Simon.Kemp
same equation giving different answers
Sat Mar 14, 2020 6:35 pm
HI All.
Apologies if this has been answered somewhere else. But this has been bugging me for a couple of hours now and I can't work out why.
To start, i am quite new to python so please bear with me
I bought a pibrella and wrote the code for a reaction game.
essentially, when you react by hitting the button it prints the time you reacted in.
This was to as many decimal points as it wanted so I truncated the answer to 3 decimal places.
The start of the code being:
import pibrella, time, random
def truncate(n, decimals=0):
    multiplier = 10 ** decimals
    return int(n * multiplier) / multiplier
name = input('Hi, Whats your name? ')
while True:
    time.sleep(1+(4 * random.random()))
    pibrella.buzzer.fail()
    pibrella.light.red.on()
    t=time.time()
    r=time.time()-t
    while pibrella.button.read()==0:
        time.sleep(0.001)
    print (name +', your truncated reaction time was',+ truncate(time.time()-t, 3) , 'seconds.')
    print (name +', t=',+ t)
    print (name +', time.time() =',+ time.time())
    print (name +', your reaction time was',+ time.time()-t)
    print (name +', r=',+ r)
    while pibrella.button.read()==1:
        pibrella.light.red.off()
        pibrella.light.green.on()
        time.sleep(2)
        pibrella.light.green.off()
This all works fine. However, the print outputs of
time.time()-t
and
r
are not the same. although they are essentially the same.
The output is as such:
Hi, Whats your name? SImon
SImon, your truncated reaction time was 0.518 seconds.
SImon, t= 1584210706.946039
SImon, time.time() = 1584210707.4652462
SImon, your reaction time was 0.5192432403564453
SImon, r= 5.4836273193359375e-06
Do you want to play again? (y/n): n
Goodbye SImon. Have a nice day! :)
in my mind these 2 lines:
should be the same. But they're not.
can anyone explain why?
Many thanks in advance.
Garvan
Re: same equation giving different answers
Sun Mar 15, 2020 7:29 am
This is an error
    t=time.time()
    r=time.time()-t
Every time you call time.time() it returns the current time, so r will be equal to a tiny number.
What you should do is move r=time.time()-t down to after the button is pressed, so it is equal to the reaction time.
Simon.Kemp
Sun Mar 15, 2020 8:18 am
This is an error
    t=time.time()
    r=time.time()-t
I've done as you suggested and it works perfectly!
Thanks you so much for pointing out my mistake. Lesson learnt!
Return to “Python”
