Problem running mypi.py on Pi Zero W
Posted: Sat Jun 22, 2019 12:12 am
by kflmiami420
Hi I have this program
#!/usr/bin/python
#                mypi.py
#  Functions to display Pi properties
#  If called directly outputs :
#  - Pi Model
#  - Revision number
#  - Serial number
#  - Python version
#  - I2C,SPI and Bluetooth status
#  - Mac address
#  - IP address
#  - CPU temperature
#  - GPU temperature
# Author : Matt Hawkins
# Date   : 06/12/2017
# https://www.raspberrypi-spy.co.uk/
import platform
import subprocess
import os
# Define functions
def getModel():
  # Extract Pi Model string
  try:
    mymodel = open('/proc/device-tree/model').readline()
  except:
    mymodel = "Error"
  return mymodel
def getSerial():
  # Extract serial from cpuinfo file
  mycpuserial = "Error"
  try:
    f = open('/proc/cpuinfo','r')
    for line in f:
      if line[0:6]=='Serial':
        mycpuserial = line[10:26]
    f.close()
  except:
  return mycpuserial
def getRevision():
  # Extract board revision from cpuinfo file
  myrevision = "Error"
  try:
    for line in f:
      if line[0:8]=='Revision':
        myrevision = line[11:-1]
    f.close()
  except:
  return myrevision
def getEthName():
  # Get name of Ethernet interface
  try:
    for root,dirs,files in os.walk('/sys/class/net'):
      for dir in dirs:
        if dir[:3]=='enx' or dir[:3]=='eth':
          interface=dir
  except:
    interface="None"
  return interface
def getMAC(interface='eth0'):
  # Return the MAC address of named Ethernet interface
  try:
    line = open('/sys/class/net/%s/address' %interface).read()
  except:
    line = "None"
  return line[0:17]
def getIP(interface='eth0'):
  # Read ifconfig.txt and extract IP address
  try:
    filename = 'ifconfig_' + interface + '.txt'
    os.system('ifconfig ' + interface + ' > /home/pi/' + filename)
    f = open('/home/pi/' + filename, 'r')
    line = f.readline() # skip 1st line
    line = f.readline() # read 2nd line
    line = line.strip()
    f.close()
    if line.startswith('inet '):
      a,b,c = line.partition('inet ')
      a,b,c = c.partition(' ')
      a=a.replace('addr:','')
    else:
      a = 'None'
    return a
  except:
    return 'Error'
def getCPUtemp():
  # Extract CPU temp
  try:
    temp = subprocess.check_output(['vcgencmd','measure_temp'])
    temp = temp[5:-3]
  except:
    temp = '0.0'
  temp = '{0:.2f}'.format(float(temp))
  return str(temp)
def getGPUtemp():
  # Extract GPU temp
  try:
    temp = subprocess.check_output(['cat','/sys/class/thermal/thermal_zone0/temp'])
    temp = float(temp)/1000
  except:
    temp = 0.0
  temp = '{0:.2f}'.format(temp)
  return temp
def getRAM():
  # free -m
  output = subprocess.check_output(['free','-m'])
  lines = output.splitlines()
  line  = str(lines[1])
  ram = line.split()
  # total/free
  return (ram[1],ram[3])
def getDisk():
  # df -h
  output = subprocess.check_output(['df','-h'])
  disk  = line.split()
  # total/free
  return (disk[1],disk[3])
def getCPUspeed():
  # Get CPU frequency
  try:
    output = subprocess.check_output(['vcgencmd','get_config','arm_freq'])
    output = output.decode()
    line  = lines[0]
    freq = line.split('=')
    freq = freq[1]
  except:
    freq = '0'
  return freq
def getUptime():
  # uptime
  # tupple uptime, 5 min load average
  return 0
def getPython():
  # Get current Python version
  # returns string
  pythonv = platform.python_version()
  return pythonv
def getSPI():
  # Check if SPI bus is enabled
  # by checking for spi_bcm2### modules
  # returns a string
  spi = "False"
  try:
    c=subprocess.Popen("lsmod",stdout=subprocess.PIPE)
    gr=subprocess.Popen(["grep" ,"spi_bcm2"],stdin=c.stdout,stdout=subprocess.PIPE)
    output = gr.communicate()[0]
    if output[:8]=='spi_bcm2':
      spi = "True"
  except:
    pass
  return spi
def getI2C():
  # Check if I2C bus is enabled
  # by checking for i2c_bcm2### modules
  # returns a string
  i2c = "False"
  try:
    gr=subprocess.Popen(["grep" ,"i2c_bcm2"],stdin=c.stdout,stdout=subprocess.PIPE)
    if output[:8]=='i2c_bcm2':
      i2c = "True"
  except:
    pass
  return i2c
def getBT():
  # Check if Bluetooth module is enabled
  # returns a string
  bt = "False"
  try:
    gr=subprocess.Popen(["grep" ,"bluetooth"],stdin=c.stdout,stdout=subprocess.PIPE)
    if output[:9]==b'bluetooth':
      bt = "True"
  except:
    pass
  return bt
if __name__ == '__main__':
  # Script has been called directly
  myRAM = getRAM()
  myDisk = getDisk()
  ethName = getEthName()
  print("----------------------------------------")
  print("Pi Model             : " + getModel())
  print("System               : " + platform.platform())
  print("Revision Number      : " + getRevision())
  print("Serial Number        : " + getSerial())
  print("Python version       : " + platform.python_version())
  print("I2C enabled          : " + getI2C())
  print("SPI enabled          : " + getSPI())
  print("Bluetooth enabled    : " + getBT())
  print("Ethernet Name        : " + ethName)
  print("Ethernet MAC Address : " + getMAC(ethName))
  print("Ethernet IP Address  : " + getIP(ethName))
  print("Wireless MAC Address : " + getMAC('wlan0'))
  print("Wireless IP Address  : " + getIP('wlan0'))
  print("CPU Clock            : " + getCPUspeed() + "MHz")
  print("CPU Temperature      : " + getCPUtemp() + u"\u00b0" +"C")
  print("GPU Temperature      : " + getGPUtemp() + u"\u00b0" +"C")
  print("RAM (Available)      : " + myRAM[0] + "MB (" + myRAM[1] + "MB)")
  print("Disk (Available)     : " + myDisk[0] + " (" + myDisk[1] + ")")
the output is this
Pi Model : Raspberry Pi 3 Model B Rev 1.2
System : Linux-4.19.42-v7+-armv7l-with-debian-9.9
Revision Number : a22082
Serial Number : 00000000a0dffe96
Python version : 2.7.13
I2C enabled : True
SPI enabled : True
Bluetooth enabled : True
Ethernet Name : eth0
Ethernet MAC Address : b8:27:eb:df:
Ethernet IP Address : None
Wireless MAC Address : b8:27:eb:8a:xx:xx #added xx to protect privacy in forum
Wireless IP Address : 192.168.1.xxx #added xx to protect privacy in forum
CPU Clock : 1200MHz
CPU Temperature : 56.90°C
GPU Temperature : 57.46°C
RAM (Available) : 969MB (480MB)
Disk (Available) : 12G (4.8G)
but it does not run on Pi Zero W
I had to comment out the
Does anyone know what the proper syntax is for getting this code or something that will display that info
Re: Problem running mypi.py on Pi Zero W
Posted: Sat Jun 22, 2019 6:07 am
by saltydog
The pi zero doesn't have an Ethernet port.
The wireless addr should return a result
Chris
Posted: Sat Aug 17, 2019 8:30 am
by kflmiami420
Just Updated and got the code working
I wanted to share the revised script
# mypi.py
# - Pi Model
# - Revision number
# - Serial number
# - Python version
# - Mac address
# - IP address
# - CPU temperature
# - GPU temperature
# revised 08-17-2019
#!/usr/bin/python3
#                mypi.py
#  - Pi Model
#  - Revision number
#  - Serial number
#  - Python version
#  - Mac address
#  - IP address
#  - CPU temperature
#  - GPU temperature
# Date   : 06/12/2017 Revised 08-17-2019 for my Pi Zero W (by kflmiami420)
import platform
import subprocess
import os
import socket
from uuid import getnode as get_mac
# Define functions
def getModel():
  try:
  except:
    mymodel = "Error"
  return mymodel
def getSerial():
  try:
    for line in f:
    f.close()
  except:
  return mycpuserial
def getRevision():
  try:
    for line in f:
    f.close()
  except:
  return myrevision
def get_local_ip_address(target):
  ipaddr = ''
  try:
    s = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
    s.connect((target, 8000))
    ipaddr = s.getsockname()[0]
    s.close()
  except:
    pass
  return ipaddr
def getCPUtemp():
  # Extract CPU temp
  try:
    temp = temp[5:-3]
  except:
    temp = '0.0'
  return str(temp)
def getGPUtemp():
  # Extract GPU temp
  try:
  except:
    temp = 0.0
  return temp
def getRAM():
  # free -m
  ram = line.split()
  # total/free
def getDisk():
  # df -h
  disk  = line.split()
  # total/free
def getCPUspeed():
  # Get CPU frequency
  try:
    line  = lines[0]
    freq = freq[1]
  except:
    freq = '0'
  return freq
def getUptime():
  # uptime
  return 0
def getPython():
  # returns string
  return pythonv
def getSPI():
  # returns a string
  spi = "False"
  try:
      spi = "True"
  except:
    pass
  return spi
def getI2C():
  # returns a string
  i2c = "False"
  try:
      i2c = "True"
  except:
    pass
  return i2c
def getBT():
  # returns a string
  bt = "False"
  try:
      bt = "True"
  except:
    pass
  return bt
  myRAM = getRAM()
  myDisk = getDisk()
  host = socket.gethostname()
  mac = get_mac()
  macString = ':'.join(("%012X" % mac)[i:i+2] for i in range(0, 12, 2))
  print("Host                 :", host)
  print("Wireless IP Address  : " + get_local_ip_address('10.0.1.1'))
  print("Wireless MAC Address : " + macString )
Posted: Sat Aug 17, 2019 1:16 pm
by hippy
I had to comment out the ...
You could probably have checked 'ethName' to see if it were None or an empty string, and then only execute the ethernet stuff if there is ethernet available. You could wrap all that with 'try-except' for extra protection.
That way the exact same code should run on any Pi variant. And it would then work and report the ethernet detail if it were a Zero with a USB-to-ethernet adapter attached.
You can do similar for WiFi, so the exact same code works for Pi variants which don't have WiFi on-board, those which may have USB-to-WiFi adapters plugged in.
Posted: Sun Aug 18, 2019 9:46 pm
by kflmiami420
Thanks I will look into that. I really don't think anyone wants to work with boards that don't have wifi these days. ( I know I don't)
I have some pi 3 and some pi 4 but I mainly deal in the Pi Zero W so that's why I set it up for the Pi W.
The original code does check for ethernet ip and mac address.
https://bitbucket.org/MattHawkinsUK/rpi ... on/mypi.py
#!/usr/bin/python
#                mypi.py
#  - Pi Model
#  - Revision number
#  - Serial number
#  - Python version
#  - Mac address
#  - IP address
#  - CPU temperature
#  - GPU temperature
# Date   : 06/12/2017
import platform
import subprocess
import os
# Define functions
def getModel():
  try:
  except:
    mymodel = "Error"
  return mymodel
def getSerial():
  try:
    for line in f:
    f.close()
  except:
  return mycpuserial
def getRevision():
  try:
    for line in f:
    f.close()
  except:
  return myrevision
def getEthName():
  try:
      for dir in dirs:
          interface=dir
  except:
    interface="None"
  return interface
  try:
  except:
    line = "None"
  return line[0:17]
  try:
    line = line.strip()
    f.close()
    else:
      a = 'None'
    return a
  except:
    return 'Error'
def getCPUtemp():
  # Extract CPU temp
  try:
    temp = temp[5:-3]
  except:
    temp = '0.0'
  return str(temp)
def getGPUtemp():
  # Extract GPU temp
  try:
  except:
    temp = 0.0
  return temp
def getRAM():
  # free -m
  ram = line.split()
  # total/free
def getDisk():
  # df -h
  disk  = line.split()
  # total/free
def getCPUspeed():
  # Get CPU frequency
  try:
    line  = lines[0]
    freq = freq[1]
  except:
    freq = '0'
  return freq
def getUptime():
  # uptime
  return 0
def getPython():
  # returns string
  return pythonv
def getSPI():
  # returns a string
  spi = "False"
  try:
      spi = "True"
  except:
    pass
  return spi
def getI2C():
  # returns a string
  i2c = "False"
  try:
      i2c = "True"
  except:
    pass
  return i2c
def getBT():
  # returns a string
  bt = "False"
  try:
      bt = "True"
  except:
    pass
  return bt
  myRAM = getRAM()
  myDisk = getDisk()
I have now broken the code as it is not reporting the status of the I2C , SPI , Bluetooth
Posted: Sun Aug 18, 2019 10:10 pm
by Andyroo
I have a couple of Pi boards (a 3B and 3B+) that are Ethernet only and have both the WiFi and Bluetooth disabled in config.txt
Neither need these functions (they are inches from a switch) so I disabled them
I also have a Zero connected via an USB link that does not have a WiFi chip but gets its LAN connected via a Mac.
Never assume a user will not do something just because you cannot think of a reason why :lol: Users do odd things on a daily basis and defensive programming is a must.
With the faster 4 Ethernet ports you may see more and more boards without WiFi up and running.
Edit: Also consider multiple WiFi / LAN adapters...
Posted: Mon Aug 19, 2019 12:01 am
by DougieLawson
That's a very bad programming technique. It's much better to use /tmp for temporary files rather than hard-coding a directory that may not exist.
Here's an example of how you can get IPv4 Address and HW MAC based on finding the interface names in /sys/class/net
#!/usr/bin/python
import fcntl, socket, struct
from os import walk
def getHwAddr(ifname):
    info = fcntl.ioctl(s.fileno(), 0x8927,  struct.pack('256s', ifname[:15]))
    return ''.join(['%02x:' % ord(char) for char in info[18:24]])[:-1]
def getIPAddr(ifname):
    if (ifname == "lo"):
        return "127.0.0.1"
    try:
         info = fcntl.ioctl(s.fileno(), 0x8915, struct.pack('256s', ifname[:15]))
    except:
         return "No address assigned"
    return socket.inet_ntoa(info[20:24])
f = []
path = '/sys/class/net'
for (dirpath, dirnames, filename) in walk(path):
    f.extend(dirnames)
    break
for iface in f:
    print "Interface:", iface
    print "IPv4 Addr:", getIPAddr(iface)
    print "HW MAC Addr:", getHwAddr(iface)
    print "-----------------------------"
Posted: Mon Aug 19, 2019 9:22 pm
by kflmiami420
DougieLawson Thank you for the code and the info on how to clean the code up
I want to add the results from i2cdetect -y 1 to the output but I am lost or dont know if it is even possible
Posted: Mon Aug 19, 2019 9:32 pm
by DougieLawson
This is a bit crude, but gives you the idea how to detect I2C devices.
#!/usr/bin/python
import smbus
import time
bus = smbus.SMBus(1)
low_addr=0x03
hi_addr=0x78
for addr in range(low_addr, hi_addr):
  try:
    bus.read_byte_data(addr,0x00)
    print "Addr: ", hex(addr)," OK"
  except:
    print "Addr: ", hex(addr),"BAD"
Posted: Tue Aug 20, 2019 2:21 am
by kflmiami420
Thank you I will implement that
