Giga_Pi
inky phat library, need help!
Thu Feb 13, 2020 4:58 pm
Hello!
I recently got a inky pHAT from pimoroni, but when I try to run a test, I get:
File "/home/pi/inkytest.py, line 1, in <module>
from inky import InkyPHAT
ModuleNotFoundError: No module named ''inky'
I did install it using the instructions they provided, pip didn't produce any errors.
Help?
As soon as the DM smiles, you know it's too late...
B.Goode
Re: inky phat library, need help!
Thu Feb 13, 2020 5:17 pm
How, exactly, did you install the library?
And how, exactly, do you try to run your sample script?
(I suspect an issue around versions of the Python interpreter.)
Giga_Pi
Thu Feb 13, 2020 5:27 pm
sudo pip install inky
I then wrote a program:
inkyphat = InkyPHAT('red')
B.Goode
Thu Feb 13, 2020 5:30 pm
Giga_Pi
Thu Feb 13, 2020 5:46 pm
So what should I do?
DirkS
Thu Feb 13, 2020 5:48 pm
Tell us which version of Python you use to run your script...
You probably installed the module for Python v2
B.Goode
Thu Feb 13, 2020 6:05 pm
If you don't want to share the details of what you have done you could try both versions of the Python interpreter and compare the results?
python inkytest.py
and
python3 inkytest.py
(I would expect the first to succeed and the second to fail... )
pcmanbob
Thu Feb 13, 2020 6:39 pm
If you followed the install instructions on the github page then you only installed it for python2,
if you are using thonny they you will be using python 3,
So you need to install it for python 3
sudo pip3 install inky
DirkS
Thu Feb 13, 2020 7:21 pm
That's assuming OP runs Python 3 *and* that pip links to the v2 version
pcmanbob
Thu Feb 13, 2020 7:31 pm
I followed the link to the later version from the pimoroni product page , it only shows the install for python 2 which is why I suggested installing for python 3.
Giga_Pi
Fri Feb 14, 2020 9:08 am
Right, will get back when I can.
Will do all suggested.
I'll be back. :twisted:
Oh yeah, I did:
pip install inky
for clarification.
Giga_Pi
Sun Feb 16, 2020 5:03 pm
Did as was suggested, and installed with
pip3 install inky
Worked first time.
Thanks all!
Return to “Python”
