sanpaulus
Python script automatic start
Sat Dec 07, 2019 1:28 pm
Hello people,
i need help. I have a python script, located on an USB-stick, the path looks like: /media/pi/USBstick/Data
it needs to starts automaticly AFTER the pi boots up completly.
my script looks like this:
#!/usr/bin/python3
import csv
import time
import datetime
import serial
import urllib.request
import sys
import RPi.GPIO as GPIO
SerialIn = serial.Serial("/dev/ttyUSB0",9600)
tvocURL = 'http://api.thingspeak.com/update?api_key=ZD8WW20D5ZD9WXXX&field1='
eco2URL = 'http://api.thingspeak.com/update?api_key=ZD8WW20D5ZD9WXXX&field2='
with open("sensor.csv", "w") as csvfile:
    sensorwriter = csv.writer(csvfile)
    sensorwriter.writerow(["datetime", "field1", "field2"])
    while True:
        temp = SerialIn.readline()
        temp = temp.decode('utf-8').strip().split(',')
        f = urllib.request.urlopen(tvocURL +str(temp[0]))
        f.read()
        g = urllib.request.urlopen(eco2URL +str(temp[1]))
        g.read()
        time_now = datetime.datetime.now()
        sensorwriter.writerow([time_now, temp[0], temp[1]])
        print("{0},{1},{2}". format(time_now, temp[0], temp[1]))
f.close()
g.close()
time.sleep(15)
Many epic fails happend when i tried different methods and to end my suffering i am seeking help now in this forum.
klricks
Re: Python script automatic start
Sat Dec 07, 2019 3:36 pm
If booting to desktop then use autostart:
/etc/xdg/lxsession/LXDE-pi/autostart
You must specify the complete path when calling your script.
Also you must specify the complete path when opening any files within your script.
sanpaulus
Mon Dec 09, 2019 10:22 am
thank you for the answer.
i found a tutorial describing what you just meant:
https://www.raspberrypi-spy.co.uk/2014/ ... e-desktop/
i tried to run leafpad at autostart. it worked, but my pi isn't booting up now anymore. no desktop. just a black screen.
thagrol
Mon Dec 09, 2019 1:17 pm
Autostart may not be the correct solution.
As I understand it, anything run that way will only run after login through the gui and will run on every login through the GUI. So if you login locally and via VNC you'll get two copies running. You script will probably get killed on logout too.
To run something after boot use one of the following methods:
  • cron. Via an @reboot cron job. See
    man cron
  • /etc/rc.local
  • A systemd service
Each method has advantages and disadvantages so you'll need to do some reading before you decide which to use.
As for your black screen issue, I'ev no idea. The fix is probably to undo your changes. One way to do that is to get a second SD card with a clean OS, boot from that then mount the "broken" card via a USB card reader. You should then be able to undo the changes.
Arguing with strangers on the internet since 1993.
klricks
Mon Dec 09, 2019 2:24 pm
Your autostart file must contain these 2 lines:
@lxpanel --profile LXDE-pi
@pcmanfm --desktop --profile LXDE-pi
Right click on the blank screen and select terminal. You should then be able to edit autostart and add those commands.
The tutorial was wrong as it did not show those commands present in method 2.
sanpaulus
Mon Dec 09, 2019 6:58 pm
thanks you for helping me! My pi is back to normal conditions.
did the job.
but the autostart-issue is still not solved.
Tried to get a solution with
crontab -e
directly tipped in the terminal
than simply scrolled down to the bottom and added the line
@reboot python3 /home/pi/myscript.py
but nothing at all happens at reboot... what is going on?
klricks
Mon Dec 09, 2019 7:19 pm
Did you edit your file and add the complete path to sensor.csv?
thagrol
Mon Dec 09, 2019 7:40 pm
crontab -e
Are you sure nothing at all is happening at reboot? Your script will be started as a background task with no connection to a terminal so all output will be lost.
ps aux | grep myscript.py
will show the process informatiom if you script is running. If it shows nothing, your script either didn't start or exited shortly after starting.
Either way, try changing you crontab entry to the one below, rebooting then looking at the contents of /tmp/myscript.log
@reboot python3 /home/pi/myscript.py >/tmp/myscript.log 2>&1
sanpaulus
Mon Dec 09, 2019 9:21 pm
tried that to check if the script is running. once while the script is running, and to compare once without running my script.
so yeah, the
 crontab -e @reboot python3 /home/pi/myscript.py
is not starting my script when rebooting.
also i tried
but that's not making any difference at all...
thagrol
Tue Dec 10, 2019 12:26 am
so yeah, the
also i tried
Some questions and sugestions:
  1. Was there anything in the log file?
  2. Did cron send your user any emails? Or write anything to syslog?
  3. Is your script actually called "myscript.py"? If not and you ran the ps & grep command I suggested it wouldn't have been found. Try this instead:
    ps aux | more
    Read through the output looking for your script. Or replace "myscript.py" with the actual script name in my original suggestion.
  4. Was that crontab for the same user that owns the file (presumably pi)? If not, check that permissions on the file, the directory containing it and any files it needs access to allow at least reading and if necessary writing by all users.
  5. Try adding the full path to python3 to your crontab entry. If you don't know it, this will tell you:
    which python3
  6. Check whether cron is working, add (replace "pi" if required):
    @reboot echo "crontest" > /home/pi/crontest.out
  7. What's the output of
    systemctl status cron
Without capturing the output and errors from cron and/or your script there isn't a lot more I can suggest.
sanpaulus
Tue Dec 10, 2019 4:11 pm
The log file had something in it:
File "/home/pi/Uhrzeit.py", line 3, in <module>
window = tkinter.Tk()
File "/usr/lib/python3.5/tkinter/__init__.py", line 1880, in __init__
self.tk = _tkinter.create(screenName, baseName, className, interactive, wantobjects, useTk, sync, use)
_tkinter.TclError: no display name and no $DISPLAY environment variable
well, the "Crontest" did work :)
the output of
is this:
● cron.service - Regular background program processing daemon
Loaded: loaded (/lib/systemd/system/cron.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2019-12-10 16:58:17 CET; 8min ago
Docs: man:cron(8)
Main PID: 398 (cron)
CPU: 671ms
CGroup: /system.slice/cron.service
└─398 /usr/sbin/cron -f
Dec 10 16:58:17 raspberrypi cron[398]: (CRON) INFO (Running @reboot jobs)
Dec 10 16:58:17 raspberrypi CRON[402]: pam_unix(cron:session): session opened for user pi by (uid=0)
Dec 10 16:58:17 raspberrypi CRON[401]: pam_unix(cron:session): session opened for user pi by (uid=0)
Dec 10 16:58:17 raspberrypi CRON[403]: pam_unix(cron:session): session opened for user root by (uid=0)
Dec 10 16:58:17 raspberrypi CRON[424]: (pi) CMD (/usr/bin/python3 /home/pi/Uhrzeit.py >/tmp/Uhrzeit.log 2>&1)
Dec 10 16:58:17 raspberrypi CRON[423]: (pi) CMD (echo "crontest" > /home/pi/crontest.out)
Dec 10 16:58:17 raspberrypi CRON[425]: (root) CMD (sh /media/pi/WININSTALL/Sensor_Daten/launcher.sh >/home/pi/logs/cronlogs 2>&1)
Dec 10 16:58:17 raspberrypi CRON[402]: pam_unix(cron:session): session closed for user pi
Dec 10 16:58:17 raspberrypi CRON[403]: pam_unix(cron:session): session closed for user root
Dec 10 16:58:19 raspberrypi CRON[401]: pam_unix(cron:session): session closed for user pi
thagrol
Tue Dec 10, 2019 4:40 pm
I don't think that's from the same code that you first asked about.
The presence of calls to tkinter and the error message indicates that your code requires a running desktop (or at least an X11 server). Given that, cron is not the way to start it:
  • @reboot cron jobs run before the desktop has started
  • Cron jobs run in a reduced envirnoment, as such even if a desktop is running they won't know anything about it.
  • Even if a desktop has started and you tell your code about it, it still won't work. The default security setting for the raspbian desktop is to reject all connections except those made from within the current desktop session..
You've got basically two options:
  1. Go back to autostart. Can't help with that as I don't sue it.
  2. Remove the security on your desktop then change your crontab entry to something like this:
    @reboot sleep 30 && export DISPLAY=localhost:0 && python3 /home/pi/myscript.py
    The downside of this approach is that it will always start on the same display (in this example the console/directly attached display), and that any user on your Pi can start stuff on your display.
sanpaulus
Tue Dec 10, 2019 9:34 pm
here's what cronlog said after i tried the code from the begining:
2019-12-10 22:23:37.243580,0,400
2019-12-10 22:23:38.150592,0,400
2019-12-10 22:23:39.228499,0,400
File "/usr/lib/python3.5/urllib/request.py", line 1254, in do_open
h.request(req.get_method(), req.selector, req.data, headers)
File "/usr/lib/python3.5/http/client.py", line 1107, in request
self._send_request(method, url, body, headers)
File "/usr/lib/python3.5/http/client.py", line 1152, in _send_request
self.endheaders(body)
File "/usr/lib/python3.5/http/client.py", line 1103, in endheaders
self._send_output(message_body)
File "/usr/lib/python3.5/http/client.py", line 934, in _send_output
self.send(msg)
File "/usr/lib/python3.5/http/client.py", line 877, in send
self.connect()
File "/usr/lib/python3.5/http/client.py", line 849, in connect
(self.host,self.port), self.timeout, self.source_address)
File "/usr/lib/python3.5/socket.py", line 694, in create_connection
for res in getaddrinfo(host, port, 0, SOCK_STREAM):
File "/usr/lib/python3.5/socket.py", line 733, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Temporary failure in name resolution
During handling of the above exception, another exception occurred:
File "/media/pi/WININSTALL/Sensor_Daten/SGP30_bulk_upload.py", line 21, in <module>
File "/usr/lib/python3.5/urllib/request.py", line 163, in urlopen
return opener.open(url, data, timeout)
File "/usr/lib/python3.5/urllib/request.py", line 466, in open
response = self._open(req, data)
File "/usr/lib/python3.5/urllib/request.py", line 484, in _open
'_open', req)
File "/usr/lib/python3.5/urllib/request.py", line 444, in _call_chain
result = func(*args)
File "/usr/lib/python3.5/urllib/request.py", line 1282, in http_open
return self.do_open(http.client.HTTPConnection, req)
File "/usr/lib/python3.5/urllib/request.py", line 1256, in do_open
raise URLError(err)
urllib.error.URLError: <urlopen error [Errno -3] Temporary failure in name resolution>
the first 3 rows just worked!!! Even "Thingspeak" reacted and plotted the data... now i have to find out why it's crashing after 3 rows... and it feels uncomfortable not to see anything whats going on with the process... Isn't there a way to see the whole thing in the terminal?
sanpaulus
Tue Dec 10, 2019 9:51 pm
Changed the sleep to 180 to make sure wifi conection is build up before the script starts.
It works now! problem SOLVED
Thank you guys so much
GlowInTheDark
Tue Dec 10, 2019 10:30 pm
I wonder why you have "localhost" in there.
The way I handle this problem is to go to a terminal window on the desktop and do:
$ echo $DISPLAY
:0.0
So, now I know what the right value for DISPLAY is. I set that in my "foreign" job (e.g., a cron entry) and it works as expected. Notice that this form of DISPLAY does not have any hostname in it.
Using localhost:0 means that it goes through TCP/IP to get to the X desktop. This form of access is disabled by default (for many years if not decades now). You need to go through some hoops to re-enable TCP/IP access to the X desktop. I'm curious how it is that you got it to work that way. Seriously, I'm curious; I'm not just snarking.
Reference:
If you do a long form ps on the Xorg process, it will look something like:
root 727 21.0 3.1 221692 29608 tty7 Ssl+ Nov23 5262:04 /usr/lib/xorg/Xorg :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
Notice the "-nolisten tcp" option in there.
GitD's list of things that are not ready for prime time:
1) IPv6
2) 64 bit OSes
3) USB 3
4) Bluetooth
Loves Linux; loves to dance.
thagrol
Tue Dec 10, 2019 11:14 pm
Probably because that's what I gave the OP in my suggestions. I suspect that the script that's now working doesn't care what $DISPLAY is set to as it doesn't use it (see the original post) and it can be removed from that crontab entry.
You are correct that X secutiry settings would prevet that but if you refer to my previous postings you'll see that I'd already mentioned this.
For the OP's script that needs tkinter, the optimal solution (as I pointed out here: https://www.raspberrypi.org/forums/view ... 9#p1578798) is not cron, it's autostart.
Return to “Python”
