Waiting for PIR to settle ..."
  # Loop until PIR output is 0
  while GPIO.input(GPIO_PIR)==1:
    Current_State  = 0
  print "  Ready"
  # Loop until users quits with CTRL-C
  while True :
    # Read PIR state
    Current_State = GPIO.input(GPIO_PIR)
    if Current_State==1 and Previous_State==0:
      # PIR is triggered
      print "  Motion detected!"
      execfile('led_on.py')
     # Record previous state
      Previous_State=1
    elif Current_State==0 and Previous_State==1:
      # PIR has returned to ready state
      print "  Ready"
      Previous_State=0
    # Wait for 10 milliseconds
    time.sleep(0.01)
except KeyboardInterrupt:
  print "  Quit"
  # Reset GPIO settings
  GPIO.cleanup()
Here is the LED code
import time
GPIO_LED = 17
GPIO.setup(GPIO_LED, GPIO.OUT)
GPIO.setwarnings(False)
GPIO.output(GPIO_LED, True)
time.sleep(5)
GPIO.output(GPIO_LED, False)
Re: Motion sensor to call script for continuous lighting
Posted: Mon May 18, 2020 8:47 am
by pcmanbob
Simple answer YES.
What you need to do is start a timer and then while the timer is running you keep checking for the PIR input to go high again , then if it does you reset the timer, that way while there is movement your timer will be constantly reset.
example code based on your code.
#!/usr/bin/python3
import time
GPIO_PIR = 18
GPIO_LED = 17
delay = 60
try:
    print ("Waiting for PIR to settle ...")
        time.sleep(10)
    print ("Ready")
    while True :
    # Read PIR state
    while GPIO.input(GPIO_PIR) == 0:
        time.sleep(0.1)
    start = time.time()
    # PIR is triggered
    print ("Motion detected!")
    # start timer  with reset if pir retriggered
    end = start + delay
    now = time.time()
    while end > now:
        if GPIO.input(GPIO_PIR) == 1:
            start = time.time()
            end = start + delay
        now = time.time()
        time.sleep(0.5)
    print ("Time up")
  print ("  Quit")
  GPIO.cleanup()
untested code , adjusted to run on python3
Posted: Mon May 18, 2020 9:30 pm
by richiepp
Ah yes, this is similar to how it's done in Arduino, C+; my native language so to speak.
So I spent a couple of hours playing with the indenting on your suggested code and just couldn't get it to work. I suspect your suggested code will work if I can get the indents right.
I looked at some tutorial but I'm just not getting it. What indentation will make this work?
Posted: Tue May 19, 2020 9:17 am
by pcmanbob
Adjusted indentation and changed time.sleep to catch triggers better.
tested and working
#!/usr/bin/python3
import time
GPIO_PIR = 18
GPIO_LED = 17
print ("PIR Module Test (CTRL-C to exit)")
delay = 10
try:
        time.sleep(10)
    print ("Ready")
    while True :
        # Read PIR state
            time.sleep(0.1)
        start = time.time()
        # PIR is triggered
        end = start + delay
        now = time.time()
        while end > now:
                print ("Motion detected again!")
                start = time.time()
                end = start + delay
            now = time.time()
            time.sleep(0.1)
        print ("Time up")
  print ("  Quit")
  GPIO.cleanup()
Posted: Tue May 19, 2020 10:53 pm
by richiepp
Hmm. I'm still not quite getting it to run properly.
When I fire up the script the LED goes HIGH and stays HIGH. From the console I see the "Ready" prompt and when I move I get "Motion Detected" which quickly changes to "Motion detected again!" and the message scrolls forever and the script seems to lock up. I haven't seen the "Time Up" message.
Thanks for your help so far!
Posted: Wed May 20, 2020 12:21 am
by richiepp
UPDATE
I just swapped out the PIR with a different one and it's working better. But still needs a bit more tweaking
The code runs but like the original the light goes LOW before it detects more movement and goes HIGH again.
Posted: Wed May 20, 2020 7:24 am
by pcmanbob
OK so first I set the delay at only 10 seconds for testing , try increasing it to several minutes, ( 180 seconds).
Did you set the PIR up correctly ?
my code works correctly that I know because I tested it.
