stockton
Raspberry Zero parking meter sensor & LEDS
Tue Apr 14, 2020 1:59 pm
I have created the following code, mainly from cut and paste for the HC-SR04 code but the bit about the LEDS is mine.
For the life of me I cannot see why I only ever get a green led no matter the distance.
#Libraries
import RPi.GPIO as GPIO
import time
#GPIO Mode (BOARD / BCM)
GPIO.setmode(GPIO.BCM)
#set GPIO Pins
GPIO_TRIGGER = 18
GPIO_ECHO = 24
GPIO_RED = 22
GPIO_AMBER = 27
GPIO_GREEN = 17
#set GPIO direction (IN / OUT)
GPIO.setup(GPIO_TRIGGER, GPIO.OUT)
GPIO.setup(GPIO_ECHO, GPIO.IN)
GPIO.setup(GPIO_RED, GPIO.OUT)
GPIO.setup(GPIO_AMBER, GPIO.OUT)
GPIO.setup(GPIO_GREEN, GPIO.OUT)
def KlaarAlmal():
    GPIO.output(GPIO_RED, False)
    GPIO.output(GPIO_AMBER, False)
def Rooi():
    KlaarAlmal()
    GPIO.output(GPIO_RED, True)
def Geel():
    KlaarAlmal()
    GPIO.output(GPIO_AMBER, True)
def Groen():
    KlaarAlmal()
    GPIO.output(GPIO_GREEN, True)
def distance():
    # set Trigger to HIGH
    GPIO.output(GPIO_TRIGGER, True)
    # set Trigger after 0.01ms to LOW
    time.sleep(0.00001)
    GPIO.output(GPIO_TRIGGER, False)
    StartTime = time.time()
    StopTime = time.time()
    # save StartTime
    while GPIO.input(GPIO_ECHO) == 0:
    # save time of arrival
    while GPIO.input(GPIO_ECHO) == 1:
    # time difference between start and arrival
    TimeElapsed = StopTime - StartTime
    # multiply with the sonic speed (34300 cm/s)
    # and divide by 2, because there and back
    distance = (TimeElapsed * 34300) / 2
    return distance
if __name__ == '__main__':
    try:
        while True:
            dist = distance()
            print ("Measured Distance = %.1f cm" % dist)
            time.sleep(1)
        if dist < 10:
            Rooi()
        elif dist > 10 and dist < 50:
            Geel()
        elif dist > 50 and dist < 75:
            Groen()
        elif dist > 75:
            KlaarAlmal()
        # Reset by pressing CTRL + C
    except KeyboardInterrupt:
        print("Measurement stopped by User")
        GPIO.cleanup()
I have also written a different bit of code, that uses "from gpiozero import LED" rather than the "import RPi.GPIO as GPIO" used above, that shows that my wiring and soldering is OK as I can get each of the LEDs to switch on and off.
I do not understand the difference between gpiozero and RPi.GPIO. Where can I go to read up on that for I suspect that that is the issue.
Can you please tell me how I got this wrong ?
scotty101
Re: Raspberry Zero parking meter sensor & LEDS
Tue Apr 14, 2020 2:20 pm
Looks like you have an indentation problem.
This is your code
    try:
        while True:
            dist = distance()
            time.sleep(1)
        if dist < 10:
            Rooi()
            Geel()
            Groen()
        elif dist > 75:
            KlaarAlmal()
        GPIO.cleanup()
This is what it should be
    try:
        while True:
            dist = distance()
            time.sleep(1)
            if dist < 10:
                Rooi()
                Geel()
                Groen()
            elif dist > 75:
                KlaarAlmal()
        GPIO.cleanup()
Your code was just reading the distance over and over again withouth actually getting to the if-elif statements to set the correct LEDs.
Also in your "KlaarAmal" function, you are setting the RED LED off twice rather than setting the green LED off
Code should be
def KlaarAlmal():
    GPIO.output(GPIO_GREEN, False)
Electronic and Computer Engineer
Pi Interests: Home Automation, IOT, Python and Tkinter
stockton
Tue Apr 14, 2020 2:36 pm
Thank you it now works. The two reds was silly but I do need to learn about indentation.
Return to “Python”
