Kivy app not output to HDMI
Posted: Sun Mar 08, 2020 8:13 pm
Hello Everyone,
I'm run python with kivy on pi-4 B, but it is not output to HDMI .
(code is run from ssh)
that code is OK on pi-3 B+ .
I spended 3-day to fix this problem, but not ok.
Could anyone help me pls?
Modified config.txt
Code's output
Modified config.txt
[pi4]
# Enable DRM VC4 V3D driver on top of the dispmanx display stack
#dtoverlay=vc4-fkms-v3d
max_framebuffers=2
hdmi_force_hotplug:0=1
#hdmi_safe=1
hdmi_group:0=1
hdmi_mode:0=1Code's output
[INFO ] [Logger ] Record log in /home/pi/.kivy/logs/kivy_20-03-09_5.txt
[INFO ] [Kivy ] v2.0.0rc1, git-Unknown, 20200308
[INFO ] [Kivy ] Installed at "/home/pi/.local/lib/python3.7/site-packages/kivy/__init__.py"
[INFO ] [Python ] v3.7.3 (default, Dec 20 2019, 18:57:59)
[GCC 8.3.0]
[INFO ] [Python ] Interpreter at "/usr/bin/python3"
[INFO ] [Factory ] 184 symbols loaded
[INFO ] [Image ] Providers: img_tex, img_dds, img_sdl2, img_pil (img_ffpyplayer, img_gif ignored)
[INFO ] [Window ] Provider: sdl2
[INFO ] [GL ] Using the "OpenGL" graphics system
[INFO ] [GL ] Backend used <sdl2>
[INFO ] [GL ] OpenGL version <b'OpenGL ES 2.0'>
[INFO ] [GL ] OpenGL vendor <b'Broadcom'>
[INFO ] [GL ] OpenGL renderer <b'VideoCore IV HW'>
[INFO ] [GL ] OpenGL parsed version: 2, 0
[INFO ] [GL ] Shading version <b'OpenGL ES GLSL ES 1.00'>
[INFO ] [GL ] Texture max size <2048>
[INFO ] [GL ] Texture max units <8>
[INFO ] [Window ] auto add sdl2 input provider
[INFO ] [Window ] virtual keyboard not allowed, single mode, not docked
[INFO ] [Text ] Provider: sdl2
[INFO ] [Clipboard ] Provider: xclip
[INFO ] [CutBuffer ] cut buffer support enabled
[INFO ] [GL ] NPOT texture support is available
[INFO ] [ProbeSysfs ] device match: /dev/input/event1
[INFO ] [HIDInput ] Read event from </dev/input/event1>
[INFO ] [ProbeSysfs ] device match: /dev/input/event2
[INFO ] [HIDInput ] Read event from </dev/input/event2>
[INFO ] [ProbeSysfs ] device match: /dev/input/event0
[INFO ] [HIDInput ] Read event from </dev/input/event0>
[INFO ] [Base ] Start application main loop
[INFO ] [HIDMotionEvent] using <SIGMACHIP USB Keyboard Consumer Control>
