timothyy
How to using a value from spinbox
Thu Aug 08, 2019 11:28 am
I wanted to use the spinbox value to control the output percentage for my on/off control. I tried DACp(13,spinsee1) and DACp(14,spinsee2), it seems that python does not accept this type of input, so it must be a number, for example: DACp(14,100). Is there a way that i can change into number and be recognised by python?
from tkinter import *
from pwmdac import DACp
from pwmdac import DACoff
import tkinter as tk
import time
root = Tk()
root.wm_title("Testing_version 1.0 beta")
root.geometry("300x250")
spin1 = Spinbox(root, from_=0, to=100, width=5)
global spinsee1
spin1.place(x=150, y=30)
spinsee1=spin1.get()
spin2 = Spinbox(root, from_=0, to=100, width=5)
global spinsee2
spin2.place(x=150, y=60)
spinsee2=spin2.get()
def toggle1():
    if var1.get() == "ON":
        DACp(13,spinsee1)
    else:
        DACoff(13)
var1 = tk.StringVar()
toggle = tk.Checkbutton(root, onvalue="ON", offvalue="OFF", width=4,
                        indicatoron=False,
                        variable=var1, textvariable=var1,
                        selectcolor="green", background="red",
                        command=toggle1)
var1.set("OFF")
toggle.place(x=220, y=30)
def toggle2():
    if var2.get() == "ON":
        DACp(14,spinsee2)
    else:
        DACoff(14)
var2 = tk.StringVar()
                        indicatoron=False,
                        variable=var2, textvariable=var2,
                        command=toggle2)
var2.set("OFF")
toggle.place(x=220, y=60)
mainloop()
Code for DACp & DACoff from pwmdac.py
def DACoff():
    set_all_pwm(0, 4095)
    output_disable()
def DACp(chn,perc):
    pulsewidth = int(4095/100*perc)
    DACon(chn,pulsewidth)
MrYsLab
Re: How to using a value from spinbox
Thu Aug 08, 2019 2:13 pm
The value returned from spinbox is a string. To convert the string to an integer use int(). For example if the value returned is "4", and stored in a variable called x to convert :
value = int(x)
timothyy
Thu Aug 08, 2019 2:49 pm
The code i have changed into:
global spinsee1
spinsee1= int(x)
The DACp should be:
 DACp(13,x)
joelostinspace
Sat Aug 10, 2019 3:05 pm
Timothy the example is not literal but a general way of converting a string to int- examine the use of classes
it eliminates the use of global variables.
global spinsee1
value=spin1.get()
spinsee1= int(value)
To travel is to discover that everyone is wrong about other countries.
--- Aldous Huxley
Return to “Python”
