And when card appears there is olsa GUI which is made with tkinter. They all work seperetaly but I could not work them asynchronously
I've read a lot about asyncronous jobs I am totally confused. Which library and WHY should I use among Processing or Threads or asyncio or something else...
Can anyone help me?
Here is some parts of my code
Reader.py
from datetime import datetime,timedelta
import sys
from pirc522 import RFID
class Reader(object):
def __init__(self,accessList,entryLogger):
self.reader = RFID()
self.accessList = accessList
self.entryLogger = entryLogger
self.ex_time = datetime(2017,12,12,12,12,12)
self.ex_uid = ""
def read(self):
cardUID = ""
self.reader.wait_for_tag()
(error,data) = self.reader.request()
(error, uid) = self.reader.anticoll()
if not error:
for number in uid[:4]:
cardUID += format(number,"02X")
new_time = self._readed_at()
if(new_time - self.ex_time > timedelta(seconds = 3)):
self.ex_time = datetime.now()
return cardUID
def is_granted(self,uid):
if uid is not None and uid in self.accessList:
self.entryLogger.log(uid)
print("Access Granted. UID: " + uid)
return uid
def _readed_at(self):
return datetime.now()
def main():
download_settings()
create_folders()
settings = read_settings()
accessList = get_user_list(settings)
configure_scheduler(settings)
reader = Reader(accessList, entryLogger)
message_sender = MessageSender(client.check,client.bulk)
while True:
authorized_uid = reader.is_granted(reader.read())
#TODO:If not authorized in AccessList.txt look to the server
if authorized_uid is not None:
open_door()
check_model = CheckModel(configs.DeviceSerialNumber, authorized_uid)
message.put_message(check_model)Code: Select all
from json_helper import JSONHelper
from database_helper import *
from model_helper import ModelHelper
class Message():
def __init__(self, queue, client, syncLogger=None, entryLogger=None, errorLogger=None):
self.queue = queue
self.entryLogger = entryLogger if entryLogger is not None else None
self.errorLogger = errorLogger if errorLogger is not None else None
self.syncLogger = syncLogger if syncLogger is not None else None
self.DatabaseAction = DBHelper()
def put_message(self, message):
self.put_to_queue(self.queue, message)
self.put_to_db(message)
def get_message(self):
return self.get_from_queue(self.queue)
def put_to_queue(self, queue, message):
self.queue.put(message)
def get_from_queue(self, queue):
if not queue.empty():
return queue.get()
else:
print("Queue is empty")
return None
def put_to_db(self, message):
message = ModelHelper.checkmodel_to_log(message)
self.DatabaseAction.insert(Record(message.__dict__))
def get_from_db(self,message,criteria):
pass
