tam94131
Requests GET throws up after script running awhile
Fri Feb 14, 2020 3:08 pm
Hi.
My project is a RaspPi 3 B+ with official touchscreen running a python script plus a chromium webpage showing 24x7 acting as a touchscreen controller appliance. I have a bunch of them and this seems to be much more common on WiFi connected RaspPis vs. Ethernet-connected.
Problem is that after it's been running for several days, outbound requests GET calls throw an exception:
HTTPConnectionPool(host='10.x.x.x', port=xxxx): Max retries exceeded with url: /JSON?request=xxxxxdevicebyvalue&ref=353&value=532 (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x74a9f210>: Failed to establish a new connection: [Errno 113] No route to host',))
(I've x'd out sensitive stuff.)
Basically, it can no longer make outbound calls unless it's rebooted. I don't think it's my script (pretty straightforward although it is multi-threaded, etc). WiFI has always been iffy with the RaspPis (although I really only have used Rasp3's) so I don't know if the routing table is getting messed up, it's the library, or what.
Any pointers would be helpful. Since this needs to work, the only alternative is auto-rebooting it once or twice a day. Ugly.
Thanks!
Return to “Python”
