Hal_cat
gpiozero SPI select CS1 issue
Wed Jul 17, 2019 5:47 pm
I am working with Python 3.5 with gpiozero 1.5.0. I have successfully used the following script:
from gpiozero import MCP3002
from time import sleep
import spidev
spi_max_speed = 50000     # 1 MHz for SPI
spi = spidev.SpiDev()
spi.open(0, 0)
spi.max_speed_hz = spi_max_speed
while True:
    #read channel 0 on device 0
    pot = MCP3002(chan)
    print("pot value = ", pot.value)
    print()
    sleep(1)
However, I would like to access this device using CS1.
When I tried to specify CS1 in the open statement:
spi.open(0,0,1)
I get "Type error: open() takes at most 2 arguments" even though the documentation presents this as an option.
Is there another way to specify the chip select line to spi?
trejan
Re: gpiozero SPI select CS1 issue
Wed Jul 17, 2019 6:03 pm
spidev.open is only 2 arguments. The device argument is the CE pin as the bus is which SPI interface.
open(bus, device)
Connects to the specified SPI device, opening `/dev/spidev<bus>.<device>`
A bigger issue is that you're mixing up the gpiozero module with the spidev module. They're two separate APIs. If you want to specify which SPI interface and which chip enable line for the MCP3002 module then you give it some optional arguments.
ben_nuttall
Thu Jul 18, 2019 9:40 pm
You don't need to import spidev. Use the keyword arguments in gpiozero's MCP3002 class documented here: https://gpiozero.readthedocs.io/en/stab ... yword-args
Author of GPIO Zero and creator of piwheels
Hal_cat
Mon Jul 22, 2019 5:34 pm
I get your point that mixing spidev and gpiozero could cause problems. The only reason I included spidev is that it provides a way to set the SPI clock speed.
I've retested after removing spidev and using the following:
    pot = MCP3002(channel=0, device=1)
and it works perfectly.
It appears the gpiozero must be setting the clock speed to about 308KHz, although I cannot find any documentation indicating that it sets clock speed, nor any way for me to set it. At this point everything is OK, so until becomes a problem I'm good with it.
Thank you both.
Return to “Python”
