stockton
Python crc16 AttributeError: 'int' object has no attribute 'to_bytes'
Tue Feb 25, 2020 10:50 am
I am attempting to implement python scrip to read my solar inverter.
I am not a python programmer so please forgive silly questions.
When I attempt code I get the following replies:-
  File "solar2.py", line 28, in <module>
    sendCommand(getCommand('QPI'))
  File "solar2.py", line 4, in getCommand
    crc = crc16.crc16xmodem(cmd).to_bytes(2,'big')
My code looks like:-
import crc16
def getCommand(cmd):
    cmd = cmd.encode('utf-8')
    cmd = cmd+crc
    cmd = cmd+b'\r'
    while len(cmd)<8:
        cmd = cmd+b'\0'
    return cmd
def sendCommand(cmd):
    dev.ctrl_transfer(0x21, 0x9, 0x200, 0, cmd)
def getResult(timeout=100):
    res=""
    i=0
    while '\r' not in res and i<20:
        try:
            res+="".join([chr(i) for i in dev.read(0x81, 8, timeout) if
i!=0x00])
        except usb.core.USBError as e:
            if e.errno == 110:
                pass
            else:
                raise
        i+=1
    return res
res = getResult()
This is on a Raspberry Pi 4 using latest Raspbian with Python 2.7.13
Please tell me where I went wrong.
hippy
Re: Python crc16 AttributeError: 'int' object has no attribute 'to_bytes'
Tue Feb 25, 2020 11:14 am
The problem is in using Python 2 not Python 3. There is no '.to_bytes()' attribute for integers in Python 2 but there is in Python 3 -
integerObject = 123
bytesObject = integerObject.to_bytes(2,'big')
print("Success")
pi@Pi3B:~/tmp $ python2 tobytes.py
  File "tobytes.py", line 2, in <module>
pi@Pi3B:~/tmp $ python3 tobytes.py
Success
B.Goode
Tue Feb 25, 2020 11:18 am
import crc16
    cmd = cmd+crc
    cmd = cmd+b'\r'
    while len(cmd)<8:
        cmd = cmd+b'\0'
    return cmd
    res=""
    i=0
        try:
i!=0x00])
            if e.errno == 110:
                pass
            else:
                raise
        i+=1
    return res
res = getResult()
Do you have any documentation for the crc16 python library module that indicates that to_bytes() is a supported/implemented method for that library?
The examples in ther documentation here do not mention it - but they are only examples and may not be exhaustive - https://pypi.org/project/crc16/
Edit: to acknowledge the pragmatic advice already offered as I was researching this... And subsequently to acknowledge that my response could have been better worded...
hippy
Tue Feb 25, 2020 11:21 am
My reading of the error message is that "crc16.crc16xmodem(cmd)" returns an "int" and ".to_bytes()" applied on an "int" doesn't work in Python 2. It's not actually a 'crc16' library issue AFAICS.
Edit : Also cross-posted while previous being updated.
stockton
Tue Feb 25, 2020 12:50 pm
After reinstalling crc16 as python3 when I python3 solar2.py I get
#!/usr/bin/env python3Traceback (most recent call last):
  File "solar2.py", line 12, in sendCommand
NameError: name 'dev' is not defined
[/code
B.Goode
Tue Feb 25, 2020 1:09 pm
Probably that issue was always there, but was 'masked' by the previous one...
This is the only line in the script that mentions dev
So the error message is succinct and accurate. You haven't specified what this 'dev' object is supposed to refer to.
Return to “Python”
