r4v3r23
[SOLVED] GPIO help
Thu Jan 23, 2020 2:48 pm
so ive connected a button to GPIO 23 & GROUND and setup a python script to execute a shell script when button is pressed
problem is the button press isnt being recognized by the python script.
'sudo python xxxx.py' hangs terminal. heres a test script:
import RPi.GPIO as GPIO
import time
import os
GPIO.setmode(GPIO.BCM)
GPIO.setup(23, GPIO.IN)
while True:
    if GPIO.input(23):
        os.system("sudo shutdown -h now")
    prev_input = input
    time.sleep(0.05)
rpiMike
Re: GPIO help
Thu Jan 23, 2020 6:40 pm
Please edit your post and place your code in code tags.
You should not need 'sudo' before 'python'. Replace your os.system with a print statement until it works.
Add a photo of your wiring. (Many post image to imgur.com and link into post).
Are you sure you've got the correct pin?
https://pinout.xyz/pinout/pin16_gpio23
Burngate
Re: GPIO help
Thu Jan 23, 2020 6:41 pm
import time
import os
while True:
    if GPIO.input(23):
    prev_input = input
    time.sleep(0.05)
(put that in code tags for you, as the forum removes leading indents)
You haven't mentioned any pull-ups.
If there's no pull-up resistor in your circuit, and you've not enabled the internal pull-up, the GPIO will never rise.
r4v3r23
Re: GPIO help
Thu Jan 23, 2020 6:47 pm
import time
import os
while True:
    if GPIO.input(23):
    prev_input = input
    time.sleep(0.05)
heres another test scripts that gives me the same hanging result:
import time
import os
GPIO.setup(23, GPIO.IN, pull_up_down = GPIO.PUD_UP)
def Shutdown(channel):
GPIO.add_event_detect(23, GPIO.FALLING, callback = Shutdown, bouncetime = 2000)
while 1:
    time.sleep(1)
r4v3r23
Re: GPIO help
Thu Jan 23, 2020 6:49 pm
without sudo i get:
File "pi3.py", line 12, in <module>
GPIO.setup(7, GPIO.IN, pull_up_down = GPIO.PUD_UP)
RuntimeError: Not running on a RPi!
B.Goode
Re: GPIO help
Thu Jan 23, 2020 6:57 pm
Meaning it runs and awaits a button press which it never detects?
Where, specifically, is your button/switch connected?
(As already suggested, an in-focus photo might help... )
r4v3r23
Re: GPIO help
Thu Jan 23, 2020 7:14 pm
imgur.com/a/cjVf5PY
yes, it never detects the button press. here Ive moved it to Pin 18 to match this guide: https://www.element14.com/community/doc ... berry-pi-b
rpiMike
Re: GPIO help
Thu Jan 23, 2020 10:19 pm
If your pulling a GPIO input up, the input will normally be High and you need to test for Low:
import RPi.GPIO as GPIO,time,os
GPIO.setup(24, GPIO.IN, pull_up_down = GPIO.PUD_UP)
while True:
    if GPIO.input(24) == GPIO.LOW:
        print('pressed')
    time.sleep(0.05)
This tests fine for me.
python3 test.py
r4v3r23
Re: GPIO help
Thu Jan 23, 2020 10:44 pm
while True:
        print('pressed')
    time.sleep(0.05)
python3 test.py
$ python3 pi.py
File "pi.py", line 3, in <module>
GPIO.setup(18, GPIO.IN, pull_up_down = GPIO.PUD_UP)
sudo hangs (waits for button press)
joan
Re: GPIO help
Thu Jan 23, 2020 10:51 pm
You need to post the code you are running and the traceback.
The photo you posted seems to show a connection to pins 18 and 20 which are GPIO 24 and ground.
rpiMike
Re: GPIO help
Thu Jan 23, 2020 11:10 pm
while True:
        print('pressed')
    time.sleep(0.05)
python3 test.py
$ python3 pi.py
Try running my code. As joan mentioned physical pin 18 is BCM GPIO 24.
Is your Raspbian Buster fully updated?
r4v3r23
Re: GPIO help
Thu Jan 23, 2020 11:32 pm
while True:
        print('pressed')
    time.sleep(0.05)
python3 test.py
$ python3 pi.py
this is running your code. im running Manjaro Minimal & installed rpi-gpio packages
Re: GPIO help
Fri Jan 24, 2020 12:22 am
without sudo i get:
What model of Raspberry are you using? What OS? What version of RPi.GPIO?
r4v3r23
Re: GPIO help
Fri Jan 24, 2020 12:32 am
without sudo i get:
Raspberry 4 (4GB), Manjaro minimal, RPi.GPIO 0.7.0-1
Re: GPIO help
Fri Jan 24, 2020 12:51 am
RPi.GPIO is only supported on Raspbian. You'll need to pull the source package and hack it to work on your alien operating system.
r4v3r23
Re: GPIO help
Fri Jan 24, 2020 1:08 am
it already is maintained on manjaro
rpiMike
Re: GPIO help
Fri Jan 24, 2020 7:14 am
$ python3 pi.py
From the error message it looks like you changed 24 to 18. Do you understand the difference between physical pin numbers (BOARD) and BCM GPIO pin numbers. https://pinout.xyz/
r4v3r23
Re: GPIO help
Fri Jan 24, 2020 12:12 pm
changed to 24, get this output:
pressed
pressed
pressed
pressed
pressed
ad nauseum
B.Goode
Re: GPIO help
Fri Jan 24, 2020 12:19 pm
A suggestion for diagnostic/troubleshooting purposes -
Do you get the same results if you run the Raspberry Pi recommended Raspbian Operating System on your RPi board?
(Not saying your choice of Operating System is wrong, but Raspbian is probably the OS used by most volunteer helpers in these forums, and this will ensure that advice us relevant and accurate.)
rpiMike
Re: GPIO help
Fri Jan 24, 2020 12:42 pm
pressed
pressed
pressed
pressed
pressed
ad nauseum
Is that with your button connected between GPIO24 and Ground? Is your button push-to-close or push-to-open? As others have mentioned I suggest you use Raspbian Buster.
joan
Re: GPIO help
Fri Jan 24, 2020 12:49 pm
We don't know what code is being used. We don't know how the switch is connected. The question is pointless.
r4v3r23
Re: GPIO help
Fri Jan 24, 2020 12:59 pm
pressed
pressed
pressed
pressed
pressed
ad nauseum
yes GPIO24 (red) & Ground (black) as per this pic: https://imgur.com/a/cjVf5PY
how should the script be responding?
cant use raspian buster this has to work on manjaro
r4v3r23
Re: GPIO help
Fri Jan 24, 2020 1:06 pm
both a photo of the connection & the code used are in this thread
davidcoton
Re: GPIO help
Fri Jan 24, 2020 1:38 pm
Get it saying "Pressed" repeatedly. Then press and hold the button. Any change?
Signature retired
r4v3r23
Re: GPIO help
Fri Jan 24, 2020 2:01 pm
No change it keeps printing "pressed"
Return to “Python”
