# Raspberry Pi - Photo Booth
# Copyright (c) 2014, John Croucher - www.jcroucher.com
# All rights reserved.
# Redistribution and use in source and binary forms, with or without modification,
# are permitted provided that the following conditions are met:
# 1. Redistributions of source code must retain the above copyright notice, this
# list of conditions and the following disclaimer.
# 2. Redistributions in binary form must reproduce the above copyright notice, this
# list of conditions and the following disclaimer in the documentation and/or other
# materials provided with the distribution.
# 3. Neither the name of the copyright holder nor the names of its contributors may
# be used to endorse or promote products derived from this software without specific
# prior written permission.
# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
# BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
# IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
# THE POSSIBILITY OF SUCH DAMAGE.
import RPi.GPIO as GPIO
import time
from threading import Thread
import picamera
import PIL
from PIL import Image
# import cups
import os
import sys
import pygame
import random
slideshowRunning = True
basewidth = 177 # Used for merging the photos onto one
printPhoto = False
imgPath = './images/tmp'
input_state = True
# Push button for starting the photo sequence
GPIO.setmode(GPIO.BCM)
GPIO.setup(17, GPIO.IN, pull_up_down=GPIO.PUD_UP)
# Display surface
pygame.init()
pygame.mouse.set_visible(0)
w = pygame.display.Info().current_w
h = pygame.display.Info().current_h
screenSize = (w, h)
screen = pygame.display.set_mode(screenSize, pygame.FULLSCREEN) # Full screen the display with no window
# Used for loading a random photo for the slideshow
def random_file(dir):
files = [os.path.join(path, filename)
for path, dirs, files in os.walk(dir)
for filename in files]
return random.choice(files)
def displayImage(file):
screen.fill((0,0,0))
img = pygame.image.load(file)
img = pygame.transform.scale(img,(w,h)) # Make the image full screen
screen.blit(img,(0,0))
pygame.display.flip() # update the display
# Display a random image
def slideshow():
while True:
if slideshowRunning == True:
checkEvents()
randomFile = random_file('./images/')
displayImage(randomFile)
time.sleep(2) # pause
# Handle events like keypress
def checkEvents():
global input_state
for event in pygame.event.get():
# Shutdown the application if quit event or escape key is pressed
if event.type == pygame.QUIT or ( event.type is pygame.KEYDOWN and event.key == pygame.K_ESCAPE ):
slideshowRunning = False
pygame.quit()
sys.exit()
if event.type is pygame.KEYDOWN and event.key == pygame.K_f: # Switch the display mode between full screen and windowed
if screen.get_flags() & pygame.FULLSCREEN:
pygame.display.set_mode(screenSize)
else:
pygame.display.set_mode(screenSize,pygame.FULLSCREEN)
if event.type is pygame.KEYDOWN and event.key == pygame.K_p:
input_state = False
# On screen text message
def displayStatus(status):
font = pygame.font.SysFont("monospace",24)
text = font.render(status,True,(255,255,255))
# Display in the center of the screen
textrect = text.get_rect()
textrect.centerx = screen.get_rect().centerx
textrect.centery = screen.get_rect().centery
screen.blit(text,textrect)
def displayCnt(cnt):
font = pygame.font.SysFont("monospace",200)
text = font.render(cnt,True,(255,255,255))
# Merge all photos onto one ready for printing
def combineImages():
displayStatus('Please wait. Processing Images')
# Do the merging
blankImage = Image.open('blank.jpg')
image1 = Image.open(imgPath + '/image1.jpg')
image1 = image1.resize((177,140),PIL.Image.ANTIALIAS)
blankImage.paste(image1, (0,4))
image2 = Image.open(imgPath + '/image2.jpg')
image2 = image2.resize((177,140),PIL.Image.ANTIALIAS)
blankImage.paste(image2, (0,144))
image3 = Image.open(imgPath + '/image3.jpg')
image3 = image3.resize((177,140),PIL.Image.ANTIALIAS)
blankImage.paste(image3, (177,4))
image4 = Image.open(imgPath + '/image4.jpg')
image4 = image4.resize((177,140),PIL.Image.ANTIALIAS)
blankImage.paste(image4, (177,144))
blankImage.save(imgPath + '/combined.jpg', 'JPEG', subsampling=0, quality=100)
# Print the photo
def printPhoto():
global input_state
if printPhoto == True:
displayStatus('Printing')
conn = cups.Connection()
printers = conn.getPrinters()
printer_name = printers.keys()[0]
conn.printFile(printer_name, imgPath + '/combined.jpg',"TITLE",{})
time.sleep(2)
# Thread for the slideshow
t = Thread(target=slideshow)
t.start()
with picamera.PiCamera() as camera:
camera.sensor_mode=2
camera.preview_alpha=100
camera.resolution = (3280, 2464)
while True:
checkEvents() # Needed to check for keypresses and close signals
# Putton press to start the photo sequence
if not GPIO.input(17):
input_state = False
if input_state == False:
# Stop the slideshow
# Start the camera preview
camera.start_preview()
# Make the destination path for the photos
if not os.path.exists(imgPath):
os.mkdir(imgPath)
# Loop through the 4 photo taking sequences
for pNum in range (1,5):
camera.annotate_text = 'Photo ' + str(pNum) + ' of 4'
# time.sleep(1)
for countDown in range (4,0,-1):
displayCnt(str(countDown))
# camera.annotate_text = str(countDown)
time.sleep(1)
displayCnt("")
camera.annotate_text = ''
camera.capture( imgPath + '/image' + str(pNum) + '.jpg')
time.sleep(1)
# Stop the camera preview so we can return to the pygame surface
camera.stop_preview()
combineImages()
printPhoto()
displayImage( imgPath + '/combined.jpg' ) # Display a preview of the combined image
time.sleep(5)
# Move the temp files to a new dir based on the current timestamp so they can be retrieved later
os.rename(imgPath, './images/' + str(int(time.time())))
# Restart the slideshow
input_state = True
