[solved] Puzzled by two simple hex-dec-string mixup
Posted: Fri Oct 25, 2019 8:16 am
I'm puzzled by two simple hex-dec-string mixups. (Python 3.7.3)
I discover (using Thonny) for it to accept a hex number in my .py code I need to use 0x and not \x, but then when the results are shown in the Shell, it shows the same number but with the \x prefix.
So I try this in the Shell
(I'm assuming ascii code for A is C0)
so I try this in the Shell
which works. So why to both \x and 0x work but in different context? Is that normal?
My next puzzle relates to how to get the hex numbers I extract from a file into decimal. I set the file up as binary, used read(2) to get at two hex numbers, that seems to work thus:
that gets the two hex numbers and displays them in the Shell thus:
this shows my first puzzle, the Shell shows the hex numbers as \xc0 whereas in my py code I need to write 0xc0 - why the change?
And now to the big puzzle, exactly what data type is my_bpm returned when using the read() function? As string?
So I use
thinking the first line will convert the 2 byte hex number (string) and convert it to a number.
I want to print the number so I can inspect it so I convert the number to a string for printing, but alas errors.
I can only guess I've got my strings mixed with numbers somehow.
My objective is simply to extract 2 adjacent hex numbers from a binary file and use the resulting (decimal) number in further number munching.
>>> int("\xc0",16)
File "<pyshell>", line 1, in <module>
ValueError: invalid literal for int() with base 16: 'À'
>>> int("0xc0",16)
192
position = fo.seek(0x0C,0) # put pointer to 12
my_bpm = fo.read(2)
print("Look now at BPM as two hx numbers ", my_bpm)
Look now at BPM as two hx numbers b'\x03\xc0'
So I use
my_bpm_number = int(my_bpm, 16)
print("BPM from hex to decimal - ", str(my_bpm_number) )
File "/home/pi/tester_1/File_Handling/file_experiments_1.py", line 21, in <module>
ValueError: invalid literal for int() with base 16: b'\x03\xc0'
