Question about Tkinter text widged in scrolledtext
Posted: Sun May 19, 2019 1:42 pm
by joseplaselva
I would like to know if it is a way of dysplay the lines from top to botton in a scrolledtext widget. Now when I write a line appears allways in the top when the first one appears in the botton. When I write on a simple text widget appears in the other way, the last line is allways at the botton...
Thanks if some one can make me see the light :-)
Re: Question about Tkinter text widged in scrolledtext
Posted: Sun May 19, 2019 4:11 pm
by Paeryn
Your description is a bit confusing,
When you say write do you mean inserting text from within your program or do you mean typing text into the widget? Either way a ScrolledText widget should handle writes exactly like a Text widget does as that is what that area is.
The ScrolledText widget is just three widgets combined: a text widget, a scrollbar widget and a frame widget enclosing the text and scrollbar. The ScrolledText widget behaves like a Text widget, the only difference is that the scrollbar can change what part of the text is visible when there is more text than it can display.
Posted: Sun May 19, 2019 4:20 pm
by joseplaselva
Hi , thanks for fast reply.
The text is writing by scrip as folow :
    def write_line(self):
        global display_event
        timenu = str(time.strftime("%y-%m-%d %H:%M:%S"))
        texte = timenu + "  " + display_event + " \n"
        self.textEvents.insert("1.0", texte)
        self.textEvents.update_idletasks()
Posted: Sun May 19, 2019 4:23 pm
by joseplaselva
and appears in the widget as folow :
19-05-19 18:20:45  =Check: Succeed mailed
19-05-19 18:20:39  =Check: Camera:19-May-19_(182036)
19-05-19 18:20:36  =Check: Down 1.35 Mbit | Up:0.75 Mbit
19-05-19 18:20:00  =Check: IP: 87.125.68.81
19-05-19 18:13:02  Starting survey every 5 minutes...
19-05-19 18:13:02  == Initial procedures acomplished ==
19-05-19 18:13:02  ...Succeed sending mail
19-05-19 18:12:56  Preparing to send Start-mail...
19-05-19 18:12:56  Test ok 19-May-19_(181254).jpg
19-05-19 18:12:54  Checking  camera...
19-05-19 18:12:54  Down:1.37 Mbit/s | Up:0.74 Mbit/s
19-05-19 18:12:17  Checking internet speed...
19-05-19 18:12:17  IP: 87.125.68.81
19-05-19 18:12:16  Checking internet connection...
19-05-19 18:12:16  ==Starting initial procedures==
Posted: Sun May 19, 2019 5:20 pm
by Paeryn
The "1.0" in the insert function says to insert the text at line 1 column 0, i.e. before anything else. To insert at the very end use
        self.textEvents.insert(tk.END, texte)
Posted: Sun May 19, 2019 5:30 pm
by joseplaselva
Thanks a lot , now run perfectly.
Have a nice sunday evening... and thanks again for your kind help
Cheers
Posted: Sun May 19, 2019 5:40 pm
by Paeryn
Glad I could help, have fun.
