picandies
installing latest meld
Sat Jan 04, 2020 8:39 pm
How do you get the latest version of meld installed on the rpi (what are the proper commands/steps)?
https://meldmerge.org
using apt-get install meld installs a rather old version (3.16) instead of the current 3.20
pip3 seems to fail with a screen load of errors.
klricks
Re: installing latest meld
Sat Jan 04, 2020 10:16 pm
Raspbian (Debian) is not a 'rolling' type distribution. Instead they use a tested stable philosophy which means that package versions are locked and do not change until the next major release (except for security updates). Major releases are approximately every 2 years.
So either wait for the next release "Bullseye" or obtain the source code and compile yourself.
picandies
Sat Jan 04, 2020 11:29 pm
I have the "tar" file.. .what are the step/commands you are referring to to perform the compile/install?
ghp
Mon Jan 06, 2020 10:40 am
There is a development page in the meld home page
https://meldmerge.org/development.html
According to these descriptions, this should be simple. I tried it here (get from git, run python code) but found various problems with the availability of supporting libraries.
picandies
Tue Jan 07, 2020 12:09 am
So you couldn't get it to install? I was wondering if I was doing it wrong..sounds like the program isn't ready to use, or their new install is buggy.
Return to “Python”
