Conversion
Posted: Sat Nov 09, 2019 6:34 am
by California
Hello, I am facing with mooving some code from python 2 to python 3. Code below works just ok in python 2 but not in python 3.
So your help would be very appreciated.
import struct
def convert_long_to_bytes(i):
    i = i % 4294967296
    n4 = i % 256
    i = i / 256
    n3 = i % 256
    i = i / 256
    n2 = i % 256
    n1 = i / 256
    return (n1, n2, n3, n4)
def convert_float_to_MICROCHIP_32bit(x):
    print ("x", x)
    x_IEEE = struct.pack(">f", x).encode("hex")
    print ("x_IEEE", x_IEEE)
    bits = bin(int(x_IEEE, 16))[2:].zfill(len(x_IEEE) * 4)
    i = 0
    val = list("                                ")
    b_s = bytearray(val)
    for char in bits:
        current_bit = int(char)
        if current_bit == 1:
            if (i > 0) and (i < 9):
                b_s[i - 1] = "1"
            elif i == 0:
                b_s[8] = "1"
            else:
                b_s[i] = "1"
        else:
                b_s[i - 1] = "0"
            elif i == 0:
                b_s[8] = "0"
            else:
                b_s[i] = "0"
        i = i + 1
    bin_val = str(b_s)
    print ("bin_val", bin_val)
    hex_val = int(bin_val, 2)
    print ("hex_val", hex_val)
    bytes_val = convert_long_to_bytes(hex_val)
    print ("bytes_val", bytes_val)
    return bytes_val
a = 987654321.123456789  #-987654321.123456789  #0.0  #-5.1  #5.1
b = convert_float_to_MICROCHIP_32bit(a)
print b
Thanks in advance,
Regards, Vlado
Re: Conversion
Posted: Sat Nov 09, 2019 7:31 am
by jahboater
You may need // instead of / for integer division.
Re: Conversion
Posted: Sat Nov 09, 2019 8:18 am
by California
the first error is:
  File "/home/pi/Desktop/convert_float_to_MICROCHIP_32bit_py27.py", line 47, in <module>
  File "/home/pi/Desktop/convert_float_to_MICROCHIP_32bit_py27.py", line 15, in convert_float_to_MICROCHIP_32bit
AttributeError: 'bytes' object has no attribute 'encode'
Re: Conversion
Posted: Sat Nov 09, 2019 10:33 am
by billio
I think you need
struct.pack(">f", x).hex()
as described here https://docs.python.org/3/library/stdtypes.html
The type 'bytes' does not have an encode() function in python3.
Re: Conversion
Posted: Sat Nov 09, 2019 12:24 pm
by California
Thanks for your answer, it alows me to go forward through the code execution - almost to the end.
Code looks now:
import struct
    i = i % 4294967296
    n4 = i % 256
    i = i / 256
    n3 = i % 256
    i = i / 256
    n2 = i % 256
    n1 = i / 256
    x_IEEE = struct.pack(">f", x).hex()
    i = 0
    val = "                                ".encode()
    b_s = list(val)
    for char in bits:
                b_s[i - 1] = "1"
            elif i == 0:
                b_s[8] = "1"
            else:
                b_s[i] = "1"
        else:
                b_s[i - 1] = "0"
            elif i == 0:
                b_s[8] = "0"
            else:
                b_s[i] = "0"
        i = i + 1
    bin_val = [int(i) for i in b_s]
    out = 0
    for bit in bin_val:
        out = (out << 1) | bit
    hex_val = hex(out)
    return bytes_val
a = 5.1 #987654321.123456789  #-987654321.123456789  #0.0  #-5.1
print (b)
and the last error message:
  File "/home/pi/Desktop/convert_float_to_MICROCHIP_32bit_py34.py", line 45, in <module>
  File "/home/pi/Desktop/convert_float_to_MICROCHIP_32bit_py34.py", line 41, in convert_float_to_MICROCHIP_32bit
  File "/home/pi/Desktop/convert_float_to_MICROCHIP_32bit_py34.py", line 4, in convert_long_to_bytes
    i = i % 4294967296
TypeError: not all arguments converted during string formatting
Re: Conversion
Posted: Sat Nov 09, 2019 1:54 pm
by B.Goode
I can't solve it, but can refer you to the likely cause:
In addition to performing the modulo operation on numbers, the % operator is also overloaded by string and unicode objects to perform string formatting (also known as interpolation). The syntax for string formatting is described in the Python Library Reference, section String Formatting Operations.
Ref: https://docs.python.org/2/reference/expressions.html
(Similar text for the Python3 version of the documentation.)
So it looks as though the argument being passed into your convert_long_to_bytes() function is being treated as a string, or a unicode object, by Python3?
Re: Conversion
Posted: Sat Nov 09, 2019 4:10 pm
by California
Well, it's strange for me. Code below works ok, but together with the rest of the code lines error is shown.
BTW, result is correct.
    i = i % 4294967296
    n4 = i % 256
    i = i / 256
    n3 = i % 256
    i = i / 256
    n2 = i % 256
    n1 = i / 256
    n1 = int(round(n1))
    n2 = int(round(n2))
    n3 = int(round(n3))
    n4 = int(round(n4))
a = 0x81233333   # 5.1
b = convert_long_to_bytes(a)
print (b)        # result: (129L, 35L, 51L, 51L)
Re: Conversion
Posted: Sat Nov 09, 2019 5:26 pm
by jahboater
You should use python3 integer division.
    i %= 4294967296
    n4 = i % 256
    i //= 256
    n3 = i % 256
    i //= 256
    return (i // 256, i % 256, n3, n4)
I'm pretty sure its vastly more efficient, and simpler, than converting it all to floating-point, then rounding it, and finally truncating it back to an integer! Also I think the "round" call was unnecessary and probably wrong.
Re: Conversion
Posted: Sat Nov 09, 2019 6:19 pm
by rpiMike
What about using the bitstring library?
pip3 install bitstring
import bitstring
f1 = bitstring.BitArray(float=5.1, length=32)
print(f1.bin)
01000000101000110011001100110011
Re: Conversion
Posted: Sat Nov 09, 2019 6:43 pm
by California
@jahboater:
your lines of the code works ok, but not with the rest of the code lines.
The very same error as before:
i %= 4294967296
@rpiMike:
described part of the code works ok, but yes, your solution looks much better than my... I'll try to use it
Re: Conversion
Posted: Sat Nov 09, 2019 6:54 pm
by B.Goode
@jahboater:
i %= 4294967296
@rpiMike:
Not really the same error, because the two lines of source code are different.
What does Python think is the type of the argument 'i' when you use it in your production code?
Re: Conversion
Posted: Sat Nov 09, 2019 7:47 pm
by California
In python 2 result is: (129L, 35L, 51L, 51L)
In python 3 result is: (129, 35, 51, 51)
As you can see, diference is in the letter L. Maybe this is what error message say.
So, how to get the letter L into result?
Re: Conversion
Posted: Sun Nov 10, 2019 12:13 am
by billio
Python 2 has normal length integers and long integers, the latter being represented with a trailing L.
>>> type(666L)
<type 'long'>
>>> type(666)
<type 'int'>
I believe that is where the L comes from. But can I ask what the purpose of the function "def convert_long_to_bytes" is. If it is to convert python2 long integers to bytes then this doesn't seem necessary as python3 doesn't have long integers, just integers. Python3 has a function to convert integers to bytes ( https://docs.python.org/3/library/stdty ... ger-types ):
>>> a = 666
>>> a.to_bytes(4,"big")
b'\x00\x00\x02\x9a'
However, your example is confusing me as it uses a floating point number ' # 5.1 ' .
Re: Conversion
Posted: Sun Nov 10, 2019 7:13 am
by California
First of all, I want to thank all of you for your help here.
The purpose of this part of the code is converting temperature setpoint (float) into bytes on the Rpi3 which represents master in RS485 network.
Floating point number 5.1 is just an example, could be used any other positive or negative number.
This form of setpoint is thantransmitted over network to the slave (Microchip's PIC18F458), where is written into EEPROM ...
So, is there any other way to convert in python3 (for example) 0x81233333 into form (129, 35, 51, 51)
Re: Conversion
Posted: Sun Nov 10, 2019 9:21 am
by billio
There may be a better way than this but :
>>> a = 0x81233333
>>> b = a.to_bytes(4,"big",signed=False)
>>> c = [int(i) for i in b]
>>> c
[129, 35, 51, 51]
Re: Conversion
Posted: Sun Nov 10, 2019 10:28 am
by rpiMike
Combining both gives the following, however I get different values for 5.1 - is your example correct?
import bitstring
f=5.1
print(f)
ba = bitstring.BitArray(float=f, length=32)
print(ba.hex)
ih = int(ba.hex,16)
b = ih.to_bytes(4,"big",signed=False)
print(c)
5.1
40a33333
[64, 163, 51, 51]
Re: Conversion
Posted: Sun Nov 10, 2019 12:07 pm
by California
@billio:
so far so god, it looks ok - I have to do more tests
@rpiMike:
your result is also ok, but it is coded in normal float 32 (IEEE) standard, for me it is used Microchip float 32 standard
Re: Conversion
Posted: Sun Nov 10, 2019 12:56 pm
by California
Thanks to all of you, code works as expected.
With best regards,
Vlado
