sonettguy
cannot install miniconda on pi (SOLVED)
Sat May 18, 2019 6:26 pm
I'm trying to install miniconda on a pi zero running raspbian stretch and using python 2.7. I follow the posted instructions. I edit the bash instruction to match my selection of 32-bit miniconda, rather than the 64 that is cited in the instructions.
Installing on Linux
Download the installer:
Miniconda installer for Linux.
In your terminal window, run:
Miniconda:
bash Miniconda3-latest-Linux-x86.sh
Follow the prompts on the installer screens.
If you are unsure about any setting, accept the defaults. You can change them later.
To make the changes take effect, close and then re-open your terminal window.
Test your installation.
This is what happens.
Do you accept the license terms? [yes|no]
[no] >>> yes
Miniconda2 will now be installed into this location:
/home/user/miniconda2
- Press ENTER to confirm the location
- Press CTRL-C to abort the installation
- Or specify a different location below
[/home/user/miniconda2] >>>
PREFIX=/home/user/miniconda2
installing: python-2.7.15-h9bab390_6 ...
Miniconda2-latest-Linux-x86.sh: line
373: /home/user/miniconda2/pkgs/python-2.7.15-h9bab390_6/bin/python:
cannot execute binary file: Exec format error
[email protected]:/home/pi/Downloads $ conda list bash: conda: command not found
The files are downloaded into the microconda2 folder. But, the most basic command doesn't work, likely due to the abort. I removed everything reset and started over, but with the same result. Am I missing something basic? Like, perhaps, a secret to the install folder location? Or, not trying to do it as a sudo user?
klricks
Re: cannot install miniconda on pi
Sat May 18, 2019 6:38 pm
You appear to be attempting to install x86 code on your RPi. The RPi uses an ARM processor not Intel x86 i386 etc.
If the tutorial does not specifically mention for RPi and give detailed install instructions for the RPi then don't even bother to download it.
Unless specified otherwise my response is based on the latest and fully updated Raspbian Stretch w/ Desktop OS.
sonettguy
Re: cannot install miniconda on pi (SOLVED)
Sat May 18, 2019 6:51 pm
OOOoooooh. I knew I missed something basic. Thanks.
Sat May 18, 2019 7:09 pm
Installing on Linux
Miniconda:
[no] >>> yes
MiniConda is for x86 CPU...
...though old you could try:
https://github.com/jjhelmus/berryconda/ ... /README.md
adieu
HP Envy 4500 Wireless Printer supported by HPLIP software in Raspbian Stretch.
Return to “Python”
