liviudiaconu85
use if from rc522
Thu May 23, 2019 10:41 am
Hello everyone, I need your help.
I use rc522, and I want to implement if var = id, but I get strange errors.
Thanks for your help.
code:
#!/usr/bin/env python
import RPi.GPIO as GPIO
from mfrc522 import SimpleMFRC522
reader = SimpleMFRC522()
try:
        id, text = reader.read()
        print(id)
        print(text)
var=id
if(var == 286858287748) :
print "Hi Liviu !"
finally:
        GPIO.cleanup()
error:
  File "Read2.py", line 13
    var=id
SyntaxError: invalid syntax
Andyroo
Re: use if from rc522
Thu May 23, 2019 12:20 pm
Welcome to the forum.
One issue i can see is that you have not completed the ‘try’ block with the ‘except’ part so Python gets a bit lost as to what should come next.
I’m not on a Pi at the moment but I think this should work if you match the indent to your code:
try:
    print(id)
    print(text)
except:
    print(‘Error in reading card’)
There is a good tool to play with the ‘try...except’ function on the web at https://www.w3schools.com/python/python_try_except.asp
Edit: I think you will need to add spaces after the ‘if’ line Else the print will also cause an error. You will find that you have to be very careful wth indents in Python - miss a space or four (4 being the normal setting) and all sorts will happen to the program :roll: :lol:
liviudiaconu85
Thu May 23, 2019 1:36 pm
import requests
try:
        print(id)
        print(text)
        os.system("wget -qO /dev/null 'http://www.web.com/rrhh/api/remote.php?i$
finally:
        GPIO.cleanup()
Theoretical I want that after recognizing the id, I call an api on the web. it's possible?
jadro
Thu May 23, 2019 1:45 pm
try:
        print(id)
        print(text)
        if id > 0:
        # Maybe you want this:
        if id > 0:
            os.system("wget -qO /dev/null 'http://www.web.com/rrhh/api/remote.php?id={}".format(id))
finally:
        GPIO.cleanup()
Oracle backend database developer
SmartHome IoT & Microprocessor enthusiast and hobbyist
liviudiaconu85
Thu May 23, 2019 1:47 pm
i am received this error
code
import os
import requests
try:
        print(id)
        print(text)
        if id > 0:
finally:
        GPIO.cleanup()
error :
sh: 1: Syntax error: Unterminated quoted string
jadro
Thu May 23, 2019 1:56 pm
It is end of file, put ")
jadro
Thu May 23, 2019 1:57 pm
It is also one quotte ' to end url
liviudiaconu85
Thu May 23, 2019 2:06 pm
is not work fine.
i am put this
os.system("wget -qO /dev/null 'http://www.ccccccccs.com/gps/registers.php?id={}.format(id)'")
in MySQL instead of id is this
id = {}.format(id)
jadro
Thu May 23, 2019 2:38 pm
os.system("wget -qO /dev/null 'http://www.ccccccccs.com/gps/registers.php?id={}' ".format(id))
This is properly closed quotas. Try with this.
Jadro
liviudiaconu85
Thu May 23, 2019 3:48 pm
Now it does not work Error goes out before calling the web.
 File "read4.py", line 15
    os.system("wget -qO /dev/null 'http://www.ccc.com/gps/registergps.php?id={}'".format(id))
IndentationError: expected an indented block
jadro
Thu May 23, 2019 3:51 pm
Put it on the same indent as old code. And all in one line, not in two lines
Andyroo
Thu May 23, 2019 3:55 pm
Try this as your formatting is getting out of hand :lol:
import os
import requests
try:
    print(id)
    print(text)
    if id > 0:
        os.system("wget -qO /dev/null 'http://www.web.com/rrhh/api/remote.php?id={}'".format(id))
finally:
    GPIO.cleanup()
liviudiaconu85
Thu May 23, 2019 4:09 pm
Thanks, it works.
Return to “Python”
