ankith26
Good python IDE for raspberry pi
Thu Jan 09, 2020 11:34 am
I need some recommendations as to which IDE must I use on my raspberry pi. IDLE is enough for simple projects.
I am currently working on a good python project and realised that idle was not enough so I had to use thonny.
Thonny is good but are there any better options as I am not fully satisfied.
I want an IDE with good GUI and good features and it should not lag much on my pi.
If you have any choices for any general IDE(not only for the pi) then do let me know.
I sat thinking for 5 minutes on what to put here. Finally I put something like this.
Check out my github page @ https://github.com/ankith26
aivarannamaa
Re: Good python IDE for raspberry pi
Thu Jan 09, 2020 6:28 pm
Which are the main features you miss in Thonny?
apurva_v8
Mu or PyCharm
Thu Jan 09, 2020 6:29 pm
Hello there,
As you're interested in python. Python has 2 parts. If you want to code for robotics. Such as for Motors, display, controllers, etc. I would suggest you "mu" if you wanna do robotics stuff. The advantage of mu is that it's a lightweight IDE. You can install Eclipse on your RPI but that's heavy and I have experienced crashes.2nd part is that if you want to code UI or software part. you can use PyCharm.
If you want to code on raspbian I would suggest you mu, on other x64 systems like windows you can use PyCharm. But Windows doesn't come with some preinstalled libraries like GPIO control and stuff. So you will need to add them. Plus I would prefer an RPI to code as you can experiment a lot with GPIO. If you're into robotics.
Let me know your thoughts. Or reply to this if you need more information. :ugeek:
I hope my reply helps you in some way.
Apurva
  • Embedded Engineer
ankith26
Fri Jan 10, 2020 8:50 am
Thanks for the replies.
Thonny is good, but I am not a big fan of its GUI.
I am going for something that looks cool and has good functionalities.
I would want a good easy to use debugger and a panel where I can see the file system of the directory and open the required files simultaneously.
And currently I am not into robotics with pi(I use arduino for that)
I would want to code on my pi, therefore I want something that is light or moderately light
aivarannamaa
Fri Jan 10, 2020 11:27 am
Did you try Thonny's debuggers (Ctrl+F5 and Shift+F5)? Were you using only simple (default) mode, or also regular mode?
In regular mode you can show file browser (View => Files).
Best regards,
Aivar
ankith26
Fri Jan 10, 2020 1:12 pm
Nope, not yet. I generally do not need debugging. Sometimes I just use print statements all over and it solves my problem.
sibir
Thu Feb 13, 2020 4:22 pm
I have been using Thonny for a while and really like it.
I love the multi-platform support as I am switching between Win10, macOS, and RPi all the time.
Now that my projects are getting bigger the feature I miss most are collapsible function definitions to save screen real estate and reduce scrolling.
Keep it up, Aivar!
ankith26
Fri Feb 14, 2020 2:35 am
Hmm..
Thonny is very good really.
But the only thing I miss is the dark mode.
After using thonny for a while I have noticed that it has all the features I need.
aivarannamaa
Fri Feb 14, 2020 5:40 am
Thonny has dark mode (Tools => Options => Fonts & Themes). If you don't see the menu bar, you need to switch from simple mode to regular mode first (see upper-right corner of the window).
ankith26
Fri Feb 14, 2020 6:13 am
Oh I never realised that.
I’m gonna test it today.
Thonny is nice, I have got used to it now.
Return to “Python”
