johnmosquerav
HELP WITH Two stepper motors at same time
Tue Jan 14, 2020 4:13 am
I am triying do control of two stepper motor with drive HB808C, when I do control for only one, this is fine, however, when I do control with two stepper motors, the program in python don´t work correctly.
The principal idea is do control for 4 stepper motor at same time.
This is the main program:
import threading
import random
import time
from servo2 import servo1
from servo3 import servo2
# how many threads we want to start
THREADS = { 'task1':2 , 'task2':3, 'task3':2}
def task1(threadName):
 servo1()
def task2(threadName):
    servo2()
    print ("TEST")
def task3(threadName):
    while True:
        print "I am %s and I execute task3" % threadName
        time.sleep(0.5)
def generic_workflow(threadName, task_type):
    if task_type == 'task1':
        task1(threadName)
    elif task_type == 'task2':
        task2(threadName)
    elif task_type == 'task3':
        task3(threadName)
class Thread_task(threading.Thread):
    def __init__(self, task_type):
        threading.Thread.__init__(self)
        self.task_type = task_type
    def run(self):
        threadName = threading.currentThread().getName()
print 'Checking for threads for every task...'
total_threads = 0
for task in THREADS:
    total_threads += THREADS[task]
    print " ** Starting %d threads for %s **" % (THREADS[task], task)
    for i in range(THREADS[task]):
        task_type = task
        td = Thread_task(task)
        td.start()
Theese are the servo1 and servo2 program:
def servo1():
 import RPi.GPIO as GPIO
 import time
 GPIO.setmode(GPIO.BCM)
 GPIO.setup(21, GPIO.OUT)
 GPIO.setup(16,GPIO.OUT)
 limite=250
 frecuencia=(0.0001)
 def movi1 ():
  GPIO.output(21,True)
  time.sleep(frecuencia)
  GPIO.output(21, False)
 def outOn1():
  GPIO.output(16,True)
 def outOff1():
  GPIO.output(16,False)
 while True:
  for i in range(limite+1):
   movi1()
   print (i)
  outOn1()
  time.sleep(0.5)
  for j in range(limite+1):
   movi1()
   print (j)
  outOff1()
  time.sleep(0.5)
def servo2():
 import time
 GPIO.setup(20,GPIO.OUT)
 GPIO.setup(12,GPIO.OUT)
 limite=250
 frecuencia=(0.0001)
 def movi1 ():
  GPIO.output(20,True)
  GPIO.output(20, False)
 def outOn1():
  GPIO.output(12,True)
 def outOff1():
  GPIO.output(12,False)
 while True:
   movi1()
   print (i)
  outOn1()
  time.sleep(0.5)
   movi1()
   print (j)
  outOff1()
  time.sleep(0.5)
pootle
Re: HELP WITH Two stepper motors at same time
Wed Jan 15, 2020 8:36 am
it's hard to follow your code when all the indentation is lost, You're starting in the right place with threading though. Can you post the code with indentation present.....?
pcmanbob
Wed Jan 15, 2020 11:39 am
import threading
import random
import time
 servo1()
    servo2()
    print ("TEST")
    while True:
        time.sleep(0.5)
        task1(threadName)
        task2(threadName)
        task3(threadName)
    def run(self):
total_threads = 0
        task_type = task
        td.start()
def servo1():
 import time
 limite=250
 frecuencia=(0.0001)
 def movi1 ():
 def outOn1():
 def outOff1():
 while True:
   movi1()
   print (i)
  outOn1()
  time.sleep(0.5)
   movi1()
   print (j)
  outOff1()
  time.sleep(0.5)
def servo2():
 import time
 limite=250
 frecuencia=(0.0001)
 def movi1 ():
 def outOn1():
 def outOff1():
 while True:
   movi1()
   print (i)
  outOn1()
  time.sleep(0.5)
   movi1()
   print (j)
  outOff1()
  time.sleep(0.5)
Have quoted original post and added code tags.
johnmosquerav when using code tags you need to put the code between the tages
Add [code] at the top
code goes here
and [/code] at the bottom.
johnmosquerav
Fri Jan 17, 2020 7:21 pm
Thanks, I do the change in the post, now your can understand better, thanks, I will attend to news response.
Return to “Python”
