sayhello
install this ide on MX Linux :: the uPyCraft IDE: to work with MicroPython
Thu Oct 03, 2019 3:54 pm
hello and good evening dear Nobbie - and hello dear Community
i want to install this ide on MX - Linux.
the uPyCraft IDE .. guess i can use this tutorial:
LINK. https://randomnerdtutorials.com/install ... tructions/
link https://randomnerdtutorials.com/uPyCraftLinux.
$ cd Downloads
$ ls -l
  uPyCraft_linux_V1.X
and this
$ chmod +x uPyCraft_linux_V1.X
see the piece of code:
$ ./uPyCraft_linux_V1.X
and then it goes like so: I do not have Ubuntu here - but i have a MX-Linux here. But as i want to install uPyCraft on the Mx-System i guess that i can use the above mentioned commands too. Since Ubuntu relies on Debian and MX does too. This is all the reason for this above mentioned thread!
i sometimes make sure myself in something while writing things down. And in this case i just wanted to ask you - if you can confirm the idea - that Since Ubuntu relies on Debian and MX does too - i would have no issues to install the above mentioned ide on the MX18.03
update : if i do so i stuck here:
see the following
insgesamt 26620
-rw-r--r-- 1 martin martin 27256160 Sep 26 19:16 uPyCraft_linux_V1.0
[email protected]:~/Downloads
$ ls -l
insgesamt 26620
$ ^C
chmod: Zugriff auf 'uPyCraft_linux_V1.X' nicht möglich: Datei oder Verzeichnis nicht gefunden
$ chmod +x uPyCraft_linux_V1.0
bash: ./uPyCraft_linux_V1.X: Datei oder Verzeichnis nicht gefunden
$ ls -l
insgesamt 26620
-rwxr-xr-x 1 martin martin 27256160 Sep 26 19:16 uPyCraft_linux_V1.0
Click and drag to move
the uPyCraft IDE see the tutorial. https://randomnerdtutorials.com/install ... tructions/
and see this https://randomnerdtutorials.com/uPyCraftLinux.
$ cd Downloads
$ ls -l
uPyCraft_linux_V1.X
and see this
finally i got this here
[email protected]:/home/martin# su
[email protected]:/home/martin# apt-get install python3-venv
Paketlisten werden gelesen... Fertig
Abhängigkeitsbaum wird aufgebaut.
Statusinformationen werden eingelesen.... Fertig
The following additional packages will be installed:
  python3.5-venv
Die folgenden NEUEN Pakete werden installiert:
  python3-venv python3.5-venv
0 aktualisiert, 2 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
Es müssen [ration werden 39,9 kB Plattenplatz zusätzlich benutzt.
Möchten Sie fortfahren? [J/n] j
Holen:1 http://ftp.de.debian.org/debian stretch/main amd64 python3.5-venv amd64 3.5.3-1+deb9u1 [5.954 B]
Holen:2 http://ftp.de.debian.org/debian stretch/main amd64 python3-venv amd64 3.5.3-1 [1.066 B]
Es wurden 7.020 B in 0 s geholt (40,6 kB/s).
Vormals nicht ausgewähltes Paket python3.5-venv wird gewählt.
(Lese Datenbank ... 256952 Dateien und Verzeichnisse sind derzeit installiert.)
Vorbereitung zum Entpacken von .../python3.5-venv_3.5.3-1+deb9u1_amd64.deb ...
Entpacken von python3.5-venv (3.5.3-1+deb9u1) ...
Vormals nicht ausgewähltes Paket python3-venv wird gewählt.
Vorbereitung zum Entpacken von .../python3-venv_3.5.3-1_amd64.deb ...
Entpacken von python3-venv (3.5.3-1) ...
python3.5-venv (3.5.3-1+deb9u1) wird eingerichtet ...
Trigger für man-db (2.7.6.1-2) werden verarbeitet ...
python3-venv (3.5.3-1) wird eingerichtet ...
well something goes wrong here. i have to find out what goes on here.
note: the system gives back the the data were not found..
any idea ?
look forward to hear from you
love to hear from you
Re: install this ide on MX Linux :: the uPyCraft IDE: to work with MicroPython
Thu Oct 03, 2019 4:08 pm
$ cd Downloads
$ ls -l
  uPyCraft_linux_V1.X
and this
see the following
insgesamt 26620
$ ls -l
insgesamt 26620
$ ^C
$ ls -l
insgesamt 26620
$ cd Downloads
$ ls -l
uPyCraft_linux_V1.X
and see this
  python3.5-venv
any idea ?
What model of Raspberry Pi SBC are you using to run MX Linux ??
Retired disgracefully.....
Return to “Python”
