RetiredRon
Confused by Global?
Thu Aug 22, 2019 2:43 pm
I' m having trouble with global variable declarations. I understand that they must be declared inside a function if their value will be modified and used outside the function, but the following code snippet, which I pulled from a Python learning site, has me baffled:
#start of code snippet:
def foo():
    x = 20
    def bar():
        global x
        x = 25
    print("Before calling bar: ", x)
    print("Calling bar now")
    bar()
    print("After calling bar: ", x)
foo()
print("x in main : ", x)
#end of code snippet
This results in the following output:
Before calling bar: 20
Calling bar now
After calling bar: 20
x in main : 25
I thought the fact that “x” is not changing after calling the bar function might have something to do with nesting the bar function within the foo function, so I moved it from within the foo function to the outside at the same level as the foo function. But running the modified version still generated the same result.
So why, after declaring x as global in the bar function, is its value not changed on return? And why is it then changed in the main program?
Any help appreciated!
rpdom
Re: Confused by Global?
Thu Aug 22, 2019 6:06 pm
The function foo is using a local version of x, but bar is using a global version. When bar is run it updates the global version which won't affect the local version of x used in foo.
Unreadable squiggle
MrYsLab
Thu Aug 22, 2019 6:18 pm
If you use a class instead of a collection of individual procedures, you can avoid the whole global mess. Here is a great turorial: https://realpython.com/python3-object-o ... ogramming/
I took the liberty to convert your program using a class:
class PlayTime:
    # a class variable
    x = 33
    def __init__(self):
        # an instance variable
        self.x = 20
    def bar(self, value):
        self.x = value
p = PlayTime()
print("Before calling bar: ", PlayTime.x, p.x)
p.bar(99)
print("After calling bar: ", PlayTime.x, p.x)
Here is the result of the run:
Before calling bar:  33 20
Calling bar now
After calling bar:  33 99
hippy
Thu Aug 22, 2019 11:39 pm
Consider this ...
global_x = 0
def foo():
  foo_x = 20
  def bar():
    bar_x = 25
  print("Before calling bar: ", foo_x)
  bar()
  print("After calling bar: ", foo_x)
foo()
print("After calling foo: ", global_x)
Each use of "x" in your original code is refering to a particular "_x" variable, and those are effectively the internal names even though you are using only a simple "x" for all of them.
By adding a "global x" in the bar() routine, it is making "bar_x" synonymous with "global_x". Changing "x" in bar() changes "bar_x" which is actually "global_x".
The "x" in the foo() routine refers to "foo_x" which wasn't changed. But back at the outer code after calling foo() the "x" there refers to "global_x" which was changed.
RetiredRon
Tue Aug 27, 2019 2:29 pm
To: rpdom and hippy
Thanks for your replies. I think I understand this now, thanks to your explanations.
To: MrYsLab:
I'm just starting to learn OOP so don't yet understand your code using classes, etc. I'll return to it once I've got the basics nailed down.
I appreciate the link to the OOP tutorial. It looks like a great place to start!
Thanks!
Return to “Python”
