Paulon8080
Outputting text to centre of screen?
Tue Dec 17, 2019 6:59 pm
Hi everybody,
I'm not sure if this is the right place to post this, apologies if not.
I have a python script that outputs text (line by line) to the command line with a typewriter effect.
I am just wondering if it is possible to output the text to the centre of the page and not aligned left?
Thanks!
hippy
Re: Outputting text to centre of screen?
Tue Dec 17, 2019 8:09 pm
You should be able to send ASCII Escape Codes to position where text will be written to, so, knowing the number of characters on a line, how long your line of text is, you should able to determine the right Escape Code to send.
An easier and quicker alternative is to pad the string with leading spaces ...
COLUMNS = 80
text = "This is a line of centred text"
padding = " " * (( COLUMNS - len(text)) // 2)
print(padding + text)
billintad
Wed Dec 18, 2019 8:01 am
Python has a string function to centre text :
>>> # string.center(width,fillCharacter)
>>> print('asdfghjk'.center(80,"-"))
------------------------------------asdfghjk------------------------------------
A space is the default if the fill character is not defined. Here is a useful list of String functions https://www.programiz.com/python-progra ... ods/string .
joelostinspace
Wed Dec 18, 2019 2:27 pm
one more way-
>>> "{:*^70}".format('hello world')
output:
'*****************************hello world******************************'
I would rather live in a world where my life is surrounded by mystery than a world so small that my mind could comprehend it.
--- Harry Emerson Fosdick
MarkDH102
Thu Dec 19, 2019 7:15 am
Or you could investigate the 'curses' library...
Return to “Python”
