jcdocka
Python code not able to turn on GPIO
Sun Feb 02, 2020 3:46 am
Hello all,
I can turn my PI zero w GPIO pins on and off by using "gpio write 17 1", (using it to control a transistor that controls a relay, works perfectly fine), in my code though when I set it up by:
GPIO.setmode(GPIO.BOARD)
GPIO.setup(21, GPIO.OUT)
GPIO.output(21, GPIO.HIGH)
print(GPIO.input(21))
GPIO.output(21, 0)
GPIO.output(21, 1)
and i get the terminal output as:
1
0
1
But the gpio pin never picks the relay/never turns on.
Any ideas?
rpiMike
Re: Python code not able to turn on GPIO
Sun Feb 02, 2020 7:21 am
Add time.sleep(5) after each output statement.
jojopi
Sun Feb 02, 2020 8:22 am
Are you sure? The "gpio write" that I am familiar with is part of WiringPi, and it defaults to WiringPi numbering, unless you pass the -g or -1 options. But 17 in WiringPi numbering was on the extra P5 header, present only on some 26-pin Pies; it does not exist on the Zero.
Anyway, there is no combination of numberings where 17 would correspond to 21. Check that you really mean GPIO.BOARD, and pin 21.
ElEscalador
Sun Feb 02, 2020 2:28 pm
Without a delay (time.sleep(int)) it goes on then off so fast you can't see the light and the relay doesn't have enough time to physically move.
Robotics tips, hacks, book extras https://youtube.com/practicalrobotics
Return to “Python”
