RND_pi
array's confusion
Mon Nov 18, 2019 10:34 am
Hello everyone
B.Goode
Re: array's confusion
Mon Nov 18, 2019 10:51 am
It looks as though you have a generic problem with your understanding of the Python programming language, rather than anything specific to the Raspberry Pi.
Your problem may stem from the fact that you are creating a Python list but calling it 'array'.
Strictly speaking, Python does not have built in support for an array as a data type.
See, for example: https://www.w3schools.com/python/python_arrays.asp
gordon77
Mon Nov 18, 2019 1:56 pm
I am not entirely sure what you are trying to get but here's an example..which will give an output like addr0:FYURJANUARY
import serial
rx_data = []
addrs = [b'\x00',b'\x01',b'\x02',b'\x03',b'\x04',b'\x05',b'\x06',b'\x07',b'\x08',b'\x09',b'\x0A',b'\x0B',b'\x0C',b'\x0D']
start = b'\xb2'
Stop  = b'\xA3'
stop  = b'\xa3'
ser = serial.Serial("/dev/ttyS0")
ser.baudrate = 1200
while True:
    rxd_bytes = ser.read()
    rx_data.append(rxd_bytes)
    # check for end
    if rxd_bytes == stop:
        # check valid
        if rx_data[0] == start and (rx_data[14] == stop or rx_data[14] == Stop):
            Data_out = ""
            # check address
            for x in range(0,14):
                if(rx_data[1] == addrs[x]):
                    address = "addr" + str(x)
                    Data_out +=address + ":"
            # decode data
            for x in range(2,13):
                Data = rx_data[x].decode("ascii","ignore")
                Data_out += Data
            print (Data_out)
ser.close()
billio
Mon Nov 18, 2019 7:22 pm
I am not sure exactly what you want but your array contains python "bytes" which are kind of a "type of string", that's why when you print them some appear as hex numbers and some appear as letters. Using Python3 these are two ways you can convert the bytes to hexadecimal numbers as strings or as integers :
>>>a = [b'\xb2', b'\x00', b'F', b'Y', b'U', b'R', b'J', b'A', b'N', b'U', b'A', b'R', b'Y', b' ', b'\xa3']
>>>b = [b'\xb2', b'\x01', b'F', b'R', b'I', b' ', b' ', b'W', b'A', b'W', b'A', b'L', b' ', b' ', b'\xa3']
>>>c = [b'\xb2', b'\x02', b'?', b'6', b'4', b'5', b'?', b'3', b'4', b'5', b'?', b'4', b'1', b'7', b'\xa3']
>>> b"".join(a) # if you want to see the text, \xnn for bytes that are not text characters
b'\xb2\x00FYURJANUARY \xa3'
>>> b"".join(b)
b'\xb2\x01FRI  WAWAL  \xa3'
>>> b"".join(c)
b'\xb2\x02?645?345?417\xa3'
Let us know if you need more ...
RND_pi
Tue Nov 19, 2019 6:15 am
Thanks for the help
RND_pi
Tue Nov 19, 2019 10:13 am
another help would required on rs485. im getting data from rs485 and the data im getting received is continuous and byte by byte and the order of the data im receiving is random like any address is coming on my pyshell. my concern is that how should i store the incoming data and then parse the data according to the addresses which i've posted in the above.
thanks in advance
gordon77
Tue Nov 19, 2019 1:18 pm
Try this..
I have it working on data from an Arduino. Note I can't find a way to detect \x00 as python seems to see it as a control and filter it out, so it assumes if no valid address found it must be 00.
It starts by finding address 00 (no address!) and ends with address 0D, then repeats. It can cope with addresses out of order BUT if 00 isn't the start and 0D the end you won't get a full set.
For RS485 I believe you will need a RS485 HAT.
#!/usr/bin/python3
import tkinter as tk
import serial
import os
import time
class MainApplication(tk.Frame):
    def __init__(self, master):
        self.master = master
        tk.Frame.__init__(self, self.master)
        self.dataure_gui()
        self.create_widgets()
        self.start_serial()
        self.rx_data()
    def dataure_gui(self):
        self.master.title('Data Input Form')
        self.master.geometry('300x400')
        self.master.resizable(0, 0)
    def create_widgets(self):
        self.create_frames()
        self.create_entries()
        self.create_labels()
    def create_frames(self):
        self.Frame10 = tk.Frame(width=300, height=400)
        self.Frame10.grid_propagate(0)
        self.Frame10.grid(row=0, column=0)
    def create_entries(self):
        global E0,E1,E2,E3,E4,E5,E6,E7,E8,E9,E10,E11,E12,E13
        E0=tk.Label(self.Frame10, height=1, width=20, bg = "white")
        E1=tk.Label(self.Frame10, height=1, width=20, bg = "white")
        E2=tk.Label(self.Frame10, height=1, width=20, bg = "white")
        E3=tk.Label(self.Frame10, height=1, width=20, bg = "white")
        E4=tk.Label(self.Frame10, height=1, width=20, bg = "white")
        E5=tk.Label(self.Frame10, height=1, width=20, bg = "white")
        E6=tk.Label(self.Frame10, height=1, width=20, bg = "white")
        E7=tk.Label(self.Frame10, height=1, width=20, bg = "white")
        E8=tk.Label(self.Frame10, height=1, width=20, bg = "white")
        E9=tk.Label(self.Frame10, height=1, width=20, bg = "white")
        E10=tk.Label(self.Frame10, height=1, width=20, bg = "white")
        E11=tk.Label(self.Frame10, height=1, width=20, bg = "white")
        E12=tk.Label(self.Frame10, height=1, width=20, bg = "white")
        E13=tk.Label(self.Frame10, height=1, width=20, bg = "white")
        self.keys = [E0,E1,E2,E3,E4,E5,E6,E7,E8,E9,E10,E11,E12,E13]
        for a in range(0,14):
            self.keys[a].place(x=100, y= (a * 25) + 25)
    def create_labels(self):
        L1 = tk.Label(self.Frame10, text="addr00 :" , font = 30)
        L2 = tk.Label(self.Frame10, text="addr01 :" , font = 30)
        L3 = tk.Label(self.Frame10, text="addr02:" , font = 30)
        L4 = tk.Label(self.Frame10, text="addr03 :" , font = 30)
        L5 = tk.Label(self.Frame10, text="addr04 :" , font = 30)
        L6 = tk.Label(self.Frame10, text="addr05 :" , font = 30)
        L7 = tk.Label(self.Frame10, text="addr06:" , font = 30)
        L8 = tk.Label(self.Frame10, text="addr07 :" , font = 30)
        L9 = tk.Label(self.Frame10, text="addr08 :" , font = 30)
        L10 = tk.Label(self.Frame10, text="addr09 :" , font = 30)
        L11 = tk.Label(self.Frame10, text="addr10:" , font = 30)
        L12 = tk.Label(self.Frame10, text="addr11 :" , font = 30)
        L13 = tk.Label(self.Frame10, text="addr12 :" , font = 30)
        L14 = tk.Label(self.Frame10, text="addr13 :" , font = 30)
        labels = [L1,L2,L3,L4,L5,L6,L7,L8,L9,L10,L11,L12,L13,L14]
            labels[a].place(x=20, y= (a * 25) + 25)
    def start_serial(self):
        global out_array,addrs,keys,start_stop
        # setup serial
        self.ser = serial.Serial(port="/dev/ttyS0",baudrate = 1200)
        # define data
        out_array = ['0','0','0','0','0','0','0','0','0','0','0','0','0','0']
        start_stop = [b'\xb2',b'\xa3']
    def rx_data(self):
        # define variables
        array = []
        begin = 0
        end = 0
        # start receiving and wait for 00 address (no address!)
        while begin == 0:
            rxd_bytes = self.ser.read()
            while rxd_bytes != start_stop[0]:
            array = []
            array.append(rxd_bytes)
            while rxd_bytes != start_stop[1] :
            if array[1] not in addrs:
                begin = 1
        Data_out = ""
        Data_out += array[1].decode("ascii","ignore")
        # parse data
        for x in range(2,len(array)):
            Data = array[x].decode("ascii","ignore")
            Data_out += Data
        # put in out_array
        out_array[0] = Data_out
        array = []
        # continue receiving until the next b'\x0D' address.
        while end == 0:
            Data_out = ""
            # determine address
            address = 0
                if(array[1] == addrs[x]):
                    address = x
            if address == 0:
            # parse data
                Data_out += Data
            # put in out_array
            out_array[address] = Data_out
            # end
            if array[1] == addrs[13]:
                end = 1
            array = []
        # place on tkinter form from out_array
        self.update_form()
        self.after(1, self.rx_data)
    def update_form(self):
        global out_array
        for x in range(0,len(out_array)):
            self.keys[x].config(text = out_array[x])
if __name__ == '__main__':
    root = tk.Tk()
    main_app =  MainApplication(root)
    root.mainloop()
RND_pi
Fri Nov 22, 2019 6:26 am
any idea how i can add this address
b'\x01
into configuration file ?
I've try using
#b2
but it didn't work.
thanks in advance
gordon77
Fri Nov 22, 2019 8:18 am
b'\x01
I've try using
#b2
but it didn't work.
thanks in advance
Sorry l don't understand what you mean. b'\x01' is in the list of addresses.
RND_pi
Mon Dec 02, 2019 7:25 am
I need to add b'\x01' and b'\xb2' these 2 commands in my config.ini file.
but when im trying to do so im not able to read. any suggestions how should i add these 2 files in config file
Return to “Python”
