GUIZERO - input_box = TextBox
Posted: Fri Oct 11, 2019 9:36 am
by Lookslikerain75
I setup an input_box = textbox (example below) in three actions if a button is pressed a command runs and a log file is created then used as the contents of the textbox. If the second button is pressed a different log becomes the content of the text box. unless i am going mad this was working. the same text box displayed different log files depending which button was pressed.
I must have changed something or imagined it was working as now when the second button is pressed which ever one that maybe a second textbox is displayed below the first one and does not replace the first one, so i end up with an new textbox every time i press a button.
I am pretty sure i have gone about this the wrong way, the idea is to have one text box that displays different log files after a button is pressed a custom command run by myCmd and the resulting log shown. I am not great at coding as you can see, any ideas welcome.
#!/usr/bin/env python3
from guizero import App, Text, PushButton, info, TextBox
import os
# Method to call when button pressed
myCmd= '<command> > /home/pi/log.log'
myCmd2= '<command> > /home/pi/log1.log'
myCmd3= '<command> > /home/pi/log2.log'
# Set up the app
app = App(title="Command and log", height="600", width="600")
def action():
    os.system(myCmd)
    file = open("/home/pi/log.log","r+").read()
    input_box = TextBox(app, text=file, height=20, width=70, multiline=True)
    textshow.value = "Complete"
def action2():
    os.system(myCmd2)
    file1 = open("/home/pi/log1.log","r+").read()
    input_box = TextBox(app, text=file1, height=20, width=70, multiline=True)
def action3():
    os.system(myCmd3)
    file2 = open("/home/pi/log2.log","r+").read()
    input_box = TextBox(app, text=file2, height=20, width=70, multiline=True)
Text(app, "Current Version " + os.uname()[2], align="bottom")
button = PushButton(app, action, text="Command 1", align="top")
button = PushButton(app, action2, text="Command 2", align="top")
button = PushButton(app, action3, text="Command 3", align="bottom")
textshow = Text(app, text="--", color="green", align="bottom")
app.display()
Re: GUIZERO - input_box = TextBox
Posted: Fri Oct 11, 2019 12:54 pm
by Lookslikerain75
I have just changed the coed to open the log file in leafpad instead. but may come back to this another time
Posted: Fri Oct 11, 2019 4:13 pm
by joelostinspace
it works for me,
I didn't need- :
os.system(myCmd)
the only thing i see is you need to clear the previous log they get stacked,
Create a text box with buttons and use the function to add content...
I haven't spent much time w/ quizero seems the set is depreciated:
good luck,
joe
import os
# Set up the app
def action():
    input_box.clear()
    input_box.set(file)
def action2():
    input_box.clear()
    file = open("/home/pi/log1.log","r+").read()
    input_box.set(file)
def action3():
    input_box.clear()
    file = open("/home/pi/log2.log","r+").read()
    input_box.set(file)
input_box = TextBox(app, text='place holder', height=20, width=70,
                        multiline=True, )
app.display()
Posted: Mon Oct 14, 2019 1:26 pm
by lawsie
joelostinspace is right - set is deprecated and has been for a really long time. Use `input_box.value = file` (docs page here - https://lawsie.github.io/guizero/textbox/). :)
Posted: Mon Oct 14, 2019 3:32 pm
by joelostinspace
@lawsie hey thanks for the module and great documentation spent last weekend making apps. Really like that you made all the labels textvariables. Joe
