wngrtzk
Dynamic height of generated PDF based on content
Sun Apr 19, 2020 3:50 pm
I am writing a script that:
1) Pulls a random sentence from a .txt file
2) Creates a PDF with the generated sentence
Some sentences are quite long and span more than one line. For various reasons I want the page size of the PDF to be fixed width and dynamic height based on the content.
Here is a rough visual demonstration of what I mean:
Example 1:
__________________
A short sentence.
__________________
Example 2:
__________________
A longer sentence
that span over
several lines.
__________________
Is there any way to to this?
I have been using fpdf which doesn't seem to have any kind of auto-height option. Is there any other library that may be able to do this?
At the moment, my script looks like this:
#!/usr/bin/env python 3
import fpdf
import random
def GetRandomLineFromFile(filename):
  with open(filename,"r") as f:
    lines = f.read().split("\n")
  return lines[random.randint(0, len(lines)-1)]
line = GetRandomLineFromFile("thousandsofsentences.txt")
pdf = fpdf.FPDF()
pdf.add_page()
pdf.set_font("Arial", size=16)
pdf.write(5,(line))
pdf.output('generatedsentence.pdf', 'F')
Return to “Python”
