Nahyeahnah
Problem with my OLED time, date, weather script.
Sun Aug 04, 2019 4:45 am
I'm relatively new to coding python and am trying to get my OLED display to show the time, date, and weather. Pre-implementing the weather part, the time and date worked perfectly fine, and showed on the OLED.
Now that I've implemented the weather using openweathermaps, I'm getting the error show in the image.
This is the code that I'm using currently:
An analog clockface with date, time & temp.
import math
import time
import datetime
import json
import sqlite3
import urllib
import calendar
from demo_opts import get_device
from luma.core.render import canvas
APP_ID = '497f4bcadd7291213189485776f0a8c7'
WEATHER_DATA_URL = 'http://api.openweathermap.org/data/2.5/weather?q=Adelaide,de&units=metric&APPID=' + APP_ID
def posn(angle, arm_length):
    dx = int(math.cos(math.radians(angle)) * arm_length)
    dy = int(math.sin(math.radians(angle)) * arm_length)
    return (dx, dy)
def get_data():
    """get weather data from openweathermap"""
    response = urllib.urlopen(WEATHER_DATA_URL)
    data = json.loads(response.read())
    temp = data['main']['temp']
    pressure = data['main']['pressure']
    temp_min = data['main']['temp_min']
    temp_max = data['main']['temp_max']
    humidity = data['main']['humidity']
    wind_speed = data['wind']['speed']
    try:
        wind_gust = data['wind']['gust']
    except KeyError:
        wind_gust = None
    wind_deg = data['wind']['deg']
    clouds = data['clouds']['all']
    try:
        rain = data['rain']['3h']
    except KeyError:
        rain = None
    try:
        snow = data['snow']['3h']
    except KeyError:
        snow = None
    weather_id = data['weather'][0]['id']
    sunrise = data['sys']['sunrise']
    sunset = data['sys']['sunset']
    return [temp, pressure, temp_min, temp_max, humidity, wind_speed, wind_gust, wind_deg, clouds, rain, snow,
            weather_id, sunrise, sunset]
def save_data_to_db(data):
    con = sqlite3.connect("/home/pi/dumbGlasses/Weatherdata/db_files/data.db")
    con.isolation_level = None
    cur = con.cursor()
    query = '''INSERT INTO weather_data VALUES (null, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)'''
    cur.execute(query, tuple([datetime.datetime.now().isoformat()] + data[:-2]))
    con.commit()
    con.close()
def main():
    data = get_data()
    now = calendar.timegm(datetime.datetime.now().timetuple())
    if data[-2] < now < data[-1]:
    today_last_time = "Unknown"
    while True:
        now = datetime.datetime.now()
        today_date = now.strftime("%d %b %y")
        today_time = now.strftime("%H:%M:%S")
        if today_time != today_last_time:
            today_last_time = today_time
            with canvas(device) as draw:
                margin = 4
                cx = 30
                cy = min(device.height, 64) / 2
                left = cx - cy
                right = cx + cy
                hrs_angle = 270 + (30 * (now.hour + (now.minute / 60.0)))
                hrs = posn(hrs_angle, cy - margin - 7)
                min_angle = 270 + (6 * now.minute)
                mins = posn(min_angle, cy - margin - 2)
                sec_angle = 270 + (6 * now.second)
                secs = posn(sec_angle, cy - margin - 2)
                draw.ellipse((left + margin, margin, right - margin, min(device.height, 64) - margin), outline="white")
                draw.line((cx, cy, cx + hrs[0], cy + hrs[1]), fill="white")
                draw.line((cx, cy, cx + mins[0], cy + mins[1]), fill="white")
                draw.line((cx, cy, cx + secs[0], cy + secs[1]), fill="red")
                draw.ellipse((cx - 2, cy - 2, cx + 2, cy + 2), fill="white", outline="white")
                draw.text((2 * (cx + margin), cy - 8), today_date, fill="yellow")
                draw.text((2 * (cx + margin), cy), today_time, fill="yellow")
        draw.text((2 * (cx + margin), cy + 8), temp, fill="yellow")
        time.sleep(0.1)
if __name__ == "__main__":
    try:
        device = get_device()
        main()
    except KeyboardInterrupt:
        pass
Thanks for any help! :D
ghp
Re: Problem with my OLED time, date, weather script.
Sun Aug 04, 2019 10:14 am
    print("data from response is", data)  # add this statement and look what the data structure is
Nahyeahnah
Thu Aug 08, 2019 8:02 am
This is what I've gotten after adding the print function.
dumbglasses python problem 2.PNG (255.34 KiB) Viewed 649 times
Andyroo
Thu Aug 08, 2019 1:08 pm
That’s saying Adelaide DE is not a valid location.
OpenWeatherMaps recommendation is
We recommend to call API by city ID to get unambiguous result for your city.
You can find this by going to the main page and searching for the location you are after and then looking at the URL once you have found it.
You then use ?id={city ID} (replacing {city} with the number you found above} in your search string.
Nahyeahnah
Sun Aug 11, 2019 9:29 am
Thanks for all the help guys! :D
After properly adding the city ID, it's gathering all the weather data.
However, now there's an issue drawing the 'temp' data in main. I've tried defining temp as a global function, but nothing seems to be working.
This is what the terminal responds with:
dumbglasses python problem 3.PNG (212.18 KiB) Viewed 614 times
Again, thanks for the help guys!
Andyroo
Sun Aug 11, 2019 11:54 am
Without seeing you code its just about impossible to debug this!
You could check:
1) That temp is defined in the main code
2) That temp is used consistently and not Temp (python is case sensitive)
3) You have Global temp in the function that has the error
Nahyeahnah
Sun Aug 11, 2019 10:59 pm
I'll give this a shot tonight! Thanks man.
The code is in the first post. The only thing that has changed in it has been the area code for openweathermap.
You could check:
Return to “Python”
