rpinewsymphony
How can I make one delay for all sensor?
Sun Oct 13, 2019 4:11 am
This code data logs IR, Ultrasonic and a raindrop sensor but the code prints for about 2 milliseconds each time and it overwhelms our sd card, we would like to make the delay for about 30 second each time to print but right now we don't know how to do that. Thank You
import RPi.GPIO as GPIO
from time import sleep
import time, math
import os
from datetime import datetime
file = open("/home/pi/dataloggers2.csv", "a")
if os.stat("/home/pi/dataloggers2.csv").st_size == 0:
        file.write("Time,RainSensor1,RPM1,RPM2,RPM3,RPMave,Distance(cm)\n")
rpm = 0
rpm1 = 0
rpm2 = 0
elapse = 0
elapse1 = 0
elapse2 = 0
sensor = 24
sensor1 = 27
sensor2 = 22
pulse = 0
pulse1 = 0
pulse2 = 0
distance1 = 0
start_timer = time.time()
def init_GPIO():
    GPIO.setmode(GPIO.BCM)
    GPIO.setwarnings(False)
    GPIO.setup(sensor,GPIO.IN,GPIO.PUD_UP)
def calculate_elapse(channel):
    global pulse, start_timer, elapse
    pulse+=1
    elapse = time.time() - start_timer
def calculate_speed(r_cm):
    global pulse,elapse,rpm
    if elapse !=0:
        rpm = 1/elapse * 60
def init_interrupt():
    GPIO.add_event_detect(sensor, GPIO.FALLING, callback = calculate_elapse, bouncetime = 20)
def init_GPIO1():
    GPIO.setup(sensor1,GPIO.IN,GPIO.PUD_UP)
def calculate_elapse1(channel):
    global pulse1, start_timer, elapse1
    pulse1+=1
    elapse1 = time.time() - start_timer
def calculate_speed1(r1_cm):
    global pulse1,elapse1,rpm1
    if elapse1 !=0:
        rpm1 = 1/elapse1 * 60
def init_interrupt1():
    GPIO.add_event_detect(sensor1, GPIO.FALLING, callback = calculate_elapse1, bouncetime = 20)
def init_GPIO2():
    GPIO.setup(sensor2,GPIO.IN,GPIO.PUD_UP)
def calculate_elapse2(channel):
    global pulse2, start_timer, elapse2
    pulse2+=1
    elapse2 = time.time() - start_timer
def calculate_speed2(r2_cm):
    global pulse2,elapse2,rpm2,dist_km2,dist_meas2,km_per_sec2,km_per_hour2
    if elapse2 !=0:
        rpm2 = 1/elapse2 * 60
def init_interrupt2():
    GPIO.add_event_detect(sensor2, GPIO.FALLING, callback = calculate_elapse2, bouncetime = 20)
def ping():
    TRIG = 23
    ECHO = 18
    STATUS = 0
    GPIO.setup(TRIG,GPIO.OUT)
    GPIO.setup(ECHO,GPIO.IN)
    GPIO.output(TRIG, False)
    time.sleep(1)
    GPIO.output(TRIG, True)
    time.sleep(0.00001)
    while GPIO.input(ECHO)==0:
        pulse_start = time.time()
    while GPIO.input(ECHO)==1:
        pulse_end = time.time()
    global distance
    pulse_duration = pulse_end - pulse_start
    distance = pulse_duration * 17150
    distance = round(distance, 2)
def isitwet():
    GPIO.setup(4, GPIO.IN)
    state = GPIO.input(4)
    distance1 = 0
    global status, now
    if (state==1):
        now = datetime.now()
        #print ("DRY\tDistance:",distance,"cm")
        #print("DRY")
        status = "DRY"
        sleep (1)
    else:
        #print ("WET\tDistance:",distance,"cm")
        #print("WET")
        status = "WET"
        sleep (1)
if _name_ == '_main_':
    init_GPIO()
    init_interrupt()
    init_GPIO1()
    init_interrupt1()
    init_GPIO2()
    init_interrupt2()
    while True:
        ping()
        isitwet()
        calculate_speed(6)
        calculate_speed1(6)
        calculate_speed2(6)
        rpmf = (rpm + rpm1 + rpm2) / 3
        print('rpm:{0:.0f}-RPM rpm1:{1:.0f}-RPM rpm2:{2:.0f} AveRPM:{3:.0f}-RPM Distance:{4}-cm Weather:{5}'.format(rpm,rpm1,rpm2,rpmf,distance,status))
        file.write(str(now)+","+str(status)+","+str(rpm)+","+str(rpm1)+","+str(rpm2)+","+str(rpmf)+","+str(distance)+"\n")
sleep(0.1)
pcmanbob
Re: How can I make one delay for all sensor?
Sun Oct 13, 2019 7:38 am
If you want 30 seconds between each read of the sensors and subsequent print of the results then just add a 30 sleep like this
    while True:
        ping()
        isitwet()
        calculate_speed(6)
        calculate_speed1(6)
        calculate_speed2(6)
        sleep(30)
now you while true loop will run and wait 30 seconds before running again.
rpinewsymphony
Thu Oct 31, 2019 9:03 am
It worked thanks :)
Return to “Python”
