ChristopheDupriez
All Geany is FLAT (no border for boxes, buttons, tabs, etc.)
Sun May 03, 2020 1:57 pm
Geany seems a great IDE but on the Pi, display are not legible: I have no borders for buttons, boxes, tabs, etc. Am I the only one? Where is the configuration for this so I can correct? Any known workaround? Thanks!
Botspot
Re: All Geany is FLAT (no border for boxes, buttons, tabs, etc.)
Sun May 03, 2020 2:22 pm
Are you still running Raspbian Jessie? That's not the current default window border, gtk theme, or menu appearance.
Upgrading to Raspbian Buster will solve your problem.
BTW this is what Raspbian Buster looks like:
Want to make your own Raspbian image?
  • Hard way: Mess with confusing terminal commands.
  • Easy way: Let Pi-Power-Tools do it all for you!
Boot your image in a VM, Flash from the Internet at top speed, Mount (to drop files in), Edit partitions, Shrink/Expand, Repair, and more. Enjoy! :)
https://github.com/Botspot/Pi-Power-Tools
ChristopheDupriez
Mon May 04, 2020 4:59 pm
Thank you for your explanation. I am using the latest Raspbian download BUT I copied my entire /home/pi from my previous installation. I suppose it copied old configurations of GTK (or other presentation layer software) over the upgraded ones. Any idea of the files I should look after ?
Botspot
Mon May 04, 2020 5:22 pm
Probably best to not copy any hidden folders. Especially .config and .local.
But you can reset your appearance settings by going to menu --> Appearance settings --> set defaults.
To fine-tune your appearance settings, run lxappearance.
ChristopheDupriez
Mon May 04, 2020 5:32 pm
Thanks a lot for your help ! I could even choose between different themes the one I prefer. Really thank you!
Botspot
Mon May 04, 2020 5:55 pm
Would you happen to want your desktop to look like Windows 10?
ChristopheDupriez
Mon May 04, 2020 6:06 pm
Certainly not! I prefer some 3D for spotting buttons faster...
Return to “Python”
