When I put my hand on the sensor, I get the following error.
Error:
max30100 got exception [errno 121] remote i/o error
import os
import sys
import time
import max30100
def main():
try:
mx30 = max30100.MAX30100()
mx30.set_mode(max30100.MODE_SPO2)
# mx30.reset()
# time.sleep(1)
# mx30.startup()
# time.sleep(1)
i = 0
while i < 30:
mx30.set_mode(max30100.MODE_HR)
mx30.read_sensor()
# # The latest values are now available via .ir and .red
# print("HeartRate sensor .ir: {} and .red: {}".format(mx30.ir, mx30.red))
# time.sleep(2)
mx30.reinit()
# time.sleep(1)
mx30.read_sensor()
print("HRate sensor .ir: {} and SpO2 .red: {}".format(mx30.ir, mx30.red))
# temp = mx30.get_temperature()
# print("Temperature {}\n".format(temp))
mx30.reset()
time.sleep(1)
i = i + 1
mx30.reset()
# mx30.shutdown()
except Exception as e:
print("Max30100 got exception {}".format(e))
if __name__ == "__main__":
main()
connection PINS GPIO and sensor max30100
(3.3V -VIN)
(I2C SDA1 - SDA)
(I2C SCL1 - SCL)
(PIN7 - INT )
(GND - GND)
Can anyone help me to fix this issue?
