ladypi
l298 python code
Mon May 13, 2019 10:35 am
hi guys
i used l298 for driving motors and everything goes right and dont have error for python code to run
but when i send command to run, motor doesnt work!
what is the problem?
i used this tutorial:
https://www.electronicshub.org/raspberr ... pberry-pi/
https://daneshjookit.com/%D9%85%DA%A9%D ... motor.html
B.Goode
Re: l298 python code
Mon May 13, 2019 11:55 am
Welcome to the Raspberry Pi forums.
hi guys
Although reference to the tutorials you used is valuable, it doesn't tell the volunteer helpers here how you may have interpreted (or misinterpreted) them.
It will probably be necessary to share a wiring diagram and a copy of your final (failing) code.
Have you tested the motors independently from the RPi, to check that they actually work?
pcmanbob
Mon May 13, 2019 12:44 pm
For the wiring its probably best to post some good pictures as a digram will still only show us how you think its connected, were as pictures will show that actual connections.
And the code will only run under python and not python 3
ladypi
Wed May 15, 2019 6:49 am
thanks, check this photo
import RPi.GPIO as GPIO
from time import sleep
in1 = 24
in2 = 23
en = 25
temp1=1
GPIO.setwarnings(False)
GPIO.setmode(GPIO.BCM)
GPIO.setup(in1,GPIO.OUT)
GPIO.setup(in2,GPIO.OUT)
GPIO.setup(en,GPIO.OUT)
GPIO.output(in1,GPIO.LOW)
GPIO.output(in2,GPIO.LOW)
p=GPIO.PWM(en,1000)
p.start(25)
print("\n")
print("The default speed & direction of motor is LOW & Forward.....")
print("r-run s-stop f-forward b-backward l-low m-medium h-high e-exit")
print("\n")
while(1):
    x=raw_input()
    if x=='r':
        print("run")
        if(temp1==1):
         GPIO.output(in1,GPIO.HIGH)
         print("forward")
         x='z'
        else:
         GPIO.output(in2,GPIO.HIGH)
         print("backward")
         x='z'
    elif x=='s':
        print("stop")
        x='z'
    elif x=='f':
        print("forward")
        temp1=1
        x='z'
    elif x=='b':
        print("backward")
        temp1=0
        x='z'
    elif x=='l':
        print("low")
        p.ChangeDutyCycle(25)
        x='z'
    elif x=='m':
        print("medium")
        p.ChangeDutyCycle(50)
        x='z'
    elif x=='h':
        print("high")
        p.ChangeDutyCycle(75)
        x='z'
    elif x=='e':
        GPIO.cleanup()
        break
    else:
        print("<<<  wrong data  >>>")
        print("please enter the defined data to continue.....")
joan
Wed May 15, 2019 10:20 am
How are you powering the motor? All I can see is a lead connected to the logic power supply.
pcmanbob
Wed May 15, 2019 10:27 am
It would be helpful if you post a picture showing the connections to the motor driver board more clearly especially the ones to the pi and power feed terminals, as we can quite be sure how things are currently connected.
ladypi
Wed May 15, 2019 10:34 am
yes i used 9v adapter for driver motor
ladypi
Wed May 15, 2019 10:36 am
i use 9v adapter for driver motor
joan
Wed May 15, 2019 10:53 am
May we have a photo showing the wiring side of the motor driver board? It is not clear where the various wires are connected.
ladypi
Wed May 15, 2019 11:13 am
add photo ..
pcmanbob
Wed May 15, 2019 11:31 am
Sorry but that picture is to small to clearly see anything.
Try uploading a larger image to an image sharing site like imgur.com and then post a link to it here, we need to be able to see detail like this
Example.
Are you sure your motor will run from the adapter you are using ?
have you tried connecting the motor directly to the adaptor to see if the motor runs ?
joan
Wed May 15, 2019 11:32 am
Need a photo from the other end so we can clearly see the IN1/2/EN and the power connections.
ladypi
Wed May 15, 2019 11:35 am
Example.
https://imgur.com/r6xJLLA
pcmanbob
Wed May 15, 2019 11:45 am
Well the connections between the pi and motor drive board look ok and I guess you have power connected to motor drive board because the red LED is lit.
when you try to run the motor does that red LED go out ?
Have you tried replacing the motor with a volt meter to see if you actually have any voltage on the motor terminals ?
Have you tried testing the motor drive board by manually making connections between control pins and 5v /ground on motor driver board with out having any connection to the pi what so ever ?
Edit.
So I just tested the program with an L298N and it works just fine motor running forward at low only gives 9.6V when using a 12V psu.
And that's with no motor connected so no load, so either your motor board is faulty, you have a bad connection some were, you motor will not run at the voltage supplied by your PSU or your PSU cant run both the motor and the motor driver board causing the motor driver board to shutdown.
ladypi
Wed May 15, 2019 12:37 pm
Edit.
thanks alot. i,ll with check it and tell you result
ghp
Wed May 15, 2019 5:17 pm
Hello, on one of the photos there is a small, blue plastic case with a label 'tower pro'. These devices are IMHO not suitable to be driven by a L293, but need a constant power supply with 5V and pulse width modulated signal to control them.
pcmanbob
Wed May 15, 2019 5:49 pm
That was my example picture to show the OP what sort of detail was required when posting pictures of wiring/gpio connections ,
hence the line " we need to be able to see detail like this " , it was just a random image I had posted before and I was not suggesting that you could control a servo ( Tower pro SS90 ) from an L298N.
Return to “Python”
