moonjung
Why isn't the step motor working?
Tue May 21, 2019 1:13 am
I am trying to turn the motor by connecting the motor driver L298N and the stepper motor. I made a code and put it in a raspberry pie, but I can only hear the clatter and it doesn't work very well. Is there a problem with the code?
<code>
import RPi.GPIO as GPIO
from time import sleep
out11 = 26
out21 = 20
out31 = 16
out41 = 21
out12 = 24
out22 = 17
out32 = 27
out42 = 22
GPIO.setmode(GPIO.BCM)
GPIO.setup(out11,GPIO.OUT)
GPIO.setup(out21,GPIO.OUT)
GPIO.setup(out31,GPIO.OUT)
GPIO.setup(out41,GPIO.OUT)
GPIO.setup(out12,GPIO.OUT)
GPIO.setup(out22,GPIO.OUT)
GPIO.setup(out32,GPIO.OUT)
GPIO.setup(out42,GPIO.OUT)
sleep(0.5)
print "First calibrate by giving some +ve and -ve values....."
GPIO.output(out11,GPIO.LOW)
GPIO.output(out21,GPIO.LOW)
GPIO.output(out31,GPIO.LOW)
GPIO.output(out41,GPIO.LOW)
GPIO.output(out12,GPIO.LOW)
GPIO.output(out22,GPIO.LOW)
GPIO.output(out32,GPIO.LOW)
GPIO.output(out42,GPIO.LOW)
print "set"
sleep(0.5)
while True:
GPIO.output(out11,GPIO.HIGH)
GPIO.output(out12,GPIO.HIGH)
GPIO.output(out21,GPIO.HIGH)
GPIO.output(out22,GPIO.HIGH)
sleep(0.0208)
print"2"
GPIO.output(out31,GPIO.HIGH)
GPIO.output(out32,GPIO.HIGH)
sleep(0.0208)
print"4"
GPIO.output(out41,GPIO.HIGH)
GPIO.output(out42,GPIO.HIGH)
sleep(0.0208)
print"6"
sleep(0.0208)
print"8"
Gavinmc42
Re: Why isn't the step motor working?
Tue May 21, 2019 7:39 am
Put a loop in, you are only moving a few steps.
I'm dancing on Rainbows.
pcmanbob
Tue May 21, 2019 8:17 am
Hi.
So the first question is have you got the stepper motor connected to the L298N correctly , you need to make sure you have one coil connected to each side of the motor driver board, and you need to make sure the coils are actually connected the same way round.
next you need to tell us which pins on the pi are connected to which pins on the L298N, as an L298N only has 6 control pins and you are using 8 ?
and please when posting code use code tags
Add [code] at the top
code goes here
and [/code] at the bottom.
B.Goode
Tue May 21, 2019 8:46 am
Probably because of the lack of formatting you may have overlooked
while True:
Gavinmc42
Wed May 22, 2019 12:35 am
while True:
Did not see that? Still don't?
I also assumed this was driving two motors, hence the 1234 for motor1/motor2.
Without a circuit it is guesswork.
I do prefer the newer mosfet step/direction driver chips over this older bipolar style driver.
Return to “Python”
