Python program throws error when starting as service. Why?
Posted: Sun May 19, 2019 3:04 pm
by prwiley
I have a program I have setup a Unit file for so that it will run as a service on startup.
The program runs fine from the command line, however it fails to run on startup.
When I check the status of the service, I see that has it failed to load. I see the failure is the result of:
import paho.mqtt.client as mqtt
ImportError: No module named 'paho'
And yet the the program does run from the command line, and also in IDLE, just fine and throws no import error.
Can someone explain what's going on?
Many thanks
Re: Python program throws error when starting as service. Why?
Posted: Sun May 19, 2019 3:12 pm
by Andyroo
It could be the path.
Check the user the program is running under and it’s default path. I assume this user is root compared to Pi.
Posted: Sun May 19, 2019 3:28 pm
by prwiley
When I ps -ef | grep python the owner is pi
I note that a log file the program creates is put in /home/pi/ when run from the command line and in /home/pi/programDir/ when run from IDLE
Is the fix just providing the right path for the import statement? No sure I quite know how to find it.
Posted: Sun May 19, 2019 5:23 pm
by prwiley
After some more searching I found this thread at StackExchnage: https://stackoverflow.com/questions/356 ... tl-service
Per the advice there are updated my Unit file as follows:
[Unit]
Description=my.service
[Service]
WorkingDirectory=/home/pi/
User=pi
ExecStart=/home/user/otherDir/program.py
Restart=always
[Install]
WantedBy=multi-user.target
This did the trick. Before doing this I also changed the default python from 2.7.x to 3.5.x
Posted: Sun May 19, 2019 5:40 pm
by Andyroo
Just a bit concerned about the change - that may break other things within the OS that are expecting that Python 2 is the default. It may be better to make the Python3 the executable program with your program and path the parameter...
