SismeyA
Phython Reading Temperature every 10 Secs and writing to DB
Mon Aug 12, 2019 8:57 pm
Hi ,
I wonder if anyone could help me with my code, with help from snippets I have managed to write code to write , temperature, Air Pressure , etc to MYSQL, I am trying to get it to do this every 30 mins, I have tried adding the "while True:" in several position but the best I can achieve is writing the same value over and over again?
Any help would be great?
import mysql.connector as mariadb
import smbus
import time
t=time.time()
while True:
    if time.time()-t>10:
# Get I2C bus
        bus = smbus.SMBus(1)
# BMP280 address, 0x76(118)
# Read data back from 0x88(136), 24 bytes
b1 = bus.read_i2c_block_data(0x76, 0x88, 24)
# Convert the data
# Temp coefficents
dig_T1 = b1[1] * 256 + b1[0]
dig_T2 = b1[3] * 256 + b1[2]
if dig_T2 > 32767 :
        dig_T2 -= 65536
dig_T3 = b1[5] * 256 + b1[4]
if dig_T3 > 32767 :
        dig_T3 -= 65536
# Pressure coefficents
dig_P1 = b1[7] * 256 + b1[6]
dig_P2 = b1[9] * 256 + b1[8]
if dig_P2 > 32767 :
        dig_P2 -= 65536
dig_P3 = b1[11] * 256 + b1[10]
if dig_P3 > 32767 :
        dig_P3 -= 65536
dig_P4 = b1[13] * 256 + b1[12]
if dig_P4 > 32767 :
        dig_P4 -= 65536
dig_P5 = b1[15] * 256 + b1[14]
if dig_P5 > 32767 :
        dig_P5 -= 65536
dig_P6 = b1[17] * 256 + b1[16]
if dig_P6 > 32767 :
        dig_P6 -= 65536
dig_P7 = b1[19] * 256 + b1[18]
if dig_P7 > 32767 :
        dig_P7 -= 65536
dig_P8 = b1[21] * 256 + b1[20]
if dig_P8 > 32767 :
        dig_P8 -= 65536
dig_P9 = b1[23] * 256 + b1[22]
if dig_P9 > 32767 :
        dig_P9 -= 65536
# Select Control measurement register, 0xF4(244)
# 0x27(39) Pressure and Temperature Oversampling rate = 1
# Normal mode
bus.write_byte_data(0x76, 0xF4, 0x27)
# Select Configuration register, 0xF5(245)
# 0xA0(00) Stand_by time = 1000 ms
bus.write_byte_data(0x76, 0xF5, 0xA0)
time.sleep(0.5)
# Read data back from 0xF7(247), 8 bytes
# Pressure MSB, Pressure LSB, Pressure xLSB, Temperature MSB, Temperature LSB
# Temperature xLSB, Humidity MSB, Humidity LSB
data = bus.read_i2c_block_data(0x76, 0xF7, 8)
# Convert pressure and temperature data to 19-bits
adc_p = ((data[0] * 65536) + (data[1] * 256) + (data[2] & 0xF0)) / 16
adc_t = ((data[3] * 65536) + (data[4] * 256) + (data[5] & 0xF0)) / 16
# Temperature offset calculations
var1 = ((adc_t) / 16384.0 - (dig_T1) / 1024.0) * (dig_T2)
var2 = (((adc_t) / 131072.0 - (dig_T1) / 8192.0) * ((adc_t)/131072.0 - (dig_T1)/8192.0)) * (dig_T3)
t_fine = (var1 + var2)
cTemp = (var1 + var2) / 5120.0
fTemp = cTemp * 1.8 + 32
# Pressure offset calculations
var1 = (t_fine / 2.0) - 64000.0
var2 = var1 * var1 * (dig_P6) / 32768.0
var2 = var2 + var1 * (dig_P5) * 2.0
var2 = (var2 / 4.0) + ((dig_P4) * 65536.0)
var1 = ((dig_P3) * var1 * var1 / 524288.0 + ( dig_P2) * var1) / 524288.0
var1 = (1.0 + var1 / 32768.0) * (dig_P1)
p = 1048576.0 - adc_p
p = (p - (var2 / 4096.0)) * 6250.0 / var1
var1 = (dig_P9) * p * p / 2147483648.0
var2 = p * (dig_P8) / 32768.0
pressure = (p + (var1 + var2 + (dig_P7)) / 16.0) / 100
# Output data to screen
mariadb_connection = mariadb.connect(user='pi', password='my54cr4t', database='weather')
cursor = mariadb_connection.cursor()
try:
                cursor.execute("INSERT INTO WEATHER_RESULTS (C_TEMPERATURE, F_TEMPERATURE, AIR_PRESSURE, HUMIDITY, WIND_SPEED, WIND_GUST_SPEED,RAINFALL) VALUES (%s,%s,$
                mariadb_connection.commit()
                print "Data Written"
except:
                print "Error"
                mariadb_connection.rollback()
t=time.time()
mariadb_connection.close()
Andyroo
Re: Phython Reading Temperature every 10 Secs and writing to DB
Mon Aug 12, 2019 10:37 pm
I would change the program so it reads the data once only then write the data to the database.
You can then use cron to call this program every 30 minutes.
SismeyA
Tue Aug 13, 2019 9:38 am
Thanks Andyroo, new to python and pi , I appreciate the advice and will use cron , Cheers
Return to “Python”
