I have found this code online about displaying images in a slide show. However, it does not have a feature to make it stop after all the images have been displayed.
Can anybody suggest how to go about making it stop once it displays all the images once?
When I close the window that displays the images I get the following error message:
>>> invalid command name "3029038144start"
while executing
"3029038144start"
("after" script)
Can anybody tell me what does this error mean?
I am new at coding and using raspberry pi.
The RPI model I am using is the RPI 4B 2G RAM.
The projector I am using is the Excelvan YG200
Any help will be much appreciated!
Thanks!
Here is the code:
#!/usr/bin/env python3
"""Display a slideshow from a list of filenames"""
import os
import tkinter
from itertools import cycle
from PIL import Image, ImageTk
class Slideshow(tkinter.Tk):
def __init__(self, images, slide_interval):
"""Initialize
images = a list of filename
slide_interval = milliseconds to display image
tkinter.Tk.__init__(self)
self.geometry("+0+0")
self.slide_interval = slide_interval
self.images = None
self.set_images(images)
self.slide = tkinter.Label(self)
self.slide.pack()
def set_images(self, images):
self.images = cycle(images)
def center(self):
"""Center the slide window on the screen"""
self.update_idletasks()
w = self.winfo_screenwidth()
h = self.winfo_screenheight()
size = tuple(int(_) for _ in self.geometry().split('+')[0].split('x'))
x = w / 2 - size[0] / 2
y = h / 2 - size[1] / 2
self.geometry("+%d+%d" % (x, y))
def set_image(self):
"""Setup image to be displayed"""
self.image_name = next(self.images)
filename, ext = os.path.splitext(self.image_name)
self.image = ImageTk.PhotoImage(Image.open(self.image_name))
def main(self):
"""Display the images"""
self.set_image()
self.slide.config(image=self.image)
self.title(self.image_name)
self.center()
self.after(self.slide_interval, self.start)
def start(self):
"""Start method"""
self.main()
self.mainloop()
if __name__ == "__main__":
slide_interval = 2500
# use a list
#images = ["image1.jpg",
#"image2.jpeg",
#"/home/pi/image3.gif",
#"/home/pi/images/image4.png",
#"images/image5.bmp"]
# all the specified file types in a directory
# "." us the directory the script is in.
# exts is the file extentions to use. it can be any extention that pillow supports
# http://pillow.readthedocs.io/en/3.3.x/handbook/image-file-formats.html
import glob
images = glob.glob("*.jpg")
path = "."
exts = ["jpg", "bmp", "png", "gif", "jpeg"]
images = [fn for fn in os.listdir(path) if any(fn.endswith(ext) for ext in exts)]
# start the slideshow
slideshow = Slideshow(images, slide_interval)
slideshow.start()
