peppy.player
Solution for Pygame and Touchscreens on Raspbian Buster OS
Tue Aug 27, 2019 4:59 am
The current version of the Pygame library leverages libsdl1.2. The version of the libsdl1.2 on Raspbian Buster OS has the issues with touchscreens. One of the solutions is to build that library with proper touchscreen support. This solution was suggested by Gerhard the author of NewtronRadio https://forum-raspberrypi.de/forum/thre ... tron-radio On his behalf I'm creating this post hoping that it will be also helpful for other developers.
You can either download the patched libsdl1.2 package from the Gerhard's Dropbox account:
https://www.dropbox.com/s/0tkdym8ojhcmb ... _armhf.deb
and then install the package:
wget https://www.dropbox.com/s/0tkdym8ojhcmbu2/libsdl1.2debian_1.2.15+veloci1-1_armhf.deb
sudo dpkg -i libsdl1.2debian_1.2.15+veloci1-1_armhf.deb
sudo apt-get -f install
Or you can build that library yourself by following these steps:
1. Install libts-dev
sudo apt install libts-dev
2. Get the required packages
wget http://deb.debian.org/debian/pool/main/libs/libsdl1.2/libsdl1.2_1.2.15+dfsg2.orig.tar.gz
wget http://deb.debian.org/debian/pool/main/libs/libsdl1.2/libsdl1.2_1.2.15+dfsg2-4.debian.tar.xz
3. Extract the packages
tar xvzf libsdl1.2_1.2.15+dfsg2.orig.tar.gz
cd SDL-1.2.15
tar xvfJ ../libsdl1.2_1.2.15+dfsg2-4.debian.tar.xz
4. Install libSDL dependencies (can be found in debian/control)
sudo apt install libx11-dev libxext-dev libxt-dev libxv-dev x11proto-core-dev libpulse-dev libgl1-mesa-dev libasound2-dev libcaca-dev libglu1-mesa-dev
5. Install packages for building .deb-packages
sudo apt install build-essential debhelper
6. Add libts-dev to the "Build-Depends:"-section and to the "Depends:"-section for "Package: libsdl1.2-dev" in /home/pi/SDL-1.2.15/debian/control
7. Remove the "opts="-line in /home/pi/SDL-1.2.15/debian/watch so that it looks like this:
# run "uscan --report" to check or "gpb import-orig --uscan" to update
version=4
https://www.libsdl.org/release/SDL-([\d.]+)\.tar\.(?:gz|bz2|xz|lzma)
8. Edit /home/pi/SDL-1.2.15/debian/changelog (add to top)
libsdl1.2 (1.2.15+veloci1-1) unstable; urgency=medium
  * re-add support for libts
 -- veloci <[email protected]>  Thu, 11 Jul 2019 11:12:13 +0200
9. Rename libsdl1.2_1.2.15+dfsg2.orig.tar.gz to libsdl1.2_1.2.15+veloci1.orig.tar.gz
mv /home/pi/SDL-1.2.15/libsdl1.2_1.2.15+dfsg2.orig.tar.gz /home/pi/SDL-1.2.15/libsdl1.2_1.2.15+veloci1.orig.tar.gz
10. Build the whole thing (in folder /home/pi/SDL-1.2.15)
debian/rules clean
dpkg-source -b .
debian/rules build
11. Create the packages (in folder /home/pi/SDL-1.2.15)
fakeroot debian/rules binary
12. Install new package
cd ..
Many thanks to Gerhard for the suggested solution!
JKOORNNEEF
Re: Solution for Pygame and Touchscreens on Raspbian Buster OS
Fri Sep 06, 2019 2:52 pm
I have serious problems with your solution on my configuration: Buster, RPi B+, Linux 4.19.58+, Python 2.7.16, Pygame 1.9.4.post1, Watterott 2.8".
The initial installation of your precompiled libsdl1.2debian_1.2.15+veloci1-1_armhf.deb package failed due to the absence of libts0. After installing libts0_1.19-1_armhf.deb a rerun of your .deb completed.
But now, my Python script exits from Python with the "Illegal instruction" message directly after "import pygame".
I have been struggling with getting the touch capability to work for weeks, and would like your solution to work. Can you help?
veloci
Sun Sep 15, 2019 12:31 pm
What does "dpkg -s libsdl1.2debian" show?
eorange
Fri Jan 03, 2020 12:04 am
Has anyone had success with getting this solution to work? I have a 3B+ with an Adafruit PiTFT 3.5" running Buster Lite. I'm using pygame with python 3. Everything about pygame works except for the erratic and random mouse positions provided by pygame.mouse.get_pos().
I tried the pre-built and build-your-own examples provided by the OP, both on a clean Buster lite install. Each procedure completely successfully, but...there's no improvement. The mouse positions are still random.
What am I missing here? Thanks in advance.
toddboyland
Thu Jan 30, 2020 9:58 pm
I ran into the same issue w/ pygame on a Raspberry Pi.
In the OS, the touchscreen works fine.
When the python/pygame script it run the touchsreen is extremely erratic.
I tried wheezy, jessie, stretch, and buster (lite, and full OS) on Raspberry Pi version 3's & Pi 4 hardware platforms.
My solution ended up being related to how the .py script was started.
When I manually executed the .py script from ssh (as sudo due to permission issue), the touchscreen was erratic.
Example: /usr/bin/python3 /home/pi/foldername/script.py
When I schedule the script using crontab -e (as pi user), the touchscreen was erratic.
Example entry in cron: @reboot /usr/bin/python3 /home/pi/foldername/script.py
When I configure autostart the touchscreen finally works well.
Configure autostart: (must be performed as pi user, as sudo causes changes in file permissions)
mkdir /home/pi/.config/autostart
nano /home/pi/.config/autostart/script_name.desktop
[Desktop Entry]
Type=Application
Name=script_name
Exec=/usr/bin/python3 /home/pi/foldername/script.py
Hopefully this helps someone else, as it took a long time to narrow down.
peppy.player
Fri Jan 31, 2020 12:56 am
The patched library works fine for all Peppy player disk images:
https://github.com/project-owner/PeppyP ... isk-Images
I download it from the Dropbox account mentioned in the first post.
Return to “Python”
