Page 2 of 2
Re: Running Python Scripts From A Html
Posted: Tue Aug 06, 2019 6:15 pm
by drifterf
ghp wrote: ↑Mon Aug 05, 2019 4:35 am
- the last line of code is missing tornado.ioloop.IOLoop.current().start()
- html code usually has links inside <body>... here goes the page ...</body>. Your page works unexpectedly.
- in the Popen, add ", shell=True". Or try using /usr/bin/python which is more precise.
- the url mappings contain r"/opendoor2/?(.*)" AND r"/opendoor2". So MyOpenDoor2Handler will not be called. Better tu use different names for the url.
When in doubt how to use the subprocess.Popen, then write a short script with these statements only and run this on its own.
hi, im sorry to be a nightmare, i have tried stuff i know, could you provide a example of what you have said please. im really sorry to be a pain
Thank you for your time regardless
Posted: Tue Aug 06, 2019 8:05 pm
by ghp
think this could work
import tornado.ioloop
import tornado.web
import subprocess
import os
class Python3ScriptRunner:
def __init__(self):
pass
def invoke(self, script_name):
print("call script ", script_name)
if os.path.isfile(script_name):
pid = subprocess.Popen(["/usr/bin/python3", script_name]).pid
print(pid)
else:
raise Exception("script name does not exist " + script_name)
class MyOpenDoor_1_Handler(tornado.web.RequestHandler):
def get(self):
print("MyOpenDoor_1_Handler.get()")
self.write("""Released The Door - Relay 1""")
try:
Python3ScriptRunner().invoke( "opendoor_1.py")
except Exception as e:
self.set_status(500, "Exception " + str(e))
return
self.redirect("/opendoor_1_success")
class MyOpenDoor_2_Handler(tornado.web.RequestHandler):
def get(self):
print("MyOpenDoor_2_Handler.get()")
try:
Python3ScriptRunner().invoke( "opendoor_2.py")
return
self.redirect("/opendoor_2_success")
class MyFormHandler(tornado.web.RequestHandler):
def get(self):
self.write("""<html>
<body>
<a href="/opendoor_1">Release Door - Relay 1</a>
<br/>
<a href="/opendoor_2">Release Door - Relay 2</a>
</body>
</html>""")
def post(self):
self.set_header("Content-Type", "text/plain")
self.write("post request for a form, not used")
def make_app():
return tornado.web.Application([
( r"/", MyFormHandler),
( r"/myform", MyFormHandler),
( r"/opendoor_1", MyOpenDoor_1_Handler),
( r"/opendoor_2", MyOpenDoor_2_Handler),
( r"/opendoor_1_success/?(.*)", tornado.web.StaticFileHandler, {"path": "/home/pi/ACU/html/" , "default_filename": "index.html"} ),
( r"/opendoor_2_success/?(.*)", tornado.web.StaticFileHandler, {"path": "/home/pi/ACU/html/" , "default_filename": "index.html"} ),
if __name__ == "__main__":
app = make_app()
app.listen(8787)
Posted: Wed Aug 07, 2019 4:14 pm
by drifterf
Hi, no luck
all i get now is the following in the terminal when i click something
WARNING:tornado.access:404 GET /favicon.ico (::1) 3.04ms
call script opendoor_2.py
ERROR:tornado.access:500 GET /opendoor_2 (::1) 3.56ms
call script opendoor_1.py
ERROR:tornado.access:500 GET /opendoor_1 (::1) 4.82ms
ERROR:tornado.access:500 GET /opendoor_1 (::1) 3.70ms
ERROR:tornado.access:500 GET /opendoor_2 (::1) 4.46ms
on the webpage when i click on the first link it shows the "released text" but on the second link (the one trying to call the webpage and py script) i just get "this page isnt working, localhost is currently unable to handle this request, http error 500"
if i run the script i posted before it triggers the relay on button 1 and on button 2 does not trigger the relay but shows the webpage so same issue as before
the script you posted i saved as server123.py and have the original server.py in the same directory as each other
Posted: Wed Aug 07, 2019 5:12 pm
by ghp
Think the two scripts opendoor_1.py, opendoor_2.py are not available in local directory. Either rename the scripts you have to these names, or adjust the calls in the Handlers. The code fragment is Python3ScriptRunner().invoke( "opendoor_1.py") or Python3ScriptRunner().invoke( "opendoor_2.py").
In my setup, I have a script opendoor_1.py, but no opendoor_2.py (by purpose to check the code).
Here the console output:
WARNING:tornado.access:404 GET /favicon.ico (192.168.2.152) 1.65ms
favicon is searched by the browser by default. This is no problem.
1242 // printout of the pid
hello // my script just says hello
call script opendoor_2.py // this script does not exist
ERROR:tornado.access:500 GET /opendoor_2 (192.168.2.152) 1.98ms
Posted: Wed Aug 07, 2019 5:38 pm
by drifterf
Hi, thank you so much for your help, i found the issue was actually with the script i was trying to launch.
as i was launching server.py with python3 the old script was missing the brackets from the print part of the script
i changed the old script from
print "door released"
to
print ("door released")
and now it works. i have deffinalty learned something here lol.
i can only appreciate your help GHP !!! appreciated so much !!
Posted: Thu Aug 08, 2019 4:14 pm
by drifterf
sorry one last thing (i promise) the main html page (localhost:port) isit possible to put a better html in this location, if i was to create a html in a web design software and then copy replace the code to the
self.write("""<html> part would this show my designed website or can i ask it to read the html the same as staticfilehandler ?
thanks
Posted: Thu Aug 08, 2019 4:41 pm
by ghp
StaticFileHandler is a good choice for the start page.
If you need images or css files, add appropriate url-pathes too.
Posted: Thu Aug 08, 2019 4:54 pm
by drifterf
hi, thanks thats excellent, i cant appreicate your time enough with me on this !!! thanks !!
Posted: Fri Aug 09, 2019 3:43 pm
by drifterf
so much for the last question i promise thing lol
i have it working as i want but made a html file which redirects back to the main page after 5 seconds.
so when you press a button it calls the opendoor_1_success and shows my return.html (which has the javascript redirect in it) but it stays on this page and does not redirect. if i launch the .html on its open it works fine ?
is there something i can code into the .server.py to auto redirect to the previous page after a set time ?
thanks
Posted: Sat Aug 10, 2019 6:28 am
by drifterf
can anyone help with this so i can continue my project over the weekend ? thanks
Posted: Sat Aug 10, 2019 7:49 am
by ghp
Think tornado can't achieve to change a web page in a browser after some seconds. **
This requirement needs javascript in the page.
Found
https://www.tutorialspoint.com/How-to-u ... -5-seconds
The code snippet from there is
<!DOCTYPE html>
<html>
<body>
<script>
setTimeout(function(){
window.location.href = 'https://www.tutorialspoint.com/javascript/';
}, 5000);
</script>
<p>Web page redirects after 5 seconds.</p>
</body>
</html>
** complex answer: it is possible with some overhead:
- open a websocket from browser to server. needs javascript in browser and to configure appropriate Handler in tornado
- listen for messages in browser, again in javascript, and change page if specific message arrives.
- keep the application state on python side and provide timeouts.
Posted: Sat Aug 10, 2019 8:45 am
by drifterf
thanks, i have tornado redirecting to a page called return.html and in that page it has that javascript to tell it to direct to a differnt page.
as said if i do it through the localhost:8787 it shows the page once i click the link but never redorects. if i just launch the return.html it works fine
