seanspotatobusiness
RGB rainbow transition by PWM not working for me
Wed May 22, 2019 11:48 am
I'm trying to use the code kindly provided by another forum user here: viewtopic.php?t=126405
The code is for driving RGB LEDs through the rainbow via PWM.
The problem is that the code doesn't seem to work for me. I get the output printing to the terminal window but I don't get the expected colour transitions. I know that my pins are connected correctly because some other code (which does random transitions rather than deliberate rainbow transitions) does work.
Here's the code that I'm having a problem with:
import random, time
import RPi.GPIO as GPIO
import colorsys
RUNNING = True
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(False)
red = 8
green = 10
blue = 12
GPIO.setup(red, GPIO.OUT)
GPIO.setup(green, GPIO.OUT)
GPIO.setup(blue, GPIO.OUT)
Freq = 100
RED = GPIO.PWM(red, Freq)
RED.start(100)
GREEN = GPIO.PWM(green, Freq)
GREEN.start(100)
BLUE = GPIO.PWM(blue, Freq)
BLUE.start(100)
outval = 128
def wheel_color(position):
    """Get color from wheel value (0 - 384)."""
    if position < 0:
        position = 0
    if position > 384:
        position = 384
    if position < 128:
        r = 127 - position % 128
        g = position % 128
        b = 0
    elif position < 256:
        g = 127 - position % 128
        b = position % 128
        r = 0
    else:
        b = 127 - position % 128
        r = position % 128
        g = 0
    return r, g, b
try:
    while(True):
        for pos in range(0,385):
            r, g, b = wheel_color(pos)
            print (r, g, b)
            percenttestr = (r/128.0)*100.0
            percenttestg = (g/128.0)*100.0
            percenttestb = (b/128.0)*100.0
            print (percenttestr)
            print (percenttestg)
            print (percenttestb)
            RED.ChangeDutyCycle(percenttestr)
            GREEN.ChangeDutyCycle(percenttestg)
            BLUE.ChangeDutyCycle(percenttestb)
            time.sleep(0.1)
except KeyboardInterrupt:
    GPIO.cleanup()
and here's the code that is working okay for me:
import threading
import time
import random
R = 8
G = 10
B = 12
PINS = [R,G,B]
def initialize_gpio():
    GPIO.setmode(GPIO.BOARD)
    GPIO.setup(PINS, GPIO.OUT, initial=GPIO.LOW)
def color_test(channel, frequency, speed, step):
    p = GPIO.PWM(channel, frequency)
    p.start(50)
    while True:
        for dutyCycle in range(0, 101, step):
            p.ChangeDutyCycle(dutyCycle)
            time.sleep(speed)
        for dutyCycle in range(100, -1, -step):
            time.sleep(speed)
def color_test_thread():
    threads = []
    threads.append(threading.Thread(target=color_test, args=(R, 200, 0.02, 1)))
    threads.append(threading.Thread(target=color_test, args=(G, 200, 0.035, 1)))
    threads.append(threading.Thread(target=color_test, args=(B, 200, 0.045, 1)))
    for t in threads:
        t.daemon = True
        t.start()
    for t in threads:
        t.join()
def main():
    try:
        initialize_gpio()
        print("\nPress ^C (control-C) to exit the program.\n")
        color_test_thread()
        pass
    finally:
        GPIO.cleanup()
if __name__ == '__main__':
    main()
Can anyone advise what I should do to find the cause of the problem?
Edit: could it be because I don't have colorsys? If that was the case, the code wouldn't run at all, right? When I type "pip install colorsys", I get the error:
[email protected]:~ $ pip install colorsys
Collecting colorsys
  Could not find a version that satisfies the requirement colorsys (from versions: )
No matching distribution found for colorsys
so I don't actually know whether I have it installed but I would expect an error when I try to run the script if it was unable to import a required library, right?
Last edited by seanspotatobusiness on Wed May 22, 2019 11:58 am, edited 1 time in total.
Raspberry Pi 3 B and B+
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
NAME="Raspbian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
Brandon92
Re: RGB rainbow transition by PWM not working for me
Wed May 22, 2019 11:54 am
The problem is that you not using the same pins on the header in your code.
So change this is you not working code
Into this
Brandon92
Wed May 22, 2019 1:18 pm
Response to your edit:
I think you don't need to include the colorsys at all. I can not see where you are using that module. So, if you try the code without that module, does it work then?
seanspotatobusiness
Thu May 23, 2019 10:19 am
Thanks very much! I thought colorsys provided the color wheel functionality? In any case, changing BCM to BOARD fixed the script.
VERSION_ID="9"
Brandon92
Thu May 23, 2019 10:46 am
Well, I don't that execly, because I did't use that function before. However, I saw that you only imported that functie but not using it in your code.
Return to “Python”
