California
Start the GUI app after RPi boot
Sat Feb 15, 2020 9:31 am
Hello, I have the GUI app made in QT4 (python3), which I would like to run automatically after Pi3B boot.
On Pi2B I did it with (python2):
nano /home/pi/.config/lxsession/LXDE-pi/autostart
@lxterminal -e python /home/pi/Project/main.py
This doesnt't work on Pi3, what would you suggest?
Regards, Vlado
davidcoton
Re: Start the GUI app after RPi boot
Sat Feb 15, 2020 10:34 am
If it needs Python3, change python to python3 in the autostart command.
Signature retired
California
Sat Feb 15, 2020 6:02 pm
I know that, but what I don't know which autostart file is the correct one?
1... /etc/xdg/openbox/autostart
2... /etc/xdg/lxsession/LXDE/autostart
3... /etc/xdg/lxsession/LXDE-pi/autostart
klricks
Sat Feb 15, 2020 6:43 pm
The default autostart (Buster) is the global one here:
If you have created a user autostart somewhere in /home/pi/.config/.... then the global autostart is completely ignored.
Note it is very important that the user autostart, if you have one, contains all the code found in the global autostart.
You can do a simple test and start a well known application from autostart such as pcmanfm (Filemanager) and see if that works before you try your own scripts.
@pcmanfm
California
Sat Feb 15, 2020 7:28 pm
I don't have user autostart in /home/pi/.config/.... modifying autostart in option 3 gave positive result.
It works now as expected.
Thanks for help
Regards, Vlado
Return to “Python”
