Killertechno
Get filter kernel from output signal?
Wed Apr 24, 2019 1:29 pm
Hi to all, I was taking a look to this convolution example:
import numpy as np
import scipy.signal
import matplotlib
import matplotlib.pyplot as plt
import sys
matplotlib.use('TkAgg')
# test convolve
kernel = [0.5, 0.45, 0.05,  0]
input_signal = [0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 0, 0, 0, 0, 0, 0]
filtered_signal = np.convolve(kernel , input_signal)
plt.title("kernel")
plt.plot(kernel)
plt.show()
plt.subplot(211)
plt.title("input signal")
plt.plot(input_signal)
plt.subplot(212)
plt.title("output signal")
plt.plot(filtered_signal)
plt.show()
Now.... is there a way I can get kernel from input_signal and filtered_signal?
Thanks.
paddyg
Re: Get filter kernel from output signal?
Fri Apr 26, 2019 11:41 am
I think that it's possible because it acts linearly so 'just' a matter of solving simultaneous equations. Things that would make it difficult would be a) knowing the size of the kernel b) edge behavior, which is related to a. as the default edge behavior would tell you the size of the kernel. c) lack of info such as input and output being all zero.
You could re-arrange your signal, kernel and output as a system of equations and use https://docs.scipy.org/doc/numpy/refere ... solve.html Possibly working your way along the array until to got to a soluble section.
i.e. for you it might be something like
k0*i8 + k1*i7 + k2*i6 + k3*i5 = o8
k0*i9 + k1*i8 + k2*i7 + k3*i6 = o9
k0*i10 + k1*i9 + k2*i8 + k3*i7 = o10
k0*i11 + k1*i10 + k2*i9 + k3*i8 = o11
where k0,k1 etc are the unknowns x in the example
Return to “Python”
