Using spidev on python to connect the mcp2515
Posted: Mon Jul 15, 2019 10:46 am
by AlBPt
Hi
I want to connect the rasp with the can bus via mcp2515.
I have installed the latest version raspbian(4.19.57), and there are sth wrong.
I have a sample successfully run on the old version OS(4.4.x), everything is ok, but when I run "sudo apt-get update & sudo apt-get upgrade" or I reinstall the latest version OS, the code can't read the mcp2515's register data.
And I make a simple exam, one raspberry with old version OS img(backup img file), and one with the latest version OS img(both rasp are pi 3B).
old-one(kernal 4.4.x) ---------[0x01,0x02,0x03,0x04]--------> latest-one(kernal 4.19.57) : get the interrupt but can't read the data(which shows [0])
latest-one ----------[0x05,0x06,0x07,0x08]--------> old-one : get the interrupt and read the right data
The old one can read and send the right data , but the latest one can send but can't read the data.
I find the function spidev.xfer2() couldn't get the right data, so what should I do?
following are my code
#!/usr/bin/env python
# -*- coding: utf-8 -*-
#ECU
import spidev,time
import sys,cmd,shlex,types
import os,threading,signal
import RPi.GPIO as gpio
from mcp2515 import *
from time import ctime
spi = spidev.SpiDev(0,0)
print(spi.max_speed_hz)
def mcp2515_reset():
    tmpc = [0xc0]
    spi.writebytes(tmpc)
def mcp2515_writeReg(addr, val):
    buf = [0x02, addr, val]
    spi.writebytes(buf)
def mcp2515_readReg(addr):
    buf = [0x03, addr, 0x55]
    buf = spi.xfer2(buf)
    return int(buf[2])
def mcp2515_init():
    gpio.setup(26,gpio.OUT)
    mcp2515_reset()
    time.sleep(2)
    #mcp2515_writeReg(CNF1,0x01)
    #mcp2515_writeReg(CNF2,0x9d)
    #mcp2515_writeReg(CNF3,0x44)
    #CNF1 xx xxxxxx    SJW   BRP    Fosc 8MHz
    #CNF2 xx xxx xxx
    #CNF3 xxxxx xxx
    #NBR = 1/NBT
    #TQ = 2*(BRP + 1)/Fosc
    #NBT/TQ = 1 + ( CNF2<2:0>+1 ) + ( CNF2<5:3>+1 ) + ( CNF3<2:0>+1 )
    #NBR = Fosc / [ 2 * (BRP+1) * (   1 + ( CNF2<2:0>+1 ) + ( CNF2<5:3>+1 ) + ( CNF3<2:0>+1 )    ) ]
    mcp2515_writeReg(CNF1,CAN_125Kbps);
    print(CAN_125Kbps)
    mcp2515_writeReg(CNF2,0x80|PHSEG1_3TQ|PRSEG_1TQ);
    print(0x80|PHSEG1_3TQ|PRSEG_1TQ)
    mcp2515_writeReg(CNF3,PHSEG2_3TQ);
    print(PHSEG2_3TQ)
    # 125kbps
    mcp2515_writeReg(RXB0SIDH,0x00)                     #
    mcp2515_writeReg(RXB0SIDL,0x00)                     #
    mcp2515_writeReg(RXB0EID8,0x00)                     #
    mcp2515_writeReg(RXB0EID0,0x00)                     #
    mcp2515_writeReg(RXB0CTRL,0x60)                     # 0 10 0 0 0 0 0
    print(mcp2515_readReg(RXB0CTRL))
    mcp2515_writeReg(RXB0DLC,DLC_8)                     #
    mcp2515_writeReg(RXF0SIDH,0x00)         #00000000      #
    mcp2515_writeReg(RXF0SIDL,0x00)         #001 0 0 0 11  #
    mcp2515_writeReg(RXF0EID8,0x00)         #11111111      #
    mcp2515_writeReg(RXF0EID0,0x00)         #11111111      #
    mcp2515_writeReg(RXM0SIDH,0xFF)         #1111 1111      #
    mcp2515_writeReg(RXM0SIDL,0xE3)         #111 0 0 0 11   #
    mcp2515_writeReg(RXM0EID8,0xFF)         #1111 1111      #
    mcp2515_writeReg(RXM0EID0,0xFF)         #1111 1111      #
    mcp2515_writeReg(CANINTF,0x00)                      #
    mcp2515_writeReg(CANINTE,0x01)                      #
    mcp2515_writeReg(CANCTRL,REQOP_NORMAL|CLKOUT_ENABLED)       #
    print("\r\nMCP2515 Initialized.\r\n")
def mcp2515_write(buf,addr):
    if mcp2515_readReg(TXB0CTRL)&0x10:
      print("send message error")
      print(mcp2515_readReg(TXB0CTRL))
      print(mcp2515_readReg(CANINTF))
      print(mcp2515_readReg(EFLG))
      mcp2515_writeReg(TXB0CTRL,0x00)
    for i in range(50):
        time.sleep(2)
        if not mcp2515_readReg(TXB0CTRL)&0x08:
          break
    mcp2515_writeReg(TXB0SIDH, addr[0])  #
    mcp2515_writeReg(TXB0SIDL, addr[1])  #
    mcp2515_writeReg(TXB0EID8, addr[2])  #
    mcp2515_writeReg(TXB0EID0, addr[3])  #
    N = len(buf)
    for j in range(N):
        mcp2515_writeReg(TXB0D0+j,buf[j])
    mcp2515_writeReg(TXB0DLC,N)
    mcp2515_writeReg(TXB0CTRL,0x08)
    # 0 0 0 0 1 0 00
def mcp2515_read():
    N = 0
    buf = []
    if mcp2515_readReg(CANINTF) & 0x01:
        N = mcp2515_readReg(RXB0DLC)#
        for i in range(N):
            buf.append(mcp2515_readReg(RXB0D0+i))#
    mcp2515_writeReg(CANINTF,0)#
    return buf
gpio.setmode(gpio.BCM)
#set the interrupt
gpio.setup(21,gpio.IN)
def getorder_callBack(channel):
  print("get the data")
  buf2=mcp2515_read()
  print("received data: ",buf2)
  # recover the interrupt
gpio.add_event_detect(21,gpio.FALLING,callback=getorder_callBack)
def quit(signum,frame):
  print("You stop me")
  sys.exit()
if __name__=='__main__':
  try:
    mcp2515_init()
    while True:
        buf1 = [1,2,3,4]
        mcp2515_write(buf1,[0x00,0x20,0x00,0x00])
        time.sleep(3)
  finally:
    gpio.cleanup()
Re: Using spidev on python to connect the mcp2515
Posted: Tue Jan 28, 2020 12:56 pm
by latondominik
Hi!
Did you find the solution of this problem? I also have the same issue - when I read register I see 00 all the time.
