dsheli
Cut power to USB ports w/ Python
Sun May 26, 2019 1:51 am
Hello everyone!
I am working on a solar Pi timelapse rig and need to save power between shots. Killing power to the USB ports will cut my power consumption by almost 1 watt. I am able to successfully kill power with the following commands in bash:
Power off:
echo '1-1' |sudo tee /sys/bus/usb/drivers/usb/unbind
Power on:
echo '1-1' |sudo tee /sys/bus/usb/drivers/usb/bind
I am new to Python and would like for this script to be run in my Python script that is controlling the camera. I thought I would use the subprocess command but I am not having any luck.
subprocess.call(['echo','1-1|sudo tee /sys/bus/usb/drivers/usb/unbind'],shell=True)
Any thoughts?
Andyroo
Re: Cut power to USB ports w/ Python
Sun May 26, 2019 12:07 pm
I think it is because the subprocess captures stdin and stdout for itself rather than pass them through to the second part of the command.
A couple of thought (no Pi handy to try at the mo):
1) Try the Popen command from the same module
2) Create a little bash script that takes on / off as a parameter and just call that.
ghp
Sun May 26, 2019 2:20 pm
try:
    subprocess.call( "echo '1-1' |sudo tee /sys/bus/usb/drivers/usb/unbind", shell=True)
except ItIsASunnySundayAndNotWorkingAtAllException:
    pass
ankith26
Sat Jun 01, 2019 4:38 am
os.system(....) usually works for me.
although I heard its not recommended and am not so sure
My website is at https://pratt.ml
Hope it runs (which it wont)
Return to “Python”
